    Duet2 with two heater cartridges
    • rexxundefined
      rexx
      Hello all
      What is the best way for me to activate another 50w heater and tie it to the one thermistor
      • fcwiltundefined
        fcwilt @rexx
        @rexx said in Duet2 with two heater cartridges:
        Hello all
        What is the physical arrangement? Is the new heater heating the same thing as the existing heater?
        • rexxundefined
          rexx
          Yes I would add a second to the hot end for a total of 100w 50w each into one hot end
          • fcwiltundefined
            fcwilt @rexx
            Something like this - I'm only showing the commands relevant to your question - your setup will likely be different.
            M308 S0 P"temp0" Y"thermistor" T100000 B4138              ; configure sensor 0 as thermistor
            M950 H0 C"out0" T0 Q250                                    ; create heater output and map it to sensor 0
            M950 H1 C"out1" T0 Q250                                   ; create heater output and map it to sensor 0
            • rexxundefined
              rexx
              Ok I get that part thank you, but where would I get the power on duet 2 is the line out able to support 100w wired 50 each or how is best to make it complete to one tool/hotend/head...thermistor is another board needed
              • fcwiltundefined
                fcwilt @rexx
                The duet has two extruder heater outputs E0 HEATER and E1 HEATER - each is good to 6 amps - a 50 watt heater on 24 volts should draw a bit more than 2 amps.
                  As they are heating the same thing and the heaters draw only 2A each, it would be best to connect both heaters in parallel to a single heater output.
