Tool position not updated 3.2.9
Hi
I have an issue that the tool position isn't being updated in the "move" screen. I found the same with 3.2.7
Other than that the machine works great.
I used to use the move page to evaluate my Z offset and it was handy to be able to home all then move Z down to it print height and see how things were in comparison to the Z offset set in config.g
X & Y are not updated either
The axis position are also not updated on the main screen eitherTool position is updated instantly & correctly in DWC
Machine:
Cartesian i3 steel 2.5
Duet Wifi 2
Panel Due 4.3RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
Duet WiFi Server Version: 1.23
Duet Web Control 2.0.4
Update . Just re flashed everything from scratch and now appears to work! Panic over
