    DuetPi Duet Control Server error
    • benkitesurfsundefined
      benkitesurfs
      I am trying to set up an SBC for my board. I downloaded (from the Duet3d webpage: https://duet3d.dozuki.com/Wiki/SBC_Setup_for_Duet_3) and installed DuetPi Lite. I got the pi up and running (WPA_SUPPLICANT and .ssh). If I try to start Duet Control Server, I get this error:
      pi@duet3:~ $ sudo systemctl start duetcontrolserver
      Job for duetcontrolserver.service failed because the service did not take the steps required by its unit configuration.
      See "systemctl status duetcontrolserver.service" and "journalctl -xe" for details.
      When I attempt to update/upgrade I get errors (see screen shot).
      This is my second attempt. I downloaded a brand new image and wiped my sd card, it didn't make a difference.
        benkitesurfs
        The SBC is a Raspberry Pi 3 Model B Rev 1.2
          Can you give the non-lite version a try?
          benkitesurfsundefined 1 Reply Last reply Reply Quote 0
            benkitesurfs @Phaedrux
            @Phaedrux sure, I'll give that a try.
            I'm also going to try installing Raspberry Pi OS and then adding everything from there - someone suggested that on the discord server:
            https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Raspbian_Setup_Guide
              benkitesurfs
              I've been communicating with @gloomyandy @PCR and @jay_s_uk on the discord server since I'm using an SKR 1.4 Turbo
              They have been patiently working with me until I finally got it working tonight. It was either a hardware problem (incorrect connection of jumper cables from the Pi to the board) or the wrong firmware.bin problem.
              These guys are not only top notch for having ported the Duet firmware over to the LPC boards, but they really have donated a significant amount of their time to supporting the end users, being patient with those of us who are a lot less knowledgeable than them.
