Acceleration as a function of speed
i would like to request "acceleration as a function of speed"
My motivation is to maximize possible acceleration for best print quality as well as speed, at given limitations.
Limitations are
stiffness/weight of the system
stepper torque as f(speed)
stepper temperature
The maximum usable acceleration is defined by the most limiting factor (whatever that is in a certain case).
In case of a stiff printer and well cooled steppers, the stepper torque as f(speed) is the limit.
Yet one has to bottleneck low speed acceleration because of the limited high speed torque.I would like to be able to set the acceleration according to speed, to increase the acceleration at lower speeds (which improves print quality and speed most, using a stiff system) compared to now.
Compared to one acceleration setting per driver yet, it would need at least 2 additional parameters:
- (OLD parameter) acceleration (new meaning: acceleration at low speed, the region where the max current setting limits)
- (NEW parameter) min speed to start acceleration reduction (start of the region where the torque starts to drop with speed)
- (NEW parameter) acceleration reduction per speed increase (to map allowed acceleration to stepper limitations, "slope" of the curve)
It doesn´t have to be a smooth transition to improve the situation compared to now. To make it more easy, it would already help to have e.g. only 2 acceleration settings per driver, one for low speeds and one for high speeds.
That's an interesting idea, but difficult to implement. The existing code divides each move into up to 3 phases: an acceleration phase, a steady speed phase, and a deceleration phase. During the acceleration and deceleration phases, the timing of each step pulse is calculated by solving a quadratic equation. Your proposal would require up to 5 segments, and in the extra 2 phases I think it would be necessary to solve a cubic equation.
An easier approach would be to choose the acceleration of the move as a whole depending on its top speed. That would allow maximum acceleration for printing moves and only reduce the acceleration for high speed travel moves.
Have you done the calculation at https://duet3d.com/wiki/Choosing_stepper_motors#How_to_work_out_the_power_supply_voltage_you_need to work out the speed at which you no longer get full torque from the motors? Are you using 12V or 24V power?
You'd have to choose the acceleration for the entire move otherwise you'll be introducing jerk (in the physics sense - the rate of change of acceleration) which we definitely don't want.
I can see why could the acceleration depend on the speed. The acceleration depends on the force that is limitted by the stepper motor torque. Maybe the motor torque depends on its rpm tho.
@DC42:
"anything" which comes closer to the real limitations of a stepper would be an improvement compared to now.Setting different acceleration values for printing and traveling is already possible. It would be new, that it depends also on top speed.
I use 24 V because the Duet doesn´t allow more. From CNC i am used to > 36 V….
I did my own calcs which are more or less the same. I can speed up with > 2g to about 1000 mm/s in theory and in real life. But until now i didn´t print anything because the printer is not finished and i am waiting for parts (z-axis is missing).If the acceleration would be a f(speed) i could increase the acceleration much more, especially for travel moves, because there "deformations of the belts/bars" (stiffness) is no problem. If the travel moves are damn fast, retraction and all the extrusion problems/imperfections (pressure advance and so on) becomes "negligible". So also flexible stuff on a bowden system works.
For constant extrusion (== no problems) a constant speed is most important, therefore high acceleration on slow printing speed is also needed.BTW: So far i had no problems with max pulses from the Duet and M122 also shows no problems at high speeds. I am wondering how that works at 1000 mm/s
@deckingman:
If you don´t vary it smoothly yes, but everybody uses jerk.... and it works, so the step has just to be not too big.
The 3 phases of the move also introduce jerks at 2 times.
@vp:
@deckingman:
If you don´t vary it smoothly yes, but everybody uses jerk…. and it works, so the step has just to be not too big.
The 3 phases of the move also introduce jerks at 2 times.NO. That's completely wrong! Jerk as used by 3D printers is referred to as instantaneous speed change and is only applied when there is a change of direction, which usually only happens doing short segmented perimeter moves. Instantaneous speed changes are NEVER applied otherwise. ANY variation to the rate of change of acceleration will result in jerky motion as defined in the physics sense. You cannot alter the rate of change of acceleration and get smooth motion.
@deckingman
ANY variation to the rate of change of acceleration will result in jerky motion as defined in the physics sense. You cannot alter the rate of change of acceleration and get smooth motion.If we are not in a quantum world ANY motion is SMOOTH in physical sense ( the space is smooth anyway). I can't understand why max acceleration should depend on the speed if limitting factor is the max available force (max torque). a=F/m in classical physics no matter how fast we are moving.
@zov:
@deckingman
The first derivative of position is velocity, the second derivative is acceleration, the third (rate of change of acceleration) is jerk, named because of how it manifests itself.
