    Error: Attempting to extrude with no tool selected
    2.7k
      droftarts administrators @A Former User
      @sgk Try moving the 'Tool' section of your config.g to after the fan definitions. At the moment it is defining the tool with a fan (F1, which is the thermostatic hot end fan, so I think it should be F0, the tool fan) before the fan has been defined. This wasn't a problem in the old version of the firmware, as fans were defined by default, but in RRF3 there are no default definitions.
      • A Former User?
        A Former User
        hello everyone thank you very much for all of your help.
        I post my gcode
        https://drive.google.com/drive/folders/1ryDNZchhWtu0Z5FudB5cCDygz8ms5czn?usp=sharing
        • A Former User?
          A Former User
          for info I disconnected my panelduo and I managed to print
          1 time
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @A Former User
            @sgk
            ok see if you can route the paneldue cable not near any power or stepper cables
            • A Former User?
              A Former User
              thank you but I have more panelduo because it no longer works the touch
              so i will see if it works now permanently
                G90
                M82
                M106 S255
                G4 P500
                M106 S191
                M140 S60
                M190 S60
                M104 S200 T0
                M109 S200 T0
                M291 P"Homing all axis" R"Printing.." S1 T2
                G21		; metric values
                G28		; home all
                ;G29 S2		; mark if you want to disable mesh grid
                G32		; Run mesh grid compenstion
                		; Purge extruder
                G92 E0 F100		; reset extruder
                G1 Z10 F3000 		; move z up little to prevent scratching of surface
                M98 P/macros/Filament/Purge	; Run nozzle purge macro
                ;G1 E-1 F2000		; Retract 1mm filament
                G92 E0 		; reset extruder
                M291 P"Printing started !" R"Printing.." S1 T3
                ; process Process1
                ; layer 1, Z = 0.120
                T0
                G92 E0.0000
                G1 E-6.0000 F2400
                ; feature inner perimeter
                ; tool H0.120 W0.480
                What do you have in macro here: M98 P/macros/Filament/Purge ; Run nozzle purge macro
                What do you have in bed.g?
                What do you have in homeall.g?
                • A Former User?
                  A Former User
                  hello
                  ; bed.g
                  ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
                  M291 P"Probing mesh grid process started" R"Probing.." S1 T2
                  G28 ; home all axis bb
                  M671 X-55.0:364.0 Y175.0:175.0 S5.0
                  G30 P1 X5 Y150 Z-99999
                  G30 P0 X300 Y150 Z-99999 S2
                  G90 ; absolute positioning bb
                  M557 X20:270 Y20:270 S240 ; Define mesh grid
                  G29 S0 ; Probe the bed and save height map to file
                  M374 ; Save calibration data. Default is sys/heightmap.csv
                  M291 P"Probing mesh grid process finished !" R"Probing.." S1 T2
                  ; Probe the bed at 4 points
                  ;G30 P0 X10 Y10 H0 Z-99999
                  ;G30 P1 X10 Y290 H0 Z-99999
                  ;G30 P2 X290 Y290 H0 Z-99999
                  ;G30 P3 X290 Y10 H0 Z-99999 S
                  • A Former User?
                    A Former User
                    ; homeall.g
                    ; called to home all axes
                    G91 ; relative positioning
                    G1 H2 Z5 F6000 S2 ; lift Z relative to current position
                    G1 H1 X-355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass)
                    G1 H1 X-355 ; home X axis
                    G1 H1 Y355 ; home Y axis
                    G1 X5 Y-5 F6000 ; go back a few mm
                    G1 H1 X-355 F360 ; move slowly to X axis endstop once more (second pass)
                    G1 H1 Y355 ; then move slowly to Y axis endstop
                    G1 X152 Y166.4 F6000 ; go to first bed probe point and home Z
                    ;G91 ; relative positioning
                    ;G1 S2 Z5 F100 ; lift Z relative to current position
                    ;G90 ; absolute positioning
                    • A Former User?
                      A Former User
                      ;purge hotend
                      M291 P"purge started !" R"purging.." S1 T2 ; display msg
                      G1 X5 Y70 Z0.3 F5000.0 ; move to start-line position
                      G1 Z0.3 F1000 ; print height
                      G1 X5 Y220 F1500.0 E15 ; draw 1st line
                      G1 X5.2 Y220 Z0.3 F5000.0 ; move to side a little
                      G1 X5.2 Y70 Z0.3 F1500.0 E30 ; draw 2nd line
                      G1 X150 Y150 F6000 ; move to center of the bed
                      M291 P"purge finished !" R"purging.." S1 T2 ; display msg
                      • A Former User?
                        A Former User
                        ; Clean nozzle macro
                        M291 P"Cleaning Hotend" R"Cleaning.." S1 T5 ; display msg
                        G1 X-20 Y290 F10000 ; move to first brush point
                        G1 Z0.5 F3000 ; lower nozzle to the brush
                        G1 X-8 Y290 F10000 ;
                        G1 X-20 Y290 F10000 ; move back to first brush point
                        G1 X-8 Y280 F10000 ; move to 2 brush point
                        G1 X-20 Y280 F10000 ; move to 2 brush point
                        G1 X-8 Y280 F10000 ; move back to 2 brush point
                        G1 X-20 Y270 F10000 ; move back to 3 brush point
                        G1 X-8 Y270 F10000 ; move back to 3 brush point
                        G1 X-8 Y260 F10000 ; move back to 4 brush point
                        G1 X-20 Y260 F10000 ; move back to 4 brush point
                        G1 X-20 Y254 F10000 ; move back to 5 brush point
                        G1 X-8 Y254 F10000 ; move back to 5 brush point
                        M291 P"Cleaning finished !" R"Cleaning...." S1 T2 ; display msg
