    Different movement type
    • taconiteundefined
      taconite
      Hello guys,
      in robotics you can choose different movement types. When you want to move from X0 Y0 to X75 Y100 there are different options. Option 1 is where the target (75 for X and 100 for Y) is reached in the same time so you are moving diaganoly. Option 2 is where the speed for X is not reduced so it is reaching the target first. e.g. for Z-hopping and Retract or a lot of other applications that would be very handy.
      I know there is more important stuff on the wishlist for FW but just out of curiosity what do you guys think?
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • PCRundefined
        PCR
        Would this be Not something which the slicer should handle?
        • fcwiltundefined
          fcwilt
          Slicers use different strategies to achieve their desired result.
          If optional movements like that were possible the slicers would have to know the nature of the movement and adjust for it.
          And if the slicer adjusts for it the actual movement would be what the slicer wanted - not what the option specified.
