Duet 3 and connection issues.
Web control has insane lag and as you can see its not the wifi speed that is causing it.
Allso trying to set duets ip to static results in a crash and a compleate reset of the board is required to make it work again, what ever i do i cant get the ip to be static.
Any web trafic when the printter is running results in a disconect in web control
Connection established
28.1.2021 klo 16.36.29 Connection interrupted, attempting to reconnect...
HTTP request timed out
28.1.2021 klo 16.36.19 Failed to get file list
Directory 0:/macros not found
28.1.2021 klo 16.36.19 Connection established
28.1.2021 klo 16.36.19 Connection interrupted, attempting to reconnect...
28.1.2021 klo 16.36.00 Failed to get file list
28.1.2021 klo 16.36.00 Connection established
28.1.2021 klo 16.36.00 Connection interrupted, attempting to reconnect...
28.1.2021 klo 16.35.24 Failed to get file list
28.1.2021 klo 16.35.24 Connection established
28.1.2021 klo 16.35.24 Connection interrupted, attempting to reconnect...
HTTP request timed outThis all when typing this message.
I see you're having some issues, but we're missing some information to be able to help you.
Are you using the Duet 3 with a raspberry pi, or standalone?
Probably best to start with a standalone setup first.
Stand alone, the setup has been functioning fine for a year.
Please post the results of M122 and M98 P"config.g"
Post your config.g as well.The duet 3 is wired to your switch/router?
Are you able to set a DHCP reservation on the router for the Duet3?
M122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
Board ID: 08DJM-956L2-G43S4-6J1FL-3SJ6T-186QH
Used output buffers: 2 of 40 (23 max)
Static ram: 154604
Dynamic ram: 162784 of which 20 recycled
Exception stack ram used: 376
Never used ram: 75432
Tasks: NETWORK(ready,276) ETHERNET(blocked,404) HEAT(blocked,1112) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,196) MAIN(running,4512) IDLE(ready,76)
Owned mutexes:
Last reset 00:24:59 ago, cause: power up
Last software reset at 2021-01-29 22:57, reason: User, spinning module GCodes, available RAM 75264 bytes (slot 3)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 23.1, current 23.3, max 23.4
Supply voltage: min 23.6, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
Driver 0: standstill, reads 34723, writes 0 timeouts 0, SG min/max not available
Driver 1: standstill, reads 34723, writes 0 timeouts 0, SG min/max not available
Driver 2: standstill, reads 34722, writes 0 timeouts 0, SG min/max not available
Driver 3: standstill, reads 34723, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 34722, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 34722, writes 0 timeouts 0, SG min/max not available
Date/time: 2021-02-04 13:33:09
Slowest loop: 5.13ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 3.3ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 7, completed moves: 7, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Heater 0 is on, I-accum = 0.7
Heater 1 is on, I-accum = 0.6
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 5.77ms; fastest: 0.03ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 1 of 8- Ethernet -
State: active
Error counts: 0 0 0 0 0
Socket states: 5 2 2 2 2 2 0 2
=== CAN ===
Messages sent 29, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 1499565ms ago
RX/TX seq numbers: 0/1
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
- Ethernet -
M98 P"config.g"
HTTP is enabled on port 80
FTP is enabled on port 21
TELNET is enabled on port 23
Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 465C
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 10 2020 22:00:06 GMT+0300 (Itä-Euroopan kesäaika); General preferences
M550 P"Useless junk" ; set printer name; Network
M551 P"Sirsnip1337" ; set password
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0.0 S0 ; physical drive 0.0 goes backwards
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.2 S1 ; physical drive 0.2 goes forwards
M569 P0.3 S1 ; physical drive 0.3 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X15600.00 Y15600.00 Z180.00 E3600.00 ; set maximum speeds (mm/min)
M201 X2800.00 Y2800.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X1100 Y1100 Z1100 E1197 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S120 ; Set idle timeout; Axis Limits
M208 X210 Y200 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"io7.in" H5 F120 T3000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y41 Z3.0 ; set Z probe trigger value, offset and trigger height
M557 X15:210 Y15:200 S20 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T97700 B4619 C9.743561e-8 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
M143 H1 S285 ; set temperature limit for heater 1 to 285C
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out9" Q10 ; create fan 0 on pin out9 and set its frequency
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"Hotend/extruder" D0 H1 F0 ; define tool 0
T0 ; select first tool
@Snippy said in Duet 3 and connection issues.:
M586 P2 S1 ; enable TelnetAny modifications made in those result in an inoperable printter.
@Phaedrux
Yes its set to static in router.
When connected to the DWC, upload this zip file to the system tab. Don't extract it first. JUst upload the full zip.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
That will update the firmware to 3.2 and refresh the DWC files for 3.2 as well.
I see no errors in your config file
Never mind, I see you've started another thread and it looks like you've updated and solved your problem.
