    RRF3
    Firmware installation
    728
    • Dugeeundefined
      Dugee
      Hi all.
      I put my printer away last year after getting everything working, didn't cope well with lockdown, but started rebuilding a guitar instead. That's finished, so back to the printer
      My question, I have the final version of RRF2 installed. Will I get any benefit by migrating to RRF3? It's just a mini delta.
      Vetiundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @Dugee
        @Dugee
        all new development will happen on rrf3.
        if your printer is working at the moment, there is no immediate need to update.
        but if you have the time, i would suggest you do it.
        • o_lampeundefined
          o_lampe @Dugee
          @Dugee said in RRF3:
          Hi all.
          Hi @Dugee
          I'm in almost the same position as you. 👍
          It's been 3 years no_printing and I restored vintage saxofones until I ran out of materials...
          I hope to find a summary, of what's new in RRF3.x
          The efford to re-invent my config.g must be worth it...
          Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti @o_lampe
            @o_lampe said in RRF3:
            its not that much to do.
            see
            https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
            • Dugeeundefined
              Dugee
              we should start a music channel in here to compare lockdown, non, 3d projects!@o_lampe
              • Vetiundefined
                Veti @Dugee
                but only with 3d printed instruments 🙂
                Dugeeundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                • Dugeeundefined
                  Dugee @Veti
                  @Veti Well, i priced the components for creating a d-bot last night and it seems I can get everything I need for about £200 and then I would definitely migrate to rrf3.
                  And then I could probably make one!
                    dc42 administrators @o_lampe
                    The main advantages are more flexible pin allocation, and conditions and loops in GCode.
                    Dugeeundefined 1 Reply Last reply Reply Quote 0
                    • Dugeeundefined
                      Dugee @dc42
                      @dc42 is the delta calibration algorithm the same, 6 factor still being the most appropriate?
                      Vetiundefined 1 Reply Last reply Reply Quote 0
                      • o_lampeundefined
                        o_lampe @Veti
                        @Veti said in RRF3:
                        I've printed an American Native flute and I also have made a Didgeridoo with my own mouthpiece, so...
                        Challenge accepted
                        @dc42 said in RRF3:
                        I remember we've discussed the benefit of conditions back in RepRap-forum, but I don't remember, what I wanted to do with it.
                        In general, for a single nozzle 3D printer, there's no need to update?
                        I have another DuetWiFi and a Maestro in spare, so I could give it a try.
                        • Vetiundefined
                          Veti @Dugee
                          the "best" is the one you get the best results with.
                          what the factors calibration do has not been change from 2 to 3.
                          see what they do here
                          https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Setting_up_the_bed_g_file
                          • Vetiundefined
                            Veti @o_lampe
                            i have printed a ocarina from zelda for a friend
                            • o_lampeundefined
                              o_lampe @Dugee
                              That sounds like a pi$$ing contest, nooo I pass
                              (and I would win hands down, no doubt)🤣
                              • Dugeeundefined
                                Dugee @Veti
                                @Veti true, I tended to use 6 until I got a stable calibration then reduced for actual printing.
                                I
                                With RRF3 is it possible to create something that will do the probing for the bed.g probe trigger heights and automatically populate the file or is it still a manual process? that was the biggest PITA that I had, and with the printer sitting so long I will need to basically start from scratch to calibrate.
                                I couldn't see anything obvious other then this still being referenced in the Delta Calibration steps. I didn't go through the full differences to RRF3, and what the conditional processes can do, just looked the process for migration, so apologies if this is a question answered in the dozuki.
                                • Dugeeundefined
                                  Dugee @o_lampe
                                  @o_lampe mine was just lutherie type stuff, woodwork, painting, electrics, so if you we get to 3d instruments, you've already won.
                                  • Vetiundefined
                                    Veti @Dugee
                                    the configurator will generate a bed.g for you
                                    https://configtool.reprapfirmware.org/Start
                                    • Dugeeundefined
                                      Dugee @Veti
                                      @Veti yes, it's just that previously to determine the trigger heights ( 3 underbed sensors for hot end probing) it felt like it took an age to probe, get the results, put them through a spreadsheet to get the differential to origin, then input into the bed.g file for the probe points. I had created a file to probe all of the calibration points 5(?) times to then average the trigger height in a spreadsheet which I then put in to bed.g manually.
                                      When I was looking before at the conditional g-code I remember some talk of being able to use <average> but cant find anything in the forum, Probably not using the correct search terms.
                                      I think the configurator is a great tool, but I havent been in to it for a long time. I'll have a look to see what has changed,
                                      • o_lampeundefined
                                        o_lampe @Dugee
                                        @Dugee
                                        yup, I gave up dealing with underbed (piezo) sensors.
                                        On my XXL-Delta I have Davids smart effector which gave me the best results so far.
                                        • o_lampeundefined
                                          o_lampe @Dugee
                                          There's a printable Ukulele on thingiverse, just saying....
                                            jay_s_uk
                                            @Dugee
                                            https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
