Problem with extruder motor
I need some help. I have just instaled the new extruder, "The orbiter", for minimizing the weight. Unfortunately I am having problems with the motor.
I have bought 4 motors from Wantai (36BYGH218, 1.8A, 1.8deg/step)and tested them all, so I do not think it is the motor's problem, because they are all doing the same noise; like ggrrrrr, loosing steps. Nor the board has problem because for ease of practicing I have tried driver3 and driver0.
I have checked the wiring twice. The connections are B, A, A, B on the duet, the same for my motor. I have also tried swapping the cables but is not working either.I have put the configuraton for the extruder as per instructions:
Firmware configurations:
Stepps: 655 stepps / mm @ 16 micro-stepping (for the 7.5:1 gearing ratio)
Acceleration: 600 mm/s^2
Maximum instantaneous speed change (jerk): 300 mm/min(RRF), 5 (Marlin)
Maximum speed: 3600 mm/min
Pressure advance: 0.03s
Retraction: 1.2mm (for the volcano V6 hotend)
Retraction speed: 60mm/s
Motor current:
0.9A Peak or 0.63 RMS(Wantai 36BYGH218)I have tried different currents 1400mA, 1000mA, 900mA and 700mA but still doing the same.
Any thoughts?Part of my config:
M569 P0 S1 ; physical drive 0 goes forwards (X axis)
M569 P1 S1 ; physical drive 1 goes forwards (Y axis)
M569 P2 S0 ; physical drive 2 goes backwards (Z axis)
M569 P3 S1 ; physical drive 3 goes forwards (E0)
M569 P4 S0 ; physical drive 4 goes backwards (Coupler)
M584 X0 Y1 Z2 E3 C4 ; set drive mapping
M350 C8 I0 ; configure microstepping without interpolation
M92 X100.00 Y100.00 Z400.00 E655.00 C100.00 ; set steps per mm
M566 X400.00 Y400.00 Z10.00 E300.00 C2.00 ; set maximum instantaneous speed changes (mm/min)
M203 X16500.00 Y16500.00 Z1000.00 E3600.00 C5000 ; set maximum speeds (mm/min)
M201 X4000.00 Y4000.00 Z400.00 E600.00 C400.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1000 E900 C400 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S120 ; Set idle timeout
@sigourosandreas said in Problem with extruder motor:
duet is B,B,A,A
@Veti I have swapped the wires but it is not working either way.
M906 E900
you are supposed to run the motors at arund 75% of their rated current.
post a picture of your wiring on the duet.
Did you use a continuity checker or other device to verify the connections on the steppers to be sure the markings did label the coil ends?
@fcwilt I have used a multimeter for checking that I am using both A or both B to match with the board A and B. I do not know if the A+ of the board is the A+ of the motor though.
I have plenty of motors and it is the first time to have such a difficulty with a motor. And not just one. I have checked all 4 of them. I am building a toolchanger.
OK good to be sure.
Did you try M350 C16 I1 just as a test?
I have checked the motor cables and I verify that they are BAAB as Duet wifi has them.
I still cannot understand why all 4 of them are not turning/ spinning at all, but they act like they are skipping steps.
The first two fotos are the motors I have. The 3rd on is from Wantai site, the cable orientation.
Can anyone please tell me, what is wrong and they are not working properly?
duet is BBAA
In the "2.) Wiring your Duet 2 WiFi/Ethernet" the foto is BAAB.
But anyway I have tested with BBAA, too, and they act the same.
measure the resistance for each phase at the connector
Thanks.
The A phase is about 31ohms and the B phase about 35ohms.
What is this mean?
that there is something wrong
36BYGH218 motor should be 2.1 Ohm per phase
I measured again and both phases are 4,6ohms.
I don't know why I got the other readings. Maybe I had not used correctly the multimeter.
But the reading is double the correct one.
So this means that the motors are not good?
I am having this very same issue with a brand new duet 3 board that I just setup.
I have X,Y,Z1,Z2,Z3 on drivers 0,1,2,3,4 and the extruder on the last driver #5. I have tried 3 different motors and then switched the motors out with a Z motor by just swapping at the board and extruder motor runs perfectly on the same cable just plugged into a Z motors driver when I manual raise or lower the bed.
So the motor and cable is definitely working fine. I am wondering if the brand new board I have just happened to come with a bad driver or something?
My motors act exactly as you describe and often just barely humm and don't even step at all when driven from driver #5
@Noah Probably best to start a new thread. Include your config.g and the results of M122 along with as much detail as possible.
@Phaedrux OK, Thanks, I'll do so if I don't find any info searching around for another hour or 2.
