    Hotend always on after updating RRF3
    74
    • zecchi
      zecchi last edited by
      I've just updated to RRF3 and I've noticed that the hotend (hetear 1) is already active when I turn on the printer (even if the power supply is off). Look at the picture
      This is my config file:
      M569 P1 S0 ; physical drive 1 goes forwards
      M584 X1 Y0 Z2 E3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E408.50 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z1500.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z50.00 E1500.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X310 Y315 Z265 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      ; Stall Detection
      ;M915 X Y S7 F0 H200 R2 ; X and Y motor stall detection
      M558 P1 C"zprobe.in" H5 F250 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z1.20 ; set Z probe trigger value, offset and trigger height
      M557 X50:260 Y20:230 S105 ; define mesh grid
      M307 H0 B0 S1.2 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M950 F0 C"fan0" Q1000 ; create fan 0 on pin fan0 and set its frequency
      M950 F1 C"fan1" Q1000 ; create fan 1 on pin fan1 and set its frequency
      M950 F2 C"fan2" Q1000 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F0:2 ; define tool 0
      M911 S22.5 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      T0
      I've already checked the onboard leds: 3.3V is on, 5V is on, e0 Heat as well as Bed Heat are off.
      I've also tried to add "M104 S0" in confing.g but it doesn't work.
      Any advice is welcome. Thanks.
      Rushmere3D 1 Reply Last reply Reply Quote 0
      • Rushmere3D
        Rushmere3D @zecchi last edited by
        @zecchi
        It's active because you have a T0 at the end of your config.g. The temperature is 0 so it's active but not on if that makes sense.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        • zecchi
          Removing T0 at the end of config.g the hotend is no more active but in standby. Is there any way to shut it down?
          • Rushmere3D
            @zecchi I'm not sure but why do you want to? You don't have an active or standby temperature set so it's not going be "On"
            zecchi 1 Reply Last reply Reply Quote 0
            • zecchi
              zecchi @Rushmere3D last edited by
              @Rushmere3D yeah, it's true, it was only to see "off" 😁
              thank you
              • Veti
                Veti last edited by
                active does not mean its heating.
                it means this tool has been selected
                zecchi 1 Reply Last reply Reply Quote 1
                • zecchi
                  zecchi @Veti last edited by
                  @Veti yeah, I've noticed. Thank you for the info
                  • deckingman
                    deckingman @zecchi last edited by
                    @zecchi A "T" followed by negative number will deselect a tool. So using T-0 might make it show as off rather than active at zero degrees. Don't know for sure as I always like to select at least one tool in config.g (because one can't extrude anything until a "Tn" command has been sent.)
                    • zecchi
                      zecchi @deckingman last edited by
                      @deckingman unfortunately T-0 (or any negative value ) doesn't work. At this point I'll leave "T0", as others say there is no difference for me. thank you all!
                        Usually people have the opposite problem where they don't have T0 in config.g and then wonder why the temperature won't change and don't realize that a tool must be selected first.
                        Using G10 P0 R0 S0 sets the temps to 0, so in effect, "off". T0 selects the tool, so that it is ready to accept a temperature command.
