Request Cartesian with cyclops system: 2 extruders and 1 hotend
I've just checked. You can set separate settings. Actually I've just done it for the M92 command
@FelixH said in Request Cartesian with cyclops system: 2 extruders and 1 hotend:
What would be the point to have the possibility to set two settings if it wasn‘t?
Imagine a Z-axis driven by three different steppers...not a common thing, but I believe it's related to the drive mapping.
When you define eg. M584 Z3:4:5, there are limits, of what you can specify later.
Same for mixing hotends IIRC. -
@o_lampe said in Request Cartesian with cyclops system: 2 extruders and 1 hotend:
Just out of curiosity, now that the drive mapping is added, would it still be necessary to have separate jerk-, acceleration-, etc- setting for the second extruder?
Is it even possible to have different settings?Yes. Extruders are considered as independent axis and should have all settings defined for each extruder and those settings can be different.
For other axis like XYZ you only need a single value for that axis. You must use identical motors for axis with multiple motors and you cannot have different settings for each motor.
See the notes here: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M584_Set_drive_mapping
