    1LC and BLTouch
    778
    • matt3oundefined
      matt3o @Stephen6309
      @Stephen6309 okay, let's just say that those connectors are not made for crimps
      BlueDustundefined 1 Reply Last reply Reply Quote 0
      • BlueDustundefined
        BlueDust @Stephen6309
        @Stephen6309 @matt3o
        Once I have this all permanently wired, I planned to cut them down to size so they fit in cleanly. Will have to squeeze the white barrel to flatten it a bit... And yes, they are all stranded wires. Would prefer to keep them neat, and not worry about a runaway wire touching another terminal.
        Fun, that 3 letter word with "u" in the middle.
        matt3oundefined 1 Reply Last reply Reply Quote 0
        • matt3oundefined
          matt3o @BlueDust
          @BlueDust you can always put some solder on the tips (ONLY on low currents like those)
          BlueDustundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • BlueDustundefined
            BlueDust @matt3o
            @matt3o
            There is obviously not a lot of room between the screw terminals to fit them properly.
            • BlueDustundefined
              BlueDust @matt3o
              @matt3o
              That is an idea... Thanks. Will consider it when it comes time to re-wire and make this a permanent setup.
                Phaedrux Moderator @matt3o
                @matt3o said in 1LC and BLTouch:
                I'd say that's not a good idea. The solder tin doesn't compress at all like the wire strands would, so you might be get very good pressure. Back to same problem as using the bootlace ferrules.
                Give the bare wires a twist with your fingers to keep them tidy and then screw them down.
                • Stephen6309undefined
                  Stephen6309
                  Another way to connect to those screw terminal is to insert a 0.1 pin header in there and use the approtiate connector to connect the header you installed. Don't use this for the hotend.
                  • A Former User?
                    A Former User
                    get small enough ferrules and it'll be fine. (optionally fold the wire to make up the lacking cross section, then trim the ferrule to length and remove the plastic insulation)
