    External triggers don't work on Duex5
    • felekundefined
      felek
      Hi!
      I think that I received broken Duex5.
      I cannot use external trigger for endstop 3/4/5. For endstop 2 and 6 it works fine.
      Fans on duex also work.
      I replaced Duex board and everything woks ok.
      I suspect some soldering SX1509 chip issues.
      RRF 2.05.1 (programmed in factory)
      Duex5 V0.10
      SD card (files from factory) I only added one line: M581 E2:3:4:5:6 T6 S1 C0
      config.g
      ; Configuration file for factory testing Duet Ethernet and Wifi with V2.05.1 firmware
      FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
      ; Communication and general
      M111 S0                         ; Debug off
      M550 PDuetTest					; Machine name and Netbios name (can be anything you like)
      M551 Preprap                   	; Machine password (used for FTP)
      *** Ethernet networking: The following lines are used for factory testing - PLEASE REMOVE THEM
      M552 P192.168.1.34				; IP address
      M554 P192.168.1.255				; Gateway
      M553 P255.255.255.0				; Netmask
      ;*** End of factory test lines to be removed
      ;*** Networking
      M552 S1					; Turn network on
      M555 P2					; Set output to look like Marlin
      G21						; Work in millimetres
      G90						; Send absolute coordinates...
      M83						; ...but relative extruder moves
      ; Axis and motor configuration
      M569 P0 S1
      M569 P1 S1
      M569 P2 S1
      M569 P3 S1
      M569 P4 S1
      M574 X2 Y2 Z2 S1
      M665 R105.6 L215.0 B85 H250
      M666 X0 Y0 Z0
      M350 X16 Y16 Z16 E16:16 I1
      M92 X80 Y80 Z80
      M906 X1000 Y1000 Z1000 E800 I60
      M201 X1000 Y1000 Z1000 E1000
      M203 X20000 Y20000 Z20000 E3600
      M566 X1200 Y1200 Z1200 E1200
      ; Thermistors
      M305 P0 T100000 B3950 R4700 H30 L0
      M305 P1 T100000 B3974 R4700 H30 L0
      M305 P2 T100000 B3974 R4700 H30 L0
      M570 S180
      ; Adjustments for dummy heaters on test rig
      M307 H0 A250 C140 D5.5 B1
      M307 H1 A250 C140 D5.5 B0
      M307 H2 A250 C140 D5.5 B0
      ; Disable Fan 1 thermostatic mode
      M106 P1 H-1
      ; Tool definitions
      M563 P0 D0 H1
      G10 P0 S0 R0
      M563 P1 D1 H2
      G10 P1 S0 R0
      M92 E80:80
      ; Z probe and compensation definition
      M558 P5 F100 T6000 X0 Y0 Z0 H3
      G31 P100 X0 Y0 Z-0.25
      M208 S1 Z-0.2
      T0
      ; M117 Use https://configurator.reprapfirmware.org/ to set up your printer config
      trigger6.g
      M291 R"Hello 6" P"World"
        When and where was it purchased?
        felekundefined 1 Reply Last reply Reply Quote 0
        • felekundefined
          felek @Phaedrux
          @Phaedrux I bought 23.11.2020 from Duet3D. Label number 820.0563
            Please fill out the warranty claim form linked here: https://www.duet3d.com/warranty
            Include a link to this thread in your correspondence as authorization.
