    Request Cartesian with cyclops system: 2 extruders and 1 hotend
    Example setups and prints
    1.1k
      Can you try copy and pasting the config sample I posted and trying that?
      • FelixHundefined
        FelixH
        Just did, no change.
        At this point I am wondering if it is at all possible a hardware error, like a bad crimped cable or something like that.
          Is it still giving error messages like shown on the paneldue?
          • FelixHundefined
            FelixH
            Yeah, but I have a new lead. Hold on
            • FelixHundefined
              FelixH
              So, when I turn on the printer a whole lot of error codes flashed on the PanelDue screen. It was so fast, I had to recorded with my phone with the Slow-Mo option. The errors are as follows:
              Error in the macro file line 32 column 32: M350 array too long, max length = 1
              Error in the macro file line 33 column 34: M92 array too long, max length = 1
              Error in the macro file line 34 column 34: M566 array too long, max length = 1
              Error in the macro file line 35 column 41: M203 array too long, max length = 1
              Error in the macro file line 36 column 35: M201 array too long, max length = 1
              Error in the macro file line 37 column 35: M906 array too long, max length = 1
              So I checked the documentation and I changed this snipped:
              M350 X16 Y16 Z16 E16:16 I1                        ; Configure microstepping with interpolation
              M92 X100.00 Y100.00 Z400.00 E408:408          	  ; Set steps per mm
              M566 X600.00 Y600.00 Z18.00 E300:300         	  ; Set maximum instantaneous speed changes (mm/min)
              M203 X10000.00 Y10000.00 Z1000.00 E3600:3600 	  ; Set maximum speeds (mm/min)
              M201 X1500.00 Y1500.00 Z100.00 E10000:10000 	  ; Set accelerations (mm/s^2)
              M906 X650.00 Y800.00 Z800.00 E800:800 I30  	  ; Set motor currents (mA) and motor idle factor in per cent
              for this one:
              M350 X16 Y16 Z16 I1                  		      ; Configure microstepping with interpolation
              M350 E16:16                        				  ; Configure microstepping with interpolation
              M92 X100.00 Y100.00 Z400.00                 	  ; Set steps per mm
              M92 E408:408          	                          ; Set steps per mm
              M566 X600.00 Y600.00 Z18.00         	          ; Set maximum instantaneous speed changes (mm/min)
              M566 E300:300         	                          ; Set maximum instantaneous speed changes (mm/min)
              M203 X10000.00 Y10000.00 Z1000.00 	              ; Set maximum speeds (mm/min)
              M203 E3600:3600 	                              ; Set maximum speeds (mm/min)
              M201 X1500.00 Y1500.00 Z100.00 	                  ; Set accelerations (mm/s^2)
              M201 E10000:10000 	                              ; Set accelerations (mm/s^2)
              M906 X650.00 Y800.00 Z800.00 I30  	              ; Set motor currents (mA) and motor idle factor in per cent
              M906 E800:800 I30  	                              ; Set motor currents (mA) and motor idle factor in per cent
              Unfortunatelly, however. Nothing changed.
              • FelixHundefined
                FelixH
                I have no M584 command. I think that's it. Going to see the documentation.
                UPDATE: so, that was it. I had no M584 mapping command. I read it completely by chance while reviewing the M305 command... Anyway now it works as I expected on both the web interface and the PanelDue display.
                Thanks for sticking with me @Phaedrux
                • FelixHundefined
                  FelixH
                  If somebody lands on this thread looking for the same info as I was, here you have it. This is what did it after some headaches:
                  ; Configuration file for Duet WiFi (firmware version 3.11)
                  ; generated by RepRapFirmware Configuration Tool on Mon Feb 04 2019 17:03:09 GMT+0100 (Central European Standard Time)
                  G90                                                ; Send absolute coordinates...
