    Multiple problems
    Using Duet Controllers
    114
    • TomasL
      TomasL last edited by
      Tryin g to configure my printer.
      It is a Frankenstein printer, built from:
      Prusa I3 Steel
      with
      Geetech mechanics.
      and Duett2 controller
      The original controller was a Geetech GT2560 arduino board, or whatever.
      Using the as of today, latest software and firmware.
      I have been using the reprap configuration tool to create the various files.
      Now My problems is this:
      in the web-interface, there is no display of limit switches, as it is supposed to be according to the various documents, hence I dont know what the reprap software is thinking about them
      I have hardwired the board, so when the limit switches is on, the LEDs lights up.
      When I home the axis, X and Y is ending up in the middle of the bed, I cannot move X and Y negative from this position.
      Z ends up some 5mm above the bed.
      So obviously something in my configuration is wrong, but what?
      • alankilian
        alankilian last edited by
        Someone will point you to this page where you can find out what information people need to be able to help you efficiently.
        I can say that you can use M119 from the GCODE console to gt the limit switch status.
        • TomasL
          There isn't any G-code console in the Web-Gui
            Phaedrux Moderator @TomasL last edited by
            @TomasL said in Multiple problems:
            You sure about that?
            https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Console
            And yes the endstop display page is currently missing. Please use M119 to check endstop status until it is re-introduced.
            • TomasL
              Ok, so it is the normal console then, not a specific g-code console.
                I don't understand the distinction. The Duet only speaks gcode.
                • TomasL
                  Well, How would I know, the console is obviously displaying error messages, and to enter M-commands, I thought that M-commands was a different thing, bear in mind, this is my first encounter with these things. So I obviously have to learn.
                  Now, why is it homing to the middlke of the build-plate, is it du to miss-configured endstopps, or what.
                  fcwilt 1 Reply Last reply Reply Quote 0
                  • fcwilt
                    fcwilt @TomasL last edited by
                    Well clearly something is wrong - either with your configuration or your hardware.
                    For starters post the follow using the </> tag
                    • config.g
                    • homeall.g
                    • homex.g
                    • homey.g
                    • homez.g
                    • bed.g (if you have one)
                    If you use the tag we don't have to download the files to view them.
                    Here is an example of gcode wrapped in the tag:
                    G90
                    G1 X100 F1200
                    G1 Y100 F1200
                    Thanks.
                    • TomasL
                      Ok, here it is;
                      config.g
                      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Fri Feb 05 2021 18:34:18 GMT+0100 (centraleuropeisk normaltid)
                      M550 P"Frankenstein"                               ; set printer name
                      M569 P0 S0                                         ; physical drive 0 goes backwards
                      M569 P1 S1                                         ; physical drive 1 goes forwards
                      M569 P2 S1                                         ; physical drive 2 goes forwards
                      M569 P3 S1                                         ; physical drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                                   ; set drive mapping
                      M92 X80.00 Y80.00 Z500.00 E420.00                  ; set steps per mm
                      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
                      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
                      M208 X18 Y10 Z5 S1                                 ; set axis minima
                      M208 X205 Y235 Z190 S0                             ; set axis maxima
                      M574 X1 S1 P"^xstop"                               ; configure active-high endstop for low end on X via pin ^xstop
                      M574 Y1 S1 P"^ystop"                               ; configure active-high endstop for low end on Y via pin ^ystop
                      M574 Z1 S1 P"^zstop"                               ; configure active-high endstop for low end on Z via pin ^zstop
                      M558 P1 C"zprobe.in" H5 F120 T6000                 ; set Z probe type to unmodulated and the dive height + speeds
                      G31 P500 X29 Y0 Z2.5                               ; set Z probe trigger value, offset and trigger height
                      M557 X33:200 Y25:195 S20                           ; define mesh grid
                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 S1 H-1                                     ; set fan 1 value. Thermostatic control is turned off
                      M575 P1 S1 B57600                                  ; enable support for PanelDue
                      M501                                               ; load saved parameters from non-volatile memory
                      T0                                                 ; select first tool
                      Home All
                      ; homeall.g
                      ; called to home all axes
                      G1 H2 Z5 F6000          ; lift Z relative to current position
                      G1 H1 X-192 Y-230 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000       ; go back a few mm
                      G1 H1 X-192 Y-230 F360  ; move slowly to X and Y axis endstops once more (second pass)
                      G1 H1 Z-190 F360        ; move Z down stopping at the endstop
                      G92 Z5                  ; set Z position to axis minimum (you may want to adjust this)
                      ;G91                    ; relative positioning
                      ;G1 Z5 F100             ; lift Z relative to current position
                      ;G90                    ; absolute positioning
                      homex.g
                      ; homex.g
                      ; called to home the X axis
                      G1 H1 X-228 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 H2 X5 F6000    ; go back a few mm
                      G1 H1 X-228 F360  ; move slowly to X axis endstop once more (second pass)
                      G1 H2 Z-5 F6000   ; lower Z again
                      homey.g
                      ; homey.g
                      ; called to home the Y axis
                      G1 H1 Y-250 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                      G1 H2 Y5 F6000    ; go back a few mm
                      G1 H1 Y-250 F360  ; move slowly to Y axis endstop once more (second pass)
                      homez.g
                      ; homez.g
                      ; called to home the Z axis
                      G1 H1 Z-200 F1800 ; move Z down until the endstop is triggered
                      bed.g
                      G29  ; probe the bed and enable compensation
                      • fcwilt
                        fcwilt last edited by
                        Thanks - looking at them now...
