    Connection issue on long prints.
    Duet Web Control
    778
    • tracarundefined
      tracar
      its been said here lots, and i dont see the fix. after many hours the webpage drops the connection and hangs, both firefox and chrome. ( in my PC) , now im using the latest firmwares. duet2 wireless.
      i have had the same problem before with lower revisions.
      i can connect with any of my other devices without issue , just not the PC , unless i restart it.
        Can you provide the results of M122?
        • tracarundefined
          tracar
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
          Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
          Used output buffers: 3 of 24 (11 max)
          Static ram: 23460
          Dynamic ram: 73652 of which 44 recycled
          Never used RAM 14924, free system stack 191 words
          Tasks: NETWORK(ready,180) HEAT(blocked,309) MAIN(running,470) IDLE(ready,19)
          Owned mutexes:
          Last reset 00:00:27 ago, cause: software
          Last software reset at 2021-01-15 20:44, reason: User, GCodes spinning, available RAM 14924, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          MCU temperature: min 26.0, current 26.7, max 27.2
          Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2021-01-15 20:45:18
          Cache data hit count 33439127
          Slowest loop: 8.21ms; fastest: 0.23ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.8ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 15.76ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.25
            WiFi MAC address ec:fa:bc:5b:3f:ab
            WiFi Vcc 3.43, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 25360
            WiFi IP address 192.168.0.111
            WiFi signal strength -69dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            Socket states: 4 0 0 0 0 0 0 0
          im starting another 30 hour print i will repost another M122 after its doneto compare.
          • tracarundefined
            tracar
            i typed m112 instead, Twice,, noob..... anyways look at the temp during the seconds i did not hit the reconect button........... Hmmmmmmtemp error.png
              Phaedrux Moderator @tracar
              @tracar said in Connection issue on long prints.:
              So you mean you can connect to the Duet with another device like your phone, but not with your PC until you restart the PC or the Duet?
              Please post your config.g
              • tracarundefined
                tracar
                M122 after the connection problem...
                m122
                Used output buffers: 3 of 24 (21 max)
                Static ram: 23460
                Dynamic ram: 73860 of which 80 recycled
                Never used RAM 14680, free system stack 103 words
                Tasks: NETWORK(ready,180) HEAT(blocked,309) MAIN(running,402) IDLE(ready,19)
                Owned mutexes: WiFi(NETWORK)
                Last reset 13:58:41 ago, cause: software
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 25.7, current 27.7, max 28.8
                Supply voltage: min 23.8, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                Driver 0: position 86402, standstill, SG min/max not available
                Driver 1: position -17072, standstill, SG min/max not available
                Driver 2: position 17952, standstill, SG min/max not available
                Driver 3: position 0, ok, SG min/max not available
                Date/time: 2021-01-16 10:43:32
                Slowest loop: 69.13ms; fastest: 0.18ms
                === Storage ===
                Free file entries: 9
                SD card longest read time 5.0ms, write time 2.1ms, max retries 0
                DMs created 83, maxWait 194553ms, bed compensation in use: none, comp offset 0.000
                === MainDDARing ===
                Scheduled moves 536861, completed moves 536855, hiccups 2, stepErrors 0, LaErrors 0, Underruns [118, 0, 0], CDDA state 3
                === AuxDDARing ===
                Heater 0 is on, I-accum = 0.0
                Heater 1 is on, I-accum = 0.3
                Segments left: 1
                File is doing "G1 X228.584 Y264.573 E0.7917" in state(s) 0
                === Network ===
                Slowest loop: 201.81ms; fastest: 0.10ms
                • WiFi -
                  Failed messages: pending 0, notready 0, noresp 1
                  WiFi flash size 4194304, free heap 22208
                  WiFi signal strength -72dBm, mode 802.11n, reconnections 0, sleep mode modem
                  1/16/2021, 10:41:18 AM Connected to 192.168.0.111
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 30 2020 09:00:14 GMT-0600 (Mountain Daylight Time)
                M550 P"Duet2" ; set printer name
                M669 K1 ; select CoreXY mode
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                ; Input/Output Physical Estop
                M950 J1 C"e1stop" ; e1_stop pin on the mainboard
                M581 P1 T0 C0 S0 ; T0 = emergency stop on trigger
                M569 P5 S1 T5 R1 ; physical drive x goes forwards
                M569 P6 S1 T5 R1 ; physical drive y goes forwards
