    SBC Raspberry Pi Backup Configs
    • dbruce.ae05
      dbruce.ae05 last edited by
      Is there a documentation page that describes how the Raspberry Pi communicates with the Duet3?
      I would like to backup the configuration files using rsync on the Raspberry Pi to another computer on my network so I don't lose the configuration files. I'm making a lot of changes getting my CNC setup, and I'd like to have a history of changes.
        What specifically are you wanting to backup? the configuration? The virtual SD card can be found at /opt/dsf/sd
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Duet_Software_Framework_on_Raspberry_Pi
        • dbruce.ae05
          dbruce.ae05 last edited by dbruce.ae05
          Thanks @Phaedrux! that's just what I needed. I created a cronjob to run the following script every hour while I'm trying to get things running.
          now=`date +'%F_%H.%M.%S'`
          host_address="username@host"
          filename="[backup file pathway]/$now/"
          #echo $now
          #echo $host_address
          #echo $filename
          ssh $host_address mkdir -p $filename
          rsync -av /opt/dsf/sd/sys $host_address:$filename
          rsync -av /opt/dsf/sd/macros $host_address:$filename
          The script above requires automatic ssh login, a good link to set that up is here: http://www.linuxproblem.org/art_9.html
          Cron:
          # m h  dom mon dow   command
          0 * * * * bash /home/pi/Documents/backup-duet3.sh