                  ;Panel Due Setup
                  M575 P1 B57600 S1
                  M550 P"FH-Dual"                                    ; Set machine name
                  M552 S1                                            ; Enable network
                  M586 P0 S1                                         ; Enable HTTP
                  M586 P1 S0                                         ; Disable FTP
                  M586 P2 S0                                         ; Disable Telnet
                  M569 P0 S1                                         ; Drive 0 goes forwards
                  M569 P1 S1                                         ; Drive 1 goes forwards
                  M569 P2 S0                                         ; Drive 2 goes forwards
                  M569 P3 S1                                         ; Drive 3 goes backwards
                  M569 P4 S1                                         ; Drive 4 goes backwards
                  M584 X0 Y1 Z2 E3:4                                 ; Driver 0 controls the X motor, 1 controls Y, 2 controls Z motors, 3 and 4 control E motors
                  M84 S30
                  M208 X0 Y-49.0 Z0 S1                               ; Set axis minima
                  M208 X220 Y209 Z200 S0                             ; Set axis maxima
                  M574 X1 S3                                         ; Motor Stall X Endstop
                  M574 Y1 S3                                         ; Motor Stall Y Endstop
                  M915 X Y S30 F0 R0				   ; Stall guard config when not homing
                  M574 Z1 S2 	                                   ; Set endstops controlled by probe
                  M558 P5 C"zprobe.in" I1 H5 F300 T6000   	   ; Set Z probe type to switch and the dive height + speeds
                  G31 P500 X-23 Y7 Z0.35                             ; Set Z probe trigger value, offset and trigger height
        ; The larger the number the closest it gets to the bed
        ; i.e.  1.50 puts the nozzle closer to the bed than 1.20
                  M557 X40:210 Y5:190 S20                            ; Define mesh grid
                  ; Bed Heaters/Thermistors
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C0 R4700 	    ; Define thermistor
                  M950 H0 C"bedheat" T0                                           ; Link pin name with heater
                  M307 H0 B0 S1.00				                                ; Disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0								                            ; Links everything on the GUI
                  M143 H0 S95                                              		; Set temperature limit for heater 0 to 95C
                  ; HotEnd Heaters/Thermistors
                  M308 S1 P"e0temp" Y"thermistor" T103944 B3943 C1.658e-7 R4700 	  ; Define thermistor
                  M950 H1 C"e0heat" T1						                      ; Link pin name with heater
                  M143 H1 S290							                          ; Set temperature limit for heater 1 to 290C
                  ; Bed / HotEnd Autotunes
                  M307 H1 A1048.7 C250.3 D10.3 V24.1 B0                ; Hotend Autotune  //Changed
                  M307 H0 A112.6 C601.0 D1.0 V24.1                      ; Bed Autotune //Changed
                  M950 F0 C"fan0" Q500
                  M106 P0 S0 H-1                        		   ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500
                  M106 P1 S1 H1 T45                         	   ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M563 P0 D0 H1                                      ; Define tool 0
                  M563 P1 D1 H1                                      ; Define tool 1
                  G10 P0 X0 Y0 Z0                                    ; Set tool 0 offsets
                  G10 P0 S0 R0                                       ; Set tool 0 operating and standby temperatures
                  G10 P1 X0 Y0 Z0                                    ; Set tool 1 offsets
                  G10 P1 S0 R0                                       ; Set tool 1 operating and standby temperatures
                  ; Automatic power saving
                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                  T0
                  T1
                  Phaedruxundefined 1 Reply Last reply Reply Quote 1
                    Phaedrux Moderator @FelixH
                    @FelixH said in Request Cartesian with cyclops system: 2 extruders and 1 hotend:
                    M584 X0 Y1 Z2 E3:4
                    • o_lampeundefined
                      o_lampe @Phaedrux
                      @Phaedrux
                      Just out of curiosity, now that the drive mapping is added, would it still be necessary to have separate jerk-, acceleration-, etc- setting for the second extruder?
                      Is it even possible to have different settings?
                      [OT]
                      Like different steps/mm for a geared direct drive mixed with a remote Bowden extruder?
                      • FelixHundefined
                        FelixH
                        I will try to see if it still works if it has only half of the settings. I have no idea...
                        Why wouldn‘t be possible to have different settings? What would be the point to have the possibility to set two settings if it wasn‘t?
                        o_lampeundefined 2 Replies Last reply Reply Quote 0
                        • o_lampeundefined
                          o_lampe @FelixH
                          @FelixH
                          Right, it's just a bad gutt feeling.
                          I remember, some settings had to be identical or be ignored if you set them different.
                          • FelixHundefined
                            FelixH
                            I've just checked. You can set separate settings. Actually I've just done it for the M92 command
                            • o_lampeundefined
                              o_lampe @FelixH
                              Imagine a Z-axis driven by three different steppers...not a common thing, but I believe it's related to the drive mapping.
                              When you define eg. M584 Z3:4:5, there are limits, of what you can specify later.
                              Same for mixing hotends IIRC.
                                Phaedrux Moderator @o_lampe
                                @o_lampe said in Request Cartesian with cyclops system: 2 extruders and 1 hotend:
                                Yes. Extruders are considered as independent axis and should have all settings defined for each extruder and those settings can be different.
                                For other axis like XYZ you only need a single value for that axis. You must use identical motors for axis with multiple motors and you cannot have different settings for each motor.
                                See the notes here: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M584_Set_drive_mapping
