    Duet 2 wifi and Duex 5
    51
    • wdenker
      wdenker last edited by
      I have a duet wifi that was reporting high temps on driver 3. When I disconnected the duex 5 while powered down those errors went away. But then after about another minute the driver 3 started to smoke and looks a bit crispy. I was told I needed to come here to make sure we could warranty it. I have a second set that when powered up none of the drives work I would like to warranty as well. I also know it wasn't the wiring as I put in another set on each printer and they worked flawlessly. Same firmware and configs that I have been using on all of my printers.
        Can you post the results of M122 from each Duet?
        Photos of each?
        When and where were they purchased?
        wdenker 6 Replies Last reply Reply Quote 0
        • wdenker
          wdenker @Phaedrux last edited by
          @Phaedrux it will be a bit before I have time to hook them back up. The one set was about 6 months ago the other set this month from filastruder. Out of 30 or more sets I have only had a few failures like this.
          wdenker 1 Reply Last reply Reply Quote 0
          • wdenker
            wdenker @wdenker last edited by
            @Phaedrux The older of the two won't even connect to usb at all at this point. The newest gives the following.
            M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
            Board ID: 0JD0M-9P6M2-NW4SN-6J9D4-3S46T-KVS3L
            Used output buffers: 3 of 24 (14 max)
            Static ram: 25712
            Dynamic ram: 92880 of which 120 recycled
            Exception stack ram used: 304
            Never used ram: 12056
            Tasks: NETWORK(ready,676) HEAT(blocked,912) MAIN(running,3732) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:18:04 ago, cause: power up
            Last software reset at 2021-01-11 19:58, reason: User, spinning module GCodes, available RAM 10816 bytes (slot 3)
            Error status: 0
            Free file entries: 10
            MCU temperature: min 35.5, current 35.8, max 36.1
            Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
            Driver 0: ok, SG min/max not available
            Driver 1: ok, SG min/max not available
            Driver 2: ok, SG min/max not available
            Driver 3: ok, SG min/max not available
            Driver 4: ok, SG min/max not available
            Date/time: 2021-01-27 20:03:26
            Cache data hit count 4215967080
            Slowest loop: 5.10ms; fastest: 0.05ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
            === DDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 200.42ms; fastest: 0.07ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is running
              Failed messages: pending 0, notready 0, noresp 20
              WiFi firmware version 1.23
              WiFi MAC address 84:0d:8e:b2:f4:96
              WiFi Vcc 3.42, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 23000
              WiFi IP address 192.168.1.177
              WiFi signal strength -41dBm, reconnections 0, sleep mode modem
            • wdenker
              This post is deleted!
              • wdenker
                • wdenker
                  • wdenker
                    • wdenker
                      • wdenker
                          It's quite unusual to deal with a bulk warranty claim. For the sake of keeping things clear and accurate, would you please create a separate thread for each item?
                          Please include as much detail as possible for each one. What hardware exactly, what the problem is, relevant photos, M122 or config.g, and most importantly where and when it was purchased.
                          Sorry for the inconvenience but I think this will help things progress the smoothest.
