    Toolboard 1LC V1.0 blew/shorted
    toolboard short ciruit short to ground
    • BeosDocundefined
      BeosDoc
      My toolboard v1.0 shorted out and took out the fuse on the tool distribution board. I’m running at 32V. I had the hot end heated up, and the printer wasn’t doing anything else, for about 10 minutes and I heard a pop. The board has been working fine for about 20 hours or so.
      The toolboard has 0 ohm resistance between Vin and GND, meaning there’s a short somewhere. It looks like one of the capacitors is shorted because both sides show 0 ohms to ground on both sides. Capacitors C4, C5 and C6 that are in parallel. None of them look burnt.
      • JayJayundefined
        JayJay
        A simple "owww" test will tell you which component is shorted.
        Remove the board and connect it to a regulated PSU and crank in a low amount of voltage, place your finger on components until you go "owww" you found the faulty component and can replace it.
          Photo of the wiring and board?
            Please contact your vendor and initiate a warranty exchange. Include a link to this thread as authorization.
            BeosDocundefined 1 Reply Last reply Reply Quote 0
            • BeosDocundefined
              BeosDoc @Phaedrux
              @Phaedrux
              Thank you
