    What setting/s cause this?
    111
    • Blacksheep99
      Blacksheep99 last edited by
      I'm tuning my printer. Things are going okay but I get this stretched effect at the start of a layer. It's visible on the surface of a part. Additional walls may hide it I guess?
      Is this linked to acceleration settings, retraction & could pressure advance help?
      Thanks.
      • Veti
        Veti last edited by
        yes that can be caused by retraction.
        it could be to much retraction. or the filament slipping.
        it could also be a wrong thermistor setting.
        post your config.g
        Blacksheep99 1 Reply Last reply Reply Quote 0
        • Blacksheep99
          Blacksheep99 @Veti last edited by
          @Veti
          ; Configuration file for Duet Maestro (firmware version 3)
          ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sat Jan 09 2021 18:02:08 GMT+0000 (Greenwich Mean Time)
          G90                                             ; send absolute coordinates...
          M83                                             ; ...but relative extruder moves
          M550 P"ST3Di280 Duet"                           ; set printer name
          M552 P192.168.0.60 S1                                ; enable network and acquire dynamic address via DHCP
          M586 P0 S1                                      ; enable HTTP
          M586 P1 S0                                      ; disable FTP
          M586 P2 S0                                      ; disable Telnet
          M569 P0 S1                                      ; physical drive 0 goes forwards
          M569 P1 S0                                      ; physical drive 1 goes backwards
          M569 P2 S1                                      ; physical drive 2 goes forwards
          M569 P3 S0                                      ; physical drive 3 goes backwards
          M569 P4 S1                                      ; physical drive 4 goes forwards
          M584 X0 Y1 Z2 E3:4                              ; set drive mapping
          M350 X16 Y16 Z16 E16:16 I1                      ; configure microstepping with interpolation
          M92 X91.13 Y106.84 Z1242.228  E104.76:104.76     ; set steps per mm
          M566 X1600.00 Y1600.00 Z60.00 E120.00:120.00      ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00:250.00      ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E600:600 I30                ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                         ; Set idle timeout
          M208 X-140 Y-75 Z0 S1                           ; set axis minima
          M208 X165 Y75 Z150 S0                          ; set axis maxima
          M574 X1 S1 P"xstop"                             ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                             ; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S2 										; configure Z-probe endstop for low end on Z
          ;M574 Z1 S1 									; Set endstops controlled by probe
          M950 S0 C"^zprobe.mod" 							; create servo pin 0 for BLTouch
          M558 P8 C"^zprobe.in" H3 F900 T6000 			; Set Z probe type to switch and the dive height + speeds
          G31 P50 X-43 Y5 Z1.816 							;Set Z probe trigger value, offset and trigger height 1.81
          M557 X-120:120 Y-65:75 S15                       ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" A"Bed Heater" T100000 B3950  ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 S1.00                                ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                         ; map heated bed to heater 0
          M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" A"Left Extruder" T100000 B3950   ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                    ; set temperature limit for heater 1 to 280C
          M308 S2 P"e1temp" Y"thermistor" A"Right Extruder" T100000 B3950   ; configure sensor 2 as thermistor on pin e1temp
          M950 H2 C"e1heat" T2                            ; create nozzle heater output on e1heat and map it to sensor 2
          M307 H2 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
          M143 H2 S280                                    ; set temperature limit for heater 2 to 280C
          M950 F0 C"fan0" Q500                            ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                            ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1:2 T45                             ; set fan 1 value. Thermostatic control is turned on
          M563 P0 S"Left" D0 H1 F0                       ; define tool 0
          G10 P0 X14.275 Y-0.25 Z0                                 ; set tool 0 axis offsets
          G10 P0 R0 S0                                    ; set initial tool 0 active and standby temperatures to 0C
          M563 P1 S"Right" D1 H2 F0                        ; define tool 1
          G10 P1 X-14.275 Y0 Z0                                 ; set tool 1 axis offsets
          G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
          M575 P1 S1 B57600								;PanelDue interface
          M912 P0 S1
          M501
          M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          • Veti
            Veti last edited by
            print a temperature tower to see if your thermistor settings is correct.
            • Blacksheep99
              Okay, Will do
              • Blacksheep99
                None of them look great, hotter the better though it seems although I cannot be sure the actual temp correlates with the temp in DWC.
                FYI the PLA was only opened at the weekend although I've had it sat around for a while. On my other printer 215 is about the sweet spot for this PLA.
                • Veti
                  Veti last edited by
                  @Blacksheep99 said in What setting/s cause this?:
                  if your thermistor setting is incorrect then 215 will not be real 215
                  it can easily be off by 20-40c
                  • Blacksheep99
                    @Veti said in What setting/s cause this?:
                    The other printer is a stock Polaroid 250s so I am assuming it’s calibrated somewhat? That’s my comparison. Point taken though
                    • Blacksheep99
                      Benchy using my current settings, sliced in Cura 4.8.
                      0.2layers. Printed at '235' which is too hot for PLA.
                      • Veti
                        Veti last edited by
                        can you print this
                        https://www.thingiverse.com/thing:2080224
                        and try and calibrate your retraction with it.
                        • Blacksheep99
                          @Veti
                          I think 1.6mm retraction 50mm/s looks best.
                          0, 0.5, 1 retraction
                          1.5, 1.6, 1.75, 2
                          I think 1.5mm is close but has some slight surface blobs.
                          I previously had it set at 2.5mm.
                          Note: Pressure advance disabled in config.g for these prints.
                          • Veti
                            Veti last edited by
                            ok see if that improves the benchy. nearly 1cm difference for retraction is a lot.
