SOLVED Cannot get BL Touch to work!
I have followed the guides on both Betrue and Duet and cannot get my BL Touch V3 to react to any commands.
My setup is as follows.
Black/white to z probe in and GND
Yellow to pin 8 (heater 3)
Red to pin 1
Brown to pin 2On machine startup, it executes the self test successfully, then red LED lights up and stays on.
I have tried sending all of the m280 commands to test, deploy and restract and nothing happens.
Here is my Config.
; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Feb 19 2021 15:39:15 GMT+1100 (Australian Eastern Daylight Time); General preferences
M550 P"V-King CXY" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M350 Z16 E16:16 I0 ; configure microstepping without interpolation
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z3200.00 E406.00:406.00 ; set steps per mm
M566 X900.00 Y900.00 Z150.00 E600.00:600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z600.00 E21600.00:21600.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z120.00 E1000.00:1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z600 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y370 Z330 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T18000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X48 Y10.8 Z1.2 ; set Z probe trigger value, offset and trigger height
M557 X0:320 Y15:370 S100 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
M143 H1 S300 ; set temperature limit for heater 1 to 300C
M308 S2 P"e1temp" Y"pt1000" R4700 ; configure sensor 2 as PT1000 on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S300 ; set temperature limit for heater 2 to 300C; Fans
M106 P1 S1 H1:2 T50 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P1 D1 H2 F0 ; define tool 1
G10 P1 X20 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T0 ; select first tool; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 29 2020 09:03:19 GMT+1000 (Australian Eastern Standard Time)
M280 P0 S10 ; deploy BLTouch; retractprobe.g
; called to retract a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 29 2020 09:03:20 GMT+1000 (Australian Eastern Standard Time)
M280 P0 S90 ; retract BLTouchAny help would be appreciated.
Thanks
Ned
Ignore that my Retract and Deploy versions dont match...they are all for 3.2.3 now.
@nedmo said in Cannot get BL Touch to work!:
Can you change the setup to exp.heater7?
Try that in the first step.
Wiring up the BL-Touch to exp.heater3 does make some trouble. I can't get why, but we had that several times here.....
I have moved the Yellow wire to pin 31
and attempted to redo the config.; Configuration file for Duet WiFi (firmware version 3)
M307 H7 A-1 C-1 D-1 ; disable heater 7
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M305 P2 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 2
T0 ; select first toolBut, when I send M307 H7 I am getting this.
m307 h7
Heater 7 model: gain 340.0, time constant 140.0, dead time 5.5, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
Computed PID parameters for setpoint change: P13.4, I0.482, D51.4
Computed PID parameters for load change: P13.4
Ok, i got heater 7 disabled now.
Still nothing happens if I send a M401 or M402. The notification is green though indicating that the command was sent successfully.
what firmware version are you on?
3.2 I think. I can check in the morning.
Not used in RRF3.
Verify your firmware version with M115. Your config looks OK for RRF3, but obviously won't work if your installed firmware is actually 2.x
your config is not consistent your entire heater and thermistor config is rrf2
Hi all,
Ok yep, I thought I had upgraded to 3.0, but I was still on 2.5
Now upgraded to 3.2.2. Just ran a fresh config of the RRF3.2.3
And now i am getting my previous issues with H1 and H2 faulting and showing 2000c. Bed is working correctly.
But, good news is that i just ran a M401 and M402 and BLtouch deployed and retracted. So, now I will follow the betrue guide to try a homing operation
Here is my current config.
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Feb 24 2021 12:07:14 GMT+1100 (Australian Eastern Daylight Time); General preferences
M208 X330 Y390 Z330 S0 ; set axis maxima; Endstops
G31 P500 X48 Y-10.8 Z1.2 ; set Z probe trigger value, offset and trigger height
M557 X0:290 Y15:370 S100 ; define mesh grid; Heaters
I am using Semitec 104 GT thermister. I was told I need this config
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8
All problems are now solved and now onto getting the mesh level
