TH3D EZABL Setup Information
Hi there! I figured this would be good to post here as this forum is the official support method for Duet users. We got a few people using our EZABL kits with the Duet boards so we did a write-up on the recommended setup for our probes with the Duet boards.
You can see it here: EZABL Duet Board Setup Information - TH3D Help Center
I hope this helps people get the probes setup with the Duet boards. I had a heck of a time with the learning curve on the duet software. If there is anything I should change on the article please let me know. If one of the mods wants to just lock this post I just wanted it to be on here to serve as a reference to our setup guide article for EZABL+Duet customers. Thanks!
That's great. Thanks. I'll add a link to that page in the Z probe connection wiki.
do you really need the control board for the duet?
@th3dtim
your example homeall file misses a semikolon in line 3; homeall.g ; called to home all axes 2021 20:41:45 GMT-0600 (Central Standard Time)
I'm sure RRF simply ignores the datum line, but you never know...
@o_lampe Thanks for catching that. I fixed it.
@Veti said in TH3D EZABL Setup Information:
The control board provides isolation from the sensor and the IO pins. Definitely keep it. The signal is transmitted with a high-speed Opto IC on the control board.
