    RRF3
    Firmware installation
    792
    • o_lampeundefined
      o_lampe @Dugee
      @Dugee said in RRF3:
      Hi all.
      I put my printer away last year after getting everything working, didn't cope well with lockdown, but started rebuilding a guitar instead. That's finished, so back to the printer
      My question, I have the final version of RRF2 installed. Will I get any benefit by migrating to RRF3? It's just a mini delta.
      Hi @Dugee
      I'm in almost the same position as you. 👍
      It's been 3 years no_printing and I restored vintage saxofones until I ran out of materials...
      I hope to find a summary, of what's new in RRF3.x
      The efford to re-invent my config.g must be worth it...
      Vetiundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @o_lampe
        @o_lampe said in RRF3:
        its not that much to do.
        see
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files
        • Dugeeundefined
          Dugee
          we should start a music channel in here to compare lockdown, non, 3d projects!@o_lampe
          Vetiundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti @Dugee
            but only with 3d printed instruments 🙂
            Dugeeundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
            • Dugeeundefined
              Dugee @Veti
              @Veti Well, i priced the components for creating a d-bot last night and it seems I can get everything I need for about £200 and then I would definitely migrate to rrf3.
              And then I could probably make one!
                dc42 administrators @o_lampe
                The main advantages are more flexible pin allocation, and conditions and loops in GCode.
                Dugeeundefined 1 Reply Last reply Reply Quote 0
                • Dugeeundefined
                  Dugee @dc42
                  @dc42 is the delta calibration algorithm the same, 6 factor still being the most appropriate?
                  • o_lampeundefined
                    o_lampe @Veti
                    @Veti said in RRF3:
                    I've printed an American Native flute and I also have made a Didgeridoo with my own mouthpiece, so...
                    Challenge accepted
                    @dc42 said in RRF3:
                    I remember we've discussed the benefit of conditions back in RepRap-forum, but I don't remember, what I wanted to do with it.
                    In general, for a single nozzle 3D printer, there's no need to update?
                    I have another DuetWiFi and a Maestro in spare, so I could give it a try.
                    • Vetiundefined
                      Veti @Dugee
                      the "best" is the one you get the best results with.
                      what the factors calibration do has not been change from 2 to 3.
                      see what they do here
                      https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Setting_up_the_bed_g_file
                      • Vetiundefined
                        Veti @o_lampe
                        i have printed a ocarina from zelda for a friend
                        • o_lampeundefined
                          o_lampe @Dugee
                          That sounds like a pi$$ing contest, nooo I pass
                          (and I would win hands down, no doubt)🤣
                          • Dugeeundefined
                            Dugee @Veti
                            @Veti true, I tended to use 6 until I got a stable calibration then reduced for actual printing.
                            I
                            With RRF3 is it possible to create something that will do the probing for the bed.g probe trigger heights and automatically populate the file or is it still a manual process? that was the biggest PITA that I had, and with the printer sitting so long I will need to basically start from scratch to calibrate.
                            I couldn't see anything obvious other then this still being referenced in the Delta Calibration steps. I didn't go through the full differences to RRF3, and what the conditional processes can do, just looked the process for migration, so apologies if this is a question answered in the dozuki.
                            • Dugeeundefined
                              Dugee @o_lampe
                              @o_lampe mine was just lutherie type stuff, woodwork, painting, electrics, so if you we get to 3d instruments, you've already won.
                              • Vetiundefined
                                Veti @Dugee
                                the configurator will generate a bed.g for you
                                https://configtool.reprapfirmware.org/Start
                                • Dugeeundefined
                                  Dugee @Veti
                                  @Veti yes, it's just that previously to determine the trigger heights ( 3 underbed sensors for hot end probing) it felt like it took an age to probe, get the results, put them through a spreadsheet to get the differential to origin, then input into the bed.g file for the probe points. I had created a file to probe all of the calibration points 5(?) times to then average the trigger height in a spreadsheet which I then put in to bed.g manually.
                                  When I was looking before at the conditional g-code I remember some talk of being able to use <average> but cant find anything in the forum, Probably not using the correct search terms.
                                  I think the configurator is a great tool, but I havent been in to it for a long time. I'll have a look to see what has changed,
                                  • o_lampeundefined
                                    o_lampe @Dugee
                                    @Dugee
                                    yup, I gave up dealing with underbed (piezo) sensors.
                                    On my XXL-Delta I have Davids smart effector which gave me the best results so far.
                                    • o_lampeundefined
                                      o_lampe @Dugee
                                      There's a printable Ukulele on thingiverse, just saying....
                                        jay_s_uk
                                        @Dugee
                                        https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
                                        • Dugeeundefined
                                          Dugee @o_lampe
                                          @o_lampe I looked at that, with the amount of work involved in putting a smart effector into my machine it isnt worth it.
                                          It's only a Mini, and one of the reasons for getting the machine back out is to print the pieces for a D bot, as I think that will be more useful for what I want to print.
                                          I can just print everything I need on the mini, it's tight but it just makes it.
                                          • Dugeeundefined
                                            Dugee @jay_s_uk
                                            @jay_s_uk I saw that one, but it doesn't automate the trigger heights, but the calibration process.
                                            I did see a thread that included automating the trigger heights,
                                            https://forum.duet3d.com/topic/14280/invitation-to-share-your-conditional-gcode-scripts
                                            but havent yet found any follow up.
                                            I also found this one, which I'll have to read through first!
                                            https://forum.duet3d.com/topic/17872/automatic-bed-leveling-with-conditional-gcode-iterations/40