I think the OP is referring to the fact that the stepper motor torque drops off with speed so the maximum available force is speed dependent and therefore the maximum acceleration rate could be altered. I guess it would be possible if one looked ahead at the move, calculated the maximum speed it was likely to attain, then set the acceleration rate for that move (but you'd need to maintain that acceleration for the duration of the move otherwise you'll get jerky motion). Repeat the process for every move. That's an awful lot of processing to do on top of everything else that needs to happen. It's a lot easier to choose steppers that will give the necessary torque at the highest speed one is likely to use.
It is correct that "jerk" is only applied when direction changes, especially because it has a lot to do with "backlash".
But as mentioned by ZOV, nothing which is driven by a stepper (stepper says everything) is not "smooth in a mathematically sense" (That means continuous derivatives).Stepwise change of acceleration is also not possible. Therefore it never happens, as well as jerk never happens, because the mass and stiffness smooths the step. As long as you don´t lose a real step (not microsteps) it does not hurt anybody.
@ZOV:
The max force is a function of the torque. The torque start to drop of quite soon. If you use higher speeds, you have to limit your acceleration to the worst case torque - which is the small torque at higher speeds.E.g. torque at 100 rpm is 0.5 Nm, at 200 rpm 0.2 Nm. If you want to use 200 rpm even only for a very short time, you have to limit the acceleration even at slow speeds to 0.2 Nm torque - although the stepper could deliver 0.5 Nm.
I am sorry, but exactly this is not possible. More doesn´t help more and smaller steppers have exactly the same problem, only at a different level, until they are just too small.
Of course it is clear to choose the proper steppers, the link above from DC42 shows how to. But after you have done this, you still loose plenty of torque == printing quality and or printing time.
The difference in CPU resources is there, but depending on how it is solved not significant by definition.
Nobody says everybody has to use it.If the ramp parts of the 3 move phases are split in 2 parts, one part limiting the speed to speed_limit_1 (this is already done now) and the second part of the ramp is limited to speed_limit_2. For both parts 2 acceleration settings could be applied. I don´t believe that this is too CPU intensive. The change in acceleration does not matter at all in real life.
@deckingman:
The first derivative of position is velocity, the second derivative is acceleration, the third (rate of change of acceleration) is jerk, named because of how it manifests itself.I think the OP is referring to the fact that the stepper motor torque drops off with speed so the maximum available force is speed dependent and therefore the maximum acceleration rate could be altered.
For the sake of truth the smooth space is infinitely differentiable so any move is smooth by definition. I am not sure that stepper motor torque depends on speed of rotation very much but I may err, not fully my field of knoweledge.
Correction: I saw that MAX torque indeed depends on speed (Power = Torque x Angular Speed). I appologise for my misunderstanding.
@vp:
That's not true, because we use constant current stepper drivers. Torque is proportional to current, so torque is maintained as RPM increases up to the point at which the back emf due to inductance + back emf due to rotation + voltage drop due to resistance exceed the driver supply voltage, and the driver can no longer supply enough voltage to achieve the desired peak current.
It would be true using constant-voltage drivers though.
Thanks David. It became crystal clear that variable acceleration is useless for our case.
@zov:
I don't think it's completely useless. It would be useful if the combination of motor, drive voltage and drivechain gearing meant that it was not possible to maintain the specified motor current at high speeds. This could be the case for a printer that uses leadscrews for the X and Y axes, because of the high steps/mm of such an arrangement. But for belt-driven printers, I think it's usually possible to choose motors that don't run into the torque limit at the highest wanted RPM - especially when using a series 2 Duet with its 2.4A output capacity, because that allows you to to choose motors with lower inductance (and higher operating current) than when using the types of driver found in other 3D printer control electronics.
Are you sure of that? I never saw a torque vs speed curve with a flat part, then a falling part; they always start to fall as soon as rpm>0 (more or less quickly, depending on the supply voltage, for the rasons you mentioned). And I never saw constant voltage drivers (except diy ones)…
@vp:
…....................The change in acceleration does not matter at all in real life.
Try it next time you are driving your car. Rather than accelerating evenly, pump the accelerator up and down. Or conversely slow down by pumping the brake peddle instead of applying gentle even pressure. The jerk you will encounter is the result of altering the rate of change of acceleration (and it does matter in real life as well as in 3d printing).
@fma:
The curve you are talking about is for the case of constant driving voltage (nominal voltage applied to the DC motor). I think David is right as duet's drivers are constant current ones.
