    max31865 with duet 2
    • KevinSant
      KevinSant last edited by
      Re: PT100 board pinout/instructions?
      help with pinouts
      • T3P3Tony
        The up to 4 MAX31865 chips are supported on the temerature daughterboard header, using CS pins CS1,CS2,CS3 and CS4. If you are using our PT100 daughter board then CS1 and CS2 refer to the MAX31865 ICs on the first daughterboard and CS3 and CS4 refer to the second daughterboard.
        In RRF 3.x you need to setup the temperature sensor
        to use the appropriate CS pin
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M308_Set_or_report_sensor_parameters
        e.g.
        M308 S1 P"spi.cs1" Y"rtd-max31865" A"PT100_1" ; define a PT100 sensor on the temperature daughterboard header, CS1
        www.duet3d.com
        • KevinSant
          so this is the board I have I know it's not the duet but it's still the 31865 I'm just trying to figure out if my wiring is correct
          max31865 / duet wifi 1.04
          vin/ ?
          gnd/gnd
          3v/3v
          clk/sck
          sdo/Miso
          sdi/mosi
          cs/cs1
          rdy/not applicable
          so I pretty much got it figured out just need to know what vin gets connected to 3v on duet or stays open with nothing
          pipersw 1 Reply Last reply Reply Quote 0
          • pipersw
            pipersw @KevinSant last edited by
            @bks31 you connect VIN to 5v and not connect 3.3V or you leave VIN not connected and connect 3.3V to 3.3V of Duet
            • T3P3Tony
              yes that looks right and use 3.3V so the signal levels are correct for the Duet.
              www.duet3d.com
              • KevinSant
                ok so leave vin alone then?
                also I have two of these boards will I be able to stack them on top with same pins except the cs pin and use cs2 for another board
                  dc42 administrators @KevinSant last edited by
                  @bks31 said in max31865 with duet 2:
                  Yes.
                  • Referenced by  jphilly jphilly
