    NodeDSF : Interface nodes for Node-Red (V1.1.11 - 06-10-23).
    Third-party software
    5.0k
    • tekstyleundefined
      tekstyle @MintyTrebor
      @mintytrebor
      thanks for the recommendation. i am in the process of converting my duet2wifi to SBC. just waiting on the adapter for the wifi module pinout.
      • jgrg1undefined
        jgrg1
        Have to say, this project is excellent. Having never used NodeRed, it was relatively trivial to setup on my Raspberry pi 3b+ SBC board (following the instructions) and get going. I then wired up a pushover node, and voila, I now have notifications on my phone.
        Essentially, I wanted to recreate the pushover notifications that you get with octoprint, and this worked a treat. It's actually more powerful, as the DSF-Event nodes let you look for specific changes with the Duet object model.
        I used the DSF-Intercept node (with custom g-code added in the slicer) to check for layer changes and report when the first layer was started and finished.
        MintyTreborundefined 1 Reply Last reply Reply Quote 1
        • ilias.khizanundefined
          ilias.khizan
          This post is deleted!
          • MintyTreborundefined
            MintyTrebor @jgrg1
            V1.1.11 Update - Nodes updated to RRF 3.5 comptability. Update through Node-Red Palette manager.
            NodeDSF - Native Node-Red integration with Duet boards.
            BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
            ReleaseMgr - Duet update info inside DWC.
            Repo
            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 1
            • DIY-O-Sphereundefined
              DIY-O-Sphere @MintyTrebor
              @MintyTrebor
              I would like to share my experience with installing NodeDSF.
              I am running Node-Red in a Docker container on a PI4.
              It is important not to load the latest Node-Red image when setting up the container.
              If you do, NodeDSF will not install. (Incompatible node.js version).
              With nodered/node-red:3.1.0-18 as image it worked.
              Info about specific images are here https://github.com/node-red/node-red-docker
              It took me hours to figure this out....
              (UTC+1)
              MintyTreborundefined 1 Reply Last reply Reply Quote 0
                MintyTrebor @DIY-O-Sphere
                @DIY-O-Sphere NodeDSF is built against the recommended NodeJS version (18) as stated by node-red here https://nodered.org/docs/faq/node-versions
                Unfortunately if the docker image maintainers have not updated thier "latest" image to NodeJS18 there is not much I can do about it.
                Repo
                DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
                  @MintyTrebor
                  This should not be a criticism rather meant as a help for others.
                  And it's a bit strange that the latest image contains such old versions of node.js....
                  (UTC+1)
                    @DIY-O-Sphere said in NodeDSF : Interface nodes for Node-Red (V1.1.11 - 06-10-23).:
                    Yep - a user of my nodes for klipper (moonnode) hit the same problem (v18 nodes on v16 docker image), he raised the issue with the docker image maintainers and there response was something like "we wont update the node version until the next major release" - which is not ideal
                    Repo