That's right, torque vs. speed curves are only relevant to constant voltage operation. If you wanted to publish a torque vs. speed curve for constant current operation, you would have to specify the actual RMS or peak used and the driver supply voltage, because both of those affect the point at which the torque starts to drop off.
At work, we use Nema 34 Slo-Syn steppers, and curves given by the manufacturer (sorry, I only have them on paper, and as I'm on holidays, I can't scan them) do specify driver supply voltage; I guess they give them for nominal current of the motor. And they usually show 2 or 3 curves, for different supply voltages (24V, 48V and 70V, if I remember correctly).
As I have these documentations for more than 20 years, and as we always used constant current drivers, I assumed constant voltage drivers were abandoned long ago…
Dear all,
i know very well what constant current vs constant voltage means, i am a CNC guy and in the very old past there was only constant voltage with all limitations.
Please do me a favour and just google –> https://www.google.at/search?q=stepper+torque+curve and check the pictures. I don´t understand why that is a secret here ?!?Because of back EMF as mentioned already several times the torque starts to drop at about 0-10 rps (revs per second, depending on supply voltage). The constant current ONLY applies in the low speed region, because afterwards (at higher speeds) the coil limits the current. The reason to use higher supply voltage is because of this effect. At 12V it starts at nearby 0 rps, at 24V before 5 and with high voltage (48 V and above) the constant current torque maybe gets to 10 rps.
5 rps means with a 16 GT2 pulley 5162 = 160 mm/s !!!!! I don´t know why a 3D printer should not operate in higher speed regions? At 12 V torque drops from "zero speed".
please do me a favor and e.g. check the following link: http://www.electrocraft.com/products/stepper/TPP23/ and go to the tab "speed/torque curves", there is nothing more to say
Well, so, there is a constant torque phase, but it is very small; at work, we operate far beyond that zone.
But as you showed, for a 3D printer, it is possible to operate at constant torque, using at least a 24V supply voltage…
Are Allegro or Ti chip constant current drivers? Or are they constant voltage ones?
The speed/torque curves that vp linked to are indeed specified for different supply voltages and a particular current, so they are applicable to constant current drivers.
I don't think vp has said which particular motor he has chosen, so I can't comment on his calculation that suggests he is limited to 160mm/sec before there is a significant torque reduction, or whether he has chosen the most appropriate motor from the range. But here are some points to note:
1. In 3D printers we normally run the motors well below their maximum current, because at maximum current the motors get very hot. At reduced current, the back emf due to inductance is lower, so the (reduced) torque is maintained to higher speeds. For example, if you halve the current, then the torque at low speeds will be half what is shown on the torque/speed curves and will be almost flat until it intercepts the torque/speed curve shown for the same motor and same driver voltage at full current.
2. Because we want precise motion during printing, we use 1/16 or greater microstepping, and to get position accuracy this means that the motors need to have far more holding torque than is needed to produce the acceleration demanded, so that we can maintain a position accuracy of around one 1/16 microstep. But high-speed travel moves don't need this accuracy during the high speed part of the motion, it's only the end of the move that needs to be accurate. So quite a large loss of torque is acceptable during the middle part of a travel move. If you know the mass of the print head or bed or whatever the motor is moving, you can work out the torque needed to produce the desired acceleration, and you just need to make sure the motor can provide this torque with a sufficient safety margin e.g. 2x.
3. If you are building a CNC machine and need motors with seriously high torque, you should use external drivers.
Thanks for the explanations!
I did choose WANTAI 42BYGHW811, in my setup, they should be able to achieve nearly 1g close to about 1500mm/s, without losing 1/16 micro step with a light direct driven extruder/hot end. I don´t have a "problem" at 160mm/s, this is just an example to show that if the torque drop starts with 12 V at "0" rps, this problem is existing in the normal operating range of 3D printer, just check the curves.
This is not special for 3d printing, it is a good rule of thumb for every stepper application to use at max about 80 % of the specified amps. The steppers itself are normally rated to > 100°C surface temperature, I operate my steppers at about 80 % of the rated current and they get at max about 50 °C (also NEMA32s), which is at least for me no problem. Because P = IIR it is for sure sensitive to the chosen current - but it is also no trick to cool them and in the long term i will use mine at maybe > 100 % current.
Who operates his steppers at half of the design current? This 50 % comparison is completely misleading and even at 50 % and 12 V there is also before 5rps a torque drop. If somebody operates at 50 % i would suggest him to go for different (smaller and faster) steppers. But do these people buy a premium product like the Duet Wifi ?
Yes, that is one reason for the firmware change request, now we get back on track.
