Duet 3 no power coming to bed.
@eddygara But that is effectively the same connection.
@eddygara Electrically it's the same thing.
If you have a high-power bed, then run a second heavy wire all the way from the PSU.
Sorry for the confusion.
You're getting it!
@alankilian Ok cool sorry yall, not savy like this, The Duet Wifi was a simpler system to configure, and there was a lot more documentation on wiring, etc.
@eddygara Your experience will help build even BETTER documentation for the next person trying this out.
@eddygara In general - it is all about wire size and required power. If Your bed require high power separate wire is better option than connectin everything with just one.
If You know, that the wire connected to power in can handle all the current, then just make the jumpers between board terminals.
But if You have average power bed ~200W it would take about 16.6A to run it, and wires on photo look like they can be a source of problems I would not go below 2.5mm^2 for such heatbed.