                        M208 X18 Y10 Z5 S1 - Z5 is a very odd value - normally the value is 0 or a bit less.
                        Please explain.
                        • TomasL
                          Another problem I have is that when I do the motor test macro, randomly it says that one phase is missing on the motors.
                          Allways on the extruder thoug.
                          I have measured the connection and everything seems to be ok, connectionwise, i.e there is no open circuit or any short circuit.
                          • TomasL
                            What is M208?
                            fcwilt alankilian 2 Replies Last reply Reply Quote 0
                            • TomasL
                              I guess that is the offsets from the limitswitches.
                              Well, when the X-switch is activated, the head is around 18mm out of the bed, same with the Y-switch, the Z I had set just to avoid it craching into the glass. for the moment.
                              Maybe I got it the wrong way around
                              • fcwilt
                                What is M208?
                                Another "victim" of the configuration tool - it has shielded you from learning the commands.
                                M208 is used to set the axes minimum and maximum positions.
                                For example on one of my printers I have this: M208 X-150:150 Y-100:100 Z0:300.
                                What is means is the range on...
                                • the X axis is from -150 to +150
                                • the Y axis is from -100 to +100
                                • the Z axis is from 0 to 300
                                • alankilian
                                  alankilian @TomasL last edited by alankilian
                                  @TomasL It's just FINE that you are confused and having problems.
                                  We're here to help you and we will get you going eventually. We've all been confused with this stuff also.
                                  Stay POSITIVE and you';ll get the best results from this group.
                                  You can look up all the G and M codes here.
                                  Here's M208
                                  So, let's start with this:
                                  • Move the carriage away from the X, Y and Z limit switches and post the result of M119
                                  • Press the X limit switch and post the result of M119. Release the X limit switch.
                                  • Press the Y limit switch and post the result of M119. Release the Y limit switch.
                                  • Press the Z limit switch and post the result of M119. Release the Z limit switch.
                                  This will show that each limit switch is hooked up correctly and working correctly.
                                  Then we can move on to homing.
                                  • fcwilt
                                    OK that value for Z then makes sense as it is only for testing.
                                    Can the end stop switches be adjusted can reach the edges of the printable area?
                                    alankilian 1 Reply Last reply Reply Quote 0
                                    • fcwilt
                                      What motor test macro? Was it on the SD card? If it is the same as my SD card that macro is for factory use.
                                      • TomasL
                                        Ok, Ill have to do that tomorrow, since the printer is in my lab and I am at home , by the way, this is my labWP_20200916_21_02_34_Pro (1).jpg
                                        Yes, the macros show upp in the WEB-UI
                                        • alankilian
                                          alankilian @fcwilt last edited by
                                          @fcwilt said in Multiple problems:
                                          OK, then in M208, you want X-18 instead of X18
                                          Then, in homex.g the command on line #9 G1 H1 X-228 F360 says to move in the negative direction until the endstop switch is hit, and THEN set the current X location at minus-18mm which is what I think you want.
                                          So a similar thing for Y and Z
                                          • fcwilt
                                            @TomasL
                                            I see the problem.
                                            You don't own enough test equipment.
                                            Are those scopes Tektronix? What models?
                                              Any macros that came on the SD card should not be run. They are for factory testing. These macros are no longer included, but boards that were purchased before the change may still have them.
                                              • alankilian
                                                Nice lab!
                                                • TomasL
                                                  If I am allowed to do som "commercials",
                                                  I run two sites, (well three sites really).
                                                  They might be usefull, since all information is free.
                                                  The first site is ebaman.com, where I collect users/service manuals and other documents, for full free download, the only catch is that you have to register to download.
                                                  I have the largest collection of Heathkit manuals available, plus some 13k of other manuals.
                                                  My next site is ba-restore.com, dedicated for restoring boat-anchors (well for you that dont know what it is, old electronic and mechanical equipment).
                                                  The third site, is microdiscray.com basically this site describe how crazy I am, since my intention is to build a MIPS32 CPU/Computer in discrete components based on ECL-technology.
                                                  When I'll get some $10k or so available, I would probably build it.
                                                  Anyway, I am happy for all help I could get
                                                  • TomasL
                                                    Well, the Lab
                                                    Right, what do I have in there, well:
                                                    One TEK 7854 computing mainframe with calculator.
                                                    One TEK 7603 with 7D20 Digitizer
                                                    One TEK 7613 Storage with Curve tracer
                                                    A number of various TEK7000 series Plug-Inns
                                                    One Nicolet 4094 Storage scope with dual 5 1/4 Floppy-Drive.
                                                    One TEK DPO7000
                                                    One HP 2GHz spectrum analyzer
                                                    One Agilent 6,5 digit DVM
                                                    One Fluke 8854a 5,5 Digit DVM
                                                    One fluke 8000 DVM
                                                    Various fluke handhelds
                                                    One handheld Agilent LCR-meter
                                                    One TEK 1241 96 channel Logic analyzer
                                                    One TEK 308 8-bit +16- bit Logic analyzer
                                                    One HP Counter
                                                    One TM500 with a number of various modules
                                                    3 weller WX soldering stations, 40, 80 and 200W
                                                    1 Weller De-solderiong station
                                                    One Hot air soldering station
                                                    2 Leica Stereo microscopes with lightassembly
                                                    One 3-d Printer
                                                    And to finilize the whole stuff, one complete SMD Pick and Place assembly line
                                                    fcwilt 1 Reply Last reply Reply Quote 1
                                                    • TomasL
                                                      Fredrick, I know, I need to get some more stuff.
                                                      On the purchace list is a Wow&Flutter meter amongst others.