But i would say we don´t use 16 microsteps for finer resolution (with a 16 T GT2 pulley 16th means in theory 0.01 mm), because this fine steps never happen with this accuracy (e.g. stepper nonlinearities and all other mechanical errors of a 3D printer are much bigger) we just do it because it runs smoother and less noisy - and because it doesn´t cost anything. Maybe it can reduce some fancy patterns on deltas, but there only relative accuracy is needed. On xyz printers 16th stepping doesn´t improve accuracy at all.
I have to show more clearly what this request is for because it still seems to be not clear:
1. Many speed as well quality problems are extrusion related. Often people claim their E3D v6 cannot go above e.g. 50 mm/s because then under extrusion and so on is happening. They say the extrusion capacity is not enough - which is wrong. The problem is, that the hot end print speed varies and by that the extrusion rate. Unfortunately, molten plastics have a viscoelastic material law which brings the time factor in play. So any change in extrusion rate/speed is going to make problems - but this is not the root cause. The root cause is the varying printing speed. The root cause for the varying printing speed is a lack of useable acceleration which is limited by the mass/stiffness of the system and the stepper torque which is a function of speed .
Especially at lower layer heights and small nozzles or with e.g. a volcano, the extrusion capacity is enough for speeds far above 100 mm/s. But as soon as the speed drops the extrusion problems will occur. On youtube are enough videos showing damn fast prints - with a miserable print quality. I want fast prints with good quality - this is not possible without the maximum acceleration.
2. Many problems are retraction related. Why do we need retraction at all ? Because too much plastic would ooze out. The smartest way I know to overcome this problem is to give the oozing process no time. Half the time and you half the amount which could ooze out. If you print flexible material that is the only way to go. If you don´t need to retract (or less), problems of 1. are also reduced. Solve the problem by just increasing the speed of travel moves.
3. Think the other way round. With a Duet Wifi capable of acceleration as a function of speed, one could use smaller (faster) and cheaper steppers. This could mean one uses NEMA14 for normal printers or NEMA 17 instead of NEMA23 for big size printers.
4. printing time
Many prints need excessive amounts of travel moves. Normally most travel moves are short distance moves. Using a histogram to show the distribution of travel move length, it would be very heavy on the left side (much more short than long moves). What does short distance mean ? With 2g it takes 25 mm to reach 1000 mm/s, with 5g 10 mm. The problem is, that long travel moves need more time and increasing max travel speed would reduce the time significant. To increase max travel speed, i would have to reduce the max torque - also in the low speed region were most of the moves happen. Increasing max travel speed ends up to give no benefit, if the max torque on the low side has to be decreased.A higher acceleration in the low-speed region (printing) means a higher average printing speed and again a reduction of printing time.
5. Jerk. Jerk was introduces to get away from blobs on every corner (bleeding edges) and to decrease printing time. Unfortunately jerk is the most brutal way and is mostly based on backlash and low stiffness. In the old days both was existing at much higher levels than nowadays. Using too much jerk shows ringing/resonance artifacts in the print (as well as too high accelerations). Using 2 g it takes 0.0xyz mm to get to e.g. 20 mm/s. But it is much more gentle and gives by that less artifacts - or at same amount of artifacts much more printing speed. Jerk could be reduced to nearby 0 and substituted by "soft" acceleration. Doing so would be like a poor mans s-curve acceleration in the very low speed region.
6. Future developments like s-curve acceleration/moves. Although some people thinks it is too CPU intensive, for me it is clear that in future we will use something like s-curve like moves. This gives much more possible printing speed at same artifact level. But using s-curve like moves reduces at the same max acceleration the average acceleration - so in total the benefit is much smaller as it cold be. To overcome this problem, acceleration has to be really maximized - according speed.
Finally:
I don´t care at all, what people are doing now, i question for what is possible, i want to push the limits - and premium products like the Duet are bought because the "normal" stuff is not as good as it could be. It is not true that printing speed is limited by extrusion rate to e.g. 100 mm/s. It is limited by too much varying printing speed, caused by too low acceleration settings.
Why should we bottleneck our printers? Why should we waste resources?
I don´t care if I am able to use 5g in the low-speed region (<= 1000 mm/s) already now if I can get 8g…. or travel with 2000 mm/s instead of 1000 mm/s.BTW: On travel moves, the deflection of the printer parts doesn´t matter (nearby). When printing they become very significant at higher accelerations (e.g. > 1g), and more stiffness (a stiffer system means more mass) doesn´t help more. So finally the firmware will also have to address this problem because there is a mechanical material limit where engineering cannot increase the stiffness vs weight ratio anymore (see 6.).
[Edit: i added 5 and 6]
