    What's the correct way to send gcode to SBC
    Duet Web Control
    514
    • stuartofmtundefined
      stuartofmt
      Hi -
      I'm working on a project (DuetLapse3.py) and trying to get it working with SBC (which I do not have but others are testing).
      Specifically - I am having problems sending gcodes and it may simply be that the wrong method / syntax is being used.
      with a NON SBC (Duet2Wifi) the following python code (where command is a string with the gcode command) works fine (as expected):
      URL=('http://'+duet+'/rr_gcode?gcode='+command)
              r = requests.get(URL, timeout=5)
      on SBC I've tried three approaches: this one returns http code 200 - but apparently does nothing at the Duet end
      URL=('http://'+duet+'/machine/status?gcode='+command)
      this (using post) gives a 405 Method not allowed error:
      URL=('http://'+duet+'/machine/status')
             r = requests.post(URL, data=command)
      and this gives a 404 (not found) error:
      Any and all help appreciated.
        jay_s_uk @stuartofmt
        @stuartofmt have you seen this?
        Might help
        https://github.com/Duet3D/DuetSoftwareFramework#rest-api
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
          stuartofmt @jay_s_uk
          @jay_s_uk
          No - and thanks! Seems that the correct form is
                  URL=('http://'+duet+'/machine/code')
          i.e. /machine/code (as opposed to machine/status) in the post command. Definitely looks like my brain seeing something different than my eyes ....
          I'll submit a revised test to the "testers" 🙂
            stuartofmt
            Folks - we are still experiencing problems with this and need some help.
            The issue is that we cannot seem to send Gcode commands to SBC Duet. Other commands (like getting status) work fine. So the ip address is correct (variable duet in the code below).
            Here is the relevant python3 code. For testing command = 'M117 Test of SBC':
                    URL=('http://'+duet+'/machine/code/')
                    logger.info('URL was: '+r.url)
                if (r.ok):
                   return
                logger.info('sendDuetGCode failed with code: '+str(r.status_code)+'and reason: '+str(r.reason))
                return
            This returns no http error i.e. from an http perspective the post works. This has also been tried with /machine/code (i.e. no trailing /). Same results.
            DWC is being used to monitor for the correct resonse. No message is ever displayed in DWC to the M117 command.
            on a non SBC the following works correctly.
            Help ! 🙂
              stuartofmt
              This is now resolved. It seems that DWS endpoints are not completely consistent.
              Sending a gcode of 'M117 Test of SBC' works in one situation bit not the other.
              Sending 'M117 "Test of SBC"' works in both situations.
              PCRundefined 1 Reply Last reply Reply Quote 0
              • PCRundefined
                PCR @stuartofmt
                Something for @chrishamm ?
                  stuartofmt
                  @chrishamm
                  FWIW (and I should have known better) - I prefer the stricter approach with the string being quoted. Exactly why I did not do that in the test ..... having said that we would not have discovered this discrepancy.
                  I note that the gcode documentation for M117 here:
                  https://duet3d.dozuki.com/Wiki/Gcode
                  shows both forms as examples.
                  • chrishammundefined
                    chrishamm administrators
                    @PCR @stuartofmt I can confirm this bug and I've got a fix ready. Nevertheless I agree it's cleaner to quote strings everywhere.
                    Duet software engineer
