Low cost, public domain, stepper analyzer - season 2.
Hi everybody,
Last year I posted here a DYI design of a stepper motor analyzer that was based on teensy 4.0 (600Mhz processor, at $20 a piece) and a 3.5 Nextion smart TFT(~$35).
Since then I worked on and off on a simpler and less expensive design and it works even better. This design uses a 3.5" 'dumb' TFT with a capacitive touch, and ~$3 'blackpill' STM32F401CE board from Ali Express.
The hardware design is trivial, with a blackpill module, two small current sensors and a EEPROM to save the settings, and it has a 40pin connector that plugs into the TFT screen. All the heavy lifting, including the signal processing, extraction of stepper measurements and user interface are done by the firmware.
Github repository and documentation are here https://github.com/zapta/simple_stepper_motor_analyzer and electrical schematic is here https://github.com/zapta/simple_stepper_motor_analyzer/blob/master/kicad/stepper_analyzer-sch.pdf .
I may be able to make a few available for cost, especially for developers that want to add functionality (C++, Platformio under VSCode, programming/debugging using stlink V2). Flashing of new boards can be done with DFU software over USB, no tools of dongles required).
If you want to build one, or ten, or a thousand and have questions, I will be happy to answer. The connectors BTW are duet2 compatible.
This is exactley what I need to test my diffrent steppers with the diffrent boards...
Unfortunatley my soldering skills and electronic DIY are not that good but would love to buy one if there is one for sale.
I will Order some pcbs and can Order some for Europe with all SMT components! Please upvote the Post If you want one!
Would supply the Board without Blackpill and Display!
Great Work!!!!!!
@PCR said in Low cost, public domain, stepper analyzer - season 2.:
Thanks PCR. Please let me know if you have any questions.
The three LEDS and their respective resistors are optional and I use them just for software development.
@zapta will do! btw will "sell" them for nonproft! shoukd be here in 1 week
@zapta this is very cool!
Nice! Still haven't gotten the pcbs for the first one but I have a small pile of screens and teensys lol. Maybe time to place a third order of boards..
@bearer said in Low cost, public domain, stepper analyzer - season 2.:
Yes, this one is much smoother. The LVGL software is is more solid than the Nexion approach, display is crispier, and it costs less, unless if you want to wait for a 2022 model with a RPI Pico .
BTW, an interesting application is to measure the consistency of homing. I connect the analyzer to a stepper, home once, reset the steps counter, and then home again a few times and watch the step count after each homing. It should stay zero. Works unless your the uses senseless homing which causes it to lose a few steps when the driver detects a stall.
Currently resolution is one full step but I think it's possible to compute also fractions of of full steps, from the ratio (coil1 current / coil 2 current).
Thanks!
Pcbs orderd! Enough i Hope!
The analyzer now can measure and show fractions of a full step in 1/100th of a step resolution.
The Allegro Microsystems datasheet such as this one (starting at page 16) https://www.allegromicro.com/-/media/files/datasheets/a5985-datasheet.ashx provide useful information about the relation between the current and the sub-step position.
The current patters are divided into electric cycles or 'electric rotations', each representing 4 full steps and the position of the stepper within that electric rotation can be done by feeding the two coil currents into the standard trigonometric function atan2(current1, current2). It ended up simpler than I expected.
I also updated the firmware and 4 steps diagram to reflect the new understanding that the centers of the full steps at the points where both coils have the exact same current (regardless of polarity, this happens at ~70% of peak current which is also the RMS current) and not when one is at its peak and the other at zero as I thought before.
I tested it with a Pololu stepper driver, incrementing a 1/8 of a step every 2 seconds and watching the display. Works like a charm.
I am really interested in buying some when it is available. As a mounting kit or fully assembled. Any price is cheap just by saving time with this amazing idea.
I'll keep an eye around here.
I am experimenting now with a new screen whose purpose is to evaluate the signal and phase cleanness. It takes the signals from the two coils and draw them as https://en.wikipedia.org/wiki/Lissajous_curve .
Here what you get from a well fed stepper with good microsteps interpolation, a balanced, large and smooth circle.
And this is what you see in a system where the supply is insufficient to drive the current at high movement speeds. Skinny and distored.
BTW, each rotation along the circle is equivalent to 4 full steps that make up a single 'electronic rotation'.
These patters are shown in real time while the printers operates. This screen is experimental, need to clean it up and include in the official release.
EDIT: here is an interesting animation from Wikipedia that shows how it works:
https://en.wikipedia.org/wiki/Lissajous_curve#/media/File:Circular_Lissajous.gif
PCBs are here,
i can supply the pcb, the two sensors and the eprom.
due too some family buisness i do not know if i can solder them in the next weeks. So selling the parts only would be the best for me. Best
No problem to sold them myself.
How do we proceed to pay you?
Contact me via PM
So for the price.
5 € the pcb
2,5€ for the sensors and eprom
1€ for 40 pin connector
1€ for resistorsdue to a mistake at digikey the capacitors are to small.. So these have to be self sourced ( easy)
shipping with tracking 8€ without 4€ in europe
germany 3 € shipping
So for the price.
5 € the pcb
germany 3 € shippingDo you have any for sale?
Can you ship to the US?
Thanks.
I have about 20pcbs and for 10 pieces parts
I sent you a message in the private chat; did you get it?
@fma said in Low cost, public domain, stepper analyzer - season 2.:
If you mean me yes I did.
