    Dual markforged kinematics
    2.1k
    • buttonundefined
      button
      Hi!
      I'm designing upgrade for my cartesian printer. First i want to do only simple IDEX upgrade, but I have place to rebuild the printer for dual markforged kinematics.
      Somebody did the same way like i did:
      Do you think I'll have any issue to run it on reprap firmware?
      I have 2 Y motors, connected with shift to make them more powerfull, but we can treat them like one motor
      Cobaltundefined 1 Reply Last reply Reply Quote 0
        Yes, RRF supports that kinematics.
        buttonundefined 1 Reply Last reply Reply Quote 0
        • buttonundefined
          button @dc42
          @dc42 I know that RRF support markforged kinematics, but IDEX in this case wouldnt be a problem?
          • RootCNCundefined
            RootCNC
            I'm currently implementing the same kinematics, you might find this thread interesting:
            https://forum.duet3d.com/topic/7796/haq-xy
            I'm waiting for my Duet 3 to turn up from Ooznest then I'll start the process of configuring the software. I've not used Reprap firmware so it'll be a learning curve. I'll post my configuration once its done - I'll happily accept any help going to get this up and running!
            • Cobaltundefined
              Cobalt @button
              @button hi. what is the M669 G Code for this kinematics. thx
              Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @Cobalt
                @cobalt Have you seen the examples here: https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m669-set-kinematics-type-and-kinematics-parameters
                  dc42 administrators @Cobalt
                  @cobalt there isn't a M669 K code that describes this kinematics, so you will need to specify Cartesian or Mark Forged kinematics using the K parameter, then modify the matrix using the X Y Z and U parameters.
                  • RogerPodacterundefined RogerPodacter referenced this topic
                  • droftartsundefined droftarts referenced this topic