                M569 P7 S1 T5 R1 ; physical drive z goes forwards
                M569 P8 S1 T5 R1 ; physical drive U goes forwards
                M569 P3 S1 ; physical drive extruder goes forwards
                M584 X6 Y5 Z7:8 E3 ; set drive mapping
                M671 X-50:490 Y330:330 S5 ; x leadscrew position left to right from o,o on y axis , S5 means can adjust up to 5 mm
                M350 X16 Y16 Z16 E16 I1 ; configure micro stepping with interpolation
                M92 X200.5 Y200.5 Z800.00 E93 ; set steps per mm
                ; FEEDRATE CONVERSIONS
                ; 1.6mm/s = F100
                ; 10mm/s = F600
                ; 16mm/s = F1000
                ; 20mm/s = F1200
                ; 35mm/s = F2100
                ; 50mm/s = F3000
                ; 70mm/s = F4200
                ; 100mm/s = F6000
                ; 120mm/s = F7200
                ; 133mm/s = F8000
                ; 160mm/s = F10000
                ; 250mm/s = F15000
                M566 X1200 Y1200 Z1200 E3000 ; jerk settings testing
                ;M566 X250.00 Y250.00 Z5.00 E120.00 ; set maximum instantaneous speed changes (mm/min) (original jerk settings)
                M203 X8000.00 Y8000.00 Z1000.00 E4000.00 ; set maximum speeds (mm/min)
                M201 X200.00 Y200.00 Z15.00 E400.00 ; set accelerations (mm/s^2)
                M906 X300 Y300 Z300 E1800 I30 ; set motor currents (mA)
                M84 S30 ; Set idle timeout
                M208 X440 Y528 Z895 S0 ; set axis maxima
                M574 X1 S1 P"xstop" ; configure active-low endstop for high end on X via pin xstop
                M574 Y2 S1 P"ystop" ; configure active-low endstop for high end on Y via pin ystop
                M574 Z1 S1 P"zstop+e0stop" ; configure active-high endstops for low end on Z via pins zstop and e0stop
                M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouch
                M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
                G31 P500 X-.04 Y-26.5 Z3.44 ; set Z probe trigger value, offset and trigger height ( the higher the number the smaller the spacing )
                ;uncomment one probe grid you want below
                M557 X20:430 S205 Y80:535 S212.5 ; define mesh grid With 9 points mapped
                ;M557 X20:430 S102.5 Y80:535 S106.25 ; define mesh grid With 25 points mapped
                M307 H0 A138.4 C562.2 D0.8 S1.00 V120.0 B0 ; disable bang-bang mode for Bed and set PWM limit
                M307 H1 A385.4 C119.0 D3.5 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit
                M950 F0 C"fan0" Q500 ; create fan0 on pin fan0 and set its frequency
                M106 P0 C"part/bridging fan" P1 S0 H-1 ; set fan0 "H-1 disables thermostatic mode" or H1 enables. ("S" parameter turns that fan on or off S0 or S1) (T45 is fan on at 45 degrees)
                M950 F1 C"fan1" Q500 ; create (Tool fan 1) on pin fan1 and set its frequency
                M106 P1 C"Hot end fan" S0 H1 T45 ; set (Tool fan 1) value. Thermostatic control is turned off
                M950 F2 C"e1heat" Q20000 ; create fan on pin e1heat and set its frequency ( connected to Solid State relay )
                M106 P2 C"Neopixels ON/OFF" S1 H-1 ;set fan 2 name and value. Thermostatic control is turned off
                M950 F3 C"fan2" Q20000 ; create fan2 on pin fan0 and set its frequency ( connected to Solid State relay )
                M106 P3 C"Relay 2 ON/OFF" S0 H-1
                M563 P0 S"Flexion" D0 H1 F0 ; define tool 0
                M501
                yes you are correct, the pc will not connect without a restart.
                but tablet and cell will , in both local wifi and or cellular only..connection lost long print.png
                  I don't think this is a Duet problem. It sounds like a problem with your PC/browser.
                  • tracarundefined
                    tracar
                    kinda what i was thinking, after everything else can just not the pc...
                    did you notice the heaters did that little thing off the scale ?
                      The heater graph is pretty weird. It could be interference on your thermistor wiring, or a bad connection. Double check your wiring.
                      For the browser, when it's not able to disconnect can you open up the browser dev console? Assuming it's chrome?
                      • tracarundefined
                        tracar
                        @Phaedrux said in Connection issue on long prints.:
                        that is the only time the heater did that,, directly after m112, while it was sitting there with the trying to reconnect popup. and as you can see i entered m112 twice,,, just as the heat graph shows, then the time where it dropped off in temp as i hit the reconnect button,,,
                          Could just be a display issue then, if it's never happened outside of that.
                          tracarundefined 1 Reply Last reply Reply Quote 0
                          • tracarundefined
                            tracar @Phaedrux
                            @Phaedrux i will try to recreate the situation after the print is done, , if it spikes i can verify with a thermal probe too.... post my findings later 🙂
