Duet II Ethernet steppers not moving
okay long story - short version
was all working fine on RR3, had to send out to to builder to have rewired and new hotend mount for bltouch.came back all rewired, sdcard config blown away, new hotend mount w/ bltouch added
nothing worked
this is a cartesian printer it has dual Z screws, dual Y mgn12, single X mgn12, single extruder
Dual Z is wired to Z and E1, both Y are wired to Y (they spliced the cable), X is of course X, E0 is E0nothing moves when i try to home all....... it acts like its working in the gui, but the motors move nothing.
i reset the config, updated to newest RR3
cat config.g
; generated by RepRapFirmware Configuration Tool v3.2.2 on Mon Feb 08 2021 15:04:40 GMT+0700 (Indochina Time); General preferences
M550 P"BEAST" ; set printer name; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X400 Y400 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop; Z-Probe
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:400 Y15:400 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossand M122
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later
Board ID: 08DGM-917DA-G4MS4-6J9D4-3S46K-1TZMB
Used output buffers: 1 of 24 (10 max)
Static ram: 23460
Dynamic ram: 68700 of which 40 recycled
Never used RAM 19880, free system stack 206 words
Tasks: NETWORK(ready,186) HEAT(blocked,311) MAIN(running,448) IDLE(ready,19)
Owned mutexes:
Last reset 00:00:37 ago, cause: power up
Last software reset at 2021-02-10 11:53, reason: User, GCodes spinning, available RAM 19844, slot 1
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 25.0, current 29.0, max 29.2
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-02-10 12:18:49
Cache data hit count 52588001
Slowest loop: 123.81ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.6ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 173.53ms; fastest: 0.02ms
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplex
check the fuses
but if you paid someone to do it. he should look into it.
welp fuses are fine, i checked the board 2 times, then noticed they had removed the jumpers for serial Z, ive replaced them since and now X and Z move fine, Y is being problematic, my guess is because they spliced the two Y motors to a single Y connector, but if the motors are on opposite sides of the frame one moves forwards and one should move back. neither move but now they at least make a sound.
@dingo007 said in Duet II Ethernet steppers not moving:
why would they do that? just use the z connector.
You need to find a new builder.
@Veti yeah. nope... sorry never sending it back there again...! even i know better.
Well maybe they just wired the Y steppers wrong and they are fighting each other.
That should make quite a bit of noise though.
If you don't like the idea of driving both Y steppers together like that you could use an a pair of external drivers for Y or perhaps Z.
The Duet WiFi has connections available for that on the expansion connector.
I'm using two of these on a printer I am building and so far they are working very well.
Just a thought.
@fcwilt said in Duet II Ethernet steppers not moving:
Yes they sound like marbles in a can now, have to figure out the wiring, seems one should go forward, one should go back, i tried reversing 2 wires on one of the motors, didnt seem to help
Separate them and determine the wiring needed for each stepper to move in the correct direction.
Then you can re-connect them both.
@dingo007 It will also depend if they have wired the two Y motors in series, or parallel (which will need twice the motor current). They may have also mixed up the motor phases of each motor, and/or wired them so one motor goes the wrong direction.
I'd first separate the wiring and find the phase pairs: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
Assuming motor phase pairs are black/green and red/blue (common, but there's no standard), then decide whether you wire them in parallel or series. We recommend series, though it's a bit more complicated to wire, there is even current distribution across motors, and you don't have to double the motor current.
This wiring diagram should cause the motors to turn the same way. If you need them to go the opposite direction, switch one wire pair, eg from
Green > Motor 1 > Black > Green > Motor 2 > Black
to
Green > Motor 1 > Black > Black > Motor 2 > GreenIan
So im thinking at this point, Im going to use Z A/B for both motors on Y obviously with one running backwards, and use Y/E1 for the Z screws. just a matter of cutting the cable and adding a new lead for the second Y .....
@dingo007 Yupp thats resolved now... all motors working
