RepRapFirmware 3.2.2 update question
Hi there,
I've saw the 3.2.2 update on RepRapFirmware and I've noticed it fixed an issued I've suffered from:
"[Duet 3 MB6HC] (regression in 3.2) The minimum step pulse width time of the TMC5160 was not always met. This could lead to missed steps when high step rates were used."I'm just have a simple question so I understand it better the best way to update on Standalone mode.
I've noticed that there is no "Duet3and3Firmware-3.2.2.zip" combined file.
Is the combined zip, just the DuetWebControl-SD.zip with the .bin and .uf2 added to it?
Additionally, since I only have a "Duet 3 MB6HC", can I just create a zip file of DuetWebControl-SD contents with the Duet3Firmware .bin files for the board and modules I have?
For example a collection of these files:- DWC files
- Duet3_SDiap32_MB6HC.bin
- Duet3Firmware_MB6HC.bin
- Duet3Firmware_TOOL1LC.bin
Thank you for the clarification in advance.
Upload these two files on the System Files page and confirm potential update prompts:
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet3Firmware_MB6HC.bin
https://github.com/Duet3D/DuetWebControl/releases/download/v3.2.2/DuetWebControl-SD.zipWe're going to add the missing update ZIP file shortly, sorry for the inconvenience.
@chrishamm said in RepRapFirmware 3.2.2 update question:
It's fine, I was using the opportunity to also understand better each component.
So I could even update them separately right?Uploading the DuetWebControl-SD will update DWC, the Firmware .bins update the boards firmware and I just need to upload the ones I have, while having the SDiap32 ones since I'm doing InApp upgrade in Standalone mode.
Is this correct?
@Ralms yes, thats correct
@Ralms said in RepRapFirmware 3.2.2 update question:
I have now added that file and announced the 3.2.2 release. The IAP file is unchanged from firmware 3.2.
