    Error: Attempting to extrude with no tool selected
    2.8k
    • engikeneerundefined
      engikeneer
      @Phaedrux or @T3P3Tony (or one of the other moderators), it seems @sgk has been blocked from posting (getting flagged as spam by Akismet.com). Can you help with this please? 🙂
      i3 clone with a bunch of mods
        T3P3Tony administrators @engikeneer
        @engikeneer thanks for the heads up. this is the first time i have seen it with someone who is already posting successfully. Akismet is a bit of a black box, can you ask him to email info@duet3d.com and we can try and trouble shoot through this.
          @sgk You must post the sliced gcode file so we can see what the slicer is adding.
          • Thaliosundefined
            Thalios
            Do you have something defined in config-override.g concerning tools?
            Might be weird, but did you try to remove the tool label S"T0" in M563?
            Mine is like this:
            M563 P0 D0 H1 F1                                   ; define tool 0
            G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
            Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
            Heavily modified Ender 3 Pro (Duet 3 6HC)
            Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
            CR-10S Pro V2 (Duet 3 Mini 5+)
            and a bunch of SLA printers..
              droftarts administrators @A Former User
              @sgk Try moving the 'Tool' section of your config.g to after the fan definitions. At the moment it is defining the tool with a fan (F1, which is the thermostatic hot end fan, so I think it should be F0, the tool fan) before the fan has been defined. This wasn't a problem in the old version of the firmware, as fans were defined by default, but in RRF3 there are no default definitions.
                A Former User
                hello everyone thank you very much for all of your help.
                I post my gcode
                https://drive.google.com/drive/folders/1ryDNZchhWtu0Z5FudB5cCDygz8ms5czn?usp=sharing
                  A Former User
                  for info I disconnected my panelduo and I managed to print
                  1 time
                  • Vetiundefined
                    Veti @A Former User
                    @sgk
                    ok see if you can route the paneldue cable not near any power or stepper cables
                      A Former User
                      thank you but I have more panelduo because it no longer works the touch
                      so i will see if it works now permanently
                        G90
                        M82
                        M106 S255
                        G4 P500
                        M106 S191
                        M140 S60
                        M190 S60
                        M104 S200 T0
                        M109 S200 T0
                        M291 P"Homing all axis" R"Printing.." S1 T2
                        G21		; metric values
                        G28		; home all
                        ;G29 S2		; mark if you want to disable mesh grid
                        G32		; Run mesh grid compenstion
                        		; Purge extruder
                        G92 E0 F100		; reset extruder
                        G1 Z10 F3000 		; move z up little to prevent scratching of surface
                        M98 P/macros/Filament/Purge	; Run nozzle purge macro
                        ;G1 E-1 F2000		; Retract 1mm filament
                        G92 E0 		; reset extruder
                        M291 P"Printing started !" R"Printing.." S1 T3
                        ; process Process1
                        ; layer 1, Z = 0.120
                        T0
                        G92 E0.0000
                        G1 E-6.0000 F2400
                        ; feature inner perimeter
                        ; tool H0.120 W0.480
                        What do you have in macro here: M98 P/macros/Filament/Purge ; Run nozzle purge macro
                        What do you have in bed.g?
                        What do you have in homeall.g?
                          A Former User
                          hello
                          ; bed.g
                          ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
                          M291 P"Probing mesh grid process started" R"Probing.." S1 T2
                          G28 ; home all axis bb
                          M671 X-55.0:364.0 Y175.0:175.0 S5.0
                          G30 P1 X5 Y150 Z-99999
                          G30 P0 X300 Y150 Z-99999 S2
                          G90 ; absolute positioning bb
                          M557 X20:270 Y20:270 S240 ; Define mesh grid
                          G29 S0 ; Probe the bed and save height map to file
                          M374 ; Save calibration data. Default is sys/heightmap.csv
                          M291 P"Probing mesh grid process finished !" R"Probing.." S1 T2
                          ; Probe the bed at 4 points
                          ;G30 P0 X10 Y10 H0 Z-99999
                          ;G30 P1 X10 Y290 H0 Z-99999
                          ;G30 P2 X290 Y290 H0 Z-99999
                          ;G30 P3 X290 Y10 H0 Z-99999 S
                            A Former User
                            ; homeall.g
                            ; called to home all axes
                            G91 ; relative positioning
                            G1 H2 Z5 F6000 S2 ; lift Z relative to current position
                            G1 H1 X-355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass)
                            G1 H1 X-355 ; home X axis
                            G1 H1 Y355 ; home Y axis
                            G1 X5 Y-5 F6000 ; go back a few mm
                            G1 H1 X-355 F360 ; move slowly to X axis endstop once more (second pass)
                            G1 H1 Y355 ; then move slowly to Y axis endstop
                            G1 X152 Y166.4 F6000 ; go to first bed probe point and home Z
                            ;G91 ; relative positioning
                            ;G1 S2 Z5 F100 ; lift Z relative to current position
                            ;G90 ; absolute positioning
                              A Former User
                              ;purge hotend
                              M291 P"purge started !" R"purging.." S1 T2 ; display msg
                              G1 X5 Y70 Z0.3 F5000.0 ; move to start-line position
                              G1 Z0.3 F1000 ; print height
                              G1 X5 Y220 F1500.0 E15 ; draw 1st line
                              G1 X5.2 Y220 Z0.3 F5000.0 ; move to side a little
                              G1 X5.2 Y70 Z0.3 F1500.0 E30 ; draw 2nd line
                              G1 X150 Y150 F6000 ; move to center of the bed
                              M291 P"purge finished !" R"purging.." S1 T2 ; display msg
                                A Former User
                                ; Clean nozzle macro
                                M291 P"Cleaning Hotend" R"Cleaning.." S1 T5 ; display msg
                                G1 X-20 Y290 F10000 ; move to first brush point
                                G1 Z0.5 F3000 ; lower nozzle to the brush
                                G1 X-8 Y290 F10000 ;
                                G1 X-20 Y290 F10000 ; move back to first brush point
                                G1 X-8 Y280 F10000 ; move to 2 brush point
                                G1 X-20 Y280 F10000 ; move to 2 brush point
                                G1 X-8 Y280 F10000 ; move back to 2 brush point
                                G1 X-20 Y270 F10000 ; move back to 3 brush point
                                G1 X-8 Y270 F10000 ; move back to 3 brush point
                                G1 X-8 Y260 F10000 ; move back to 4 brush point
                                G1 X-20 Y260 F10000 ; move back to 4 brush point
                                G1 X-20 Y254 F10000 ; move back to 5 brush point
                                G1 X-8 Y254 F10000 ; move back to 5 brush point
                                M291 P"Cleaning finished !" R"Cleaning...." S1 T2 ; display msg
