    Stall detection on Duet 3 Mini
    521
      We've discovered a bug in how stall detection sensitivity is set on the Duet 3 Mini, due to a change in how the TMC2209 stall sensitivity is programmed compared to other drivers. This is being fixed in the forthcoming 3.3 release. Meanwhile it may be helpful to know that in firmware 3.2, this is how I expect the M915 S parameter to behave on the Duet 3 Mini:
      Most sensitive ....... least sensitive
      -1 -2 -3 ... -64 63 62 ... 2 1 0
      Whereas on TMC2260 drivers (Duet 2) and TMC5160 drivers (Duet 3 MB6HC) it is:
      -64 -63 ... -2 -1 0 1 2 ... 63
      Additionally, the TMC2209 is capable of some other sensitivity settings that cannot currently be selected using M915.
      Thanks to Andy Shaw for pointing out this issue.
      • Veti
        Veti last edited by
        that explains why i could not get stall detection to work when i tested with -64
        • mendenmh
          mendenmh last edited by
          Or, to make it more sensible, they have changed from a signed representation on [-64,63] with 63 being least sensitive to an unsigned representation on [0,127] with zero being least sensitive and 127 being most sensitive, with 7-bit math.
          • gloomyandy
            gloomyandy last edited by
            Actually on TMC2209 they have changed the range as well... it runs 0..255 with 255 being most sensitive.
              I've put a new unofficial 3.3beta build of Duet3MiniFirmware.uf2 at https://www.dropbox.com/sh/wme9k0z86sytg33/AAAT6wrHp2eeJHK-dYoW1Um4a?dl=0. This version accepts M915 S parameters between -128 (most sensitive) and +127 (least sensitive) for TMC2209 drivers.
              fcwilt 1 Reply Last reply Reply Quote 1
              • fcwilt
                fcwilt @dc42 last edited by
                @dc42 said in Stall detection on Duet 3 Mini:
                Hmm...
                So what is wrong with 0 to 255?
                Thanks.
                  dc42 administrators @fcwilt last edited by dc42
                  @fcwilt said in Stall detection on Duet 3 Mini:
                  1. If we change M915 to always accept 0 .. 255, that will break existing Duet 2 and 3 user configurations. In particular, stall homing will fail, which may cause damage to user's machines. Not all users read the upgrade notes.
                  2. If we make M915 accept values of -64 .. +63 for Duet 2 and Duet 3 MB6HC, and 255 .. 0 for Duet 3 Mini and tool boards, that will be confusing to users, especially in those systems that have both TMC5160 and TMC2209 drivers.
                  I may introduce an additional parameter that accepts 0 .. 255 and when it is present is used instead of the S parameter. We would have to map it back to +63 .. -64 when used with TMC2660 or TMC5160 drivers. We could then deprecate the S parameter.
                  • Veti
                    Veti last edited by
                    i kind of like 0 beeing the default in the middle.
                    because you can make it less - or more + sensitive.
                    • fcwilt
                      1. If we change M915 to always accept 1 .. 255, that will break existing Duet 2 and 3 user configurations. In particular, stall homing will fail, which may cause damage to user's machines. Not all users read the upgrade notes.
                      2. If we make M915 accept values of -64 .. +63 for Duet 2 and Duet 3 MB6HC, and 255 .. 0 for Duet 3 Mini and tool boards, that will be confusing to users, especially in those esystems that have both TMC5160 and TMC2209 drivers.
                      Thanks for the edification - that all makes perfect sense.
                      • Sotidii
                        Sotidii last edited by
                        This post is deleted!
                        • carcamerarig
                          carcamerarig last edited by
                          @dc42 What did you end up doing here? For clarity does the Gcode dictionary reflect the changes you made as the thread went cold and no definitive answer?
                          For my 0.9 LDO motors I have M915 X S-50 F0 H400 R0 on the mini, it homes but im having a hell of a game with motors banging, crashing, thumping however you want to call it. I had some help to try to keep spreadcycle active except for homing but still the bang / layer shift continues.
                          when I purchased the board @T3P3Tony said the 2209's ran nicely with 0.9's (bit off topic here) but I could seriously do with some help, im on the verge of scrapping it.
