    topic_solved Duex5 Endstop Issue
    105
    • 3DPrintingWorld
      3DPrintingWorld last edited by
      I recently moved my U-axis endstop to the duex5 so I could add two filament runout sensors on my IDEX when I started to get intermittent crashes while homing the Y-axis which was actually do to the U axis not homing correctly before the Y. Its happens about every 5-20 times its homed.
      When I move the U axis endstop from the Duex5 to the WIFI the U axis homes properly and I no longer get the crash while homing Y. Why am I only having this issue with the endstop on the Duex5 but not on the WIFI?
      Config
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"Muldex"                                  ; set printer name
      M552 S1                                         ; enable network
      M586 P0 S1                                      ; enable HTTP
      M586 P1 S0                                      ; disable FTP
      M586 P2 S0                                      ; disable Telnet
      ;M569 P0 S0                                      ; X physical drive 0 goes backwards
      ;M569 P5 S1                                      ; Y right physical drive 1 goes forwards
      ;M569 P6 S0                                      ; Y left physical drive 8 goes backwards
      ;M569 P2 S1                                      ; U physical drive 2 goes backwards
      ;M569 P4 S0                                      ; E1 physical drive 3 goes forwards
      ;M569 P3 S0                                      ; Z left physical drive 5 goes backwards 0
      ;M569 P1 S0                                      ; Z center physical drive 6 goes backwards
      ;M569 P4 S1                                      ; Z right physical drive 7 goes forwards 1
      ;M569 P8 S0                                      ; E2 physical drive 4 goes forwards
      M569 P1 S1                                      ; Y right physical drive 1 goes forwards
      M569 P2 S0                                      ; Y left physical drive 8 goes backwards
      M569 P3 S1                                      ; U physical drive 2 goes backwards
      M569 P5 S0                                      ; Z left physical drive 5 goes backwards 0
      M569 P6 S0                                      ; Z center physical drive 6 goes backwards
      M569 P7 S1                                      ; Z right physical drive 7 goes forwards 1
      M584 X0 Y1:2 U3 Z5:6:7 E4:8                     ; set drive mapping
      M350 X16 U16 Y16 Z16 E16:16 I1                                                        ; configure microstepping with interpolation
      M92 X100.00 U100.00 Y100.00:100.00 Z1096 E415.00:655.00                               ; set steps per mm (1760nimble)
      M566 X1000.00 U1000.00 Y1000.00:1000.00 Z100.00 E100.00:300.00                        ; set maximum instantaneous speed changes (mm/min)(Nimble 40)
      M203 X12000.00 U12000.00 Y12000.00:12000.00 Z2000.00 E4200.00:4200.00         ; set maximum speeds (mm/min)
      M201 X800.00 U800.00 Y800.00:800.00 Z100.00 E600.00:600.00                ; set accelerations (mm/s^2)(500)(Nimble 120)
      M906 X700 U700 Y700:700 Z200:200:200 E600:600 I30                                     ; set motor currents (mA) and motor idle factor in per cent(Nimble 500)
      M84 S30        ; Set idle timeout
      M208 X-21.4 Y0 U33 Z0 S1                        ; set axis min was (-18 BMG)16.7_X-14.4 Y0 U40 Z0 S1
      M208 X344 U414.75 Y334 Z300 S0                     ; set axis max Y WAS 339_X350 U422.7 Y334 Z300 S0(u415.7)
      M669 K0 Y1:1:0:1				                ; select Markforged Kinematics Y to react with X and U
      ; Endstops new
      M574 X1 S1 P"xstop"                             ;X axis active high endstop switch
      M574 Y2 S1 P"ystop+zstop"                       ; Y Double max active high endstop switch
      M574 U2 S1 P"duex.e2stop"                        ;U axis active high endstop switch
      M574 Z1 S2 						; Define Z to use Probe. Home to Min.
      ; Filament Sensor
      M591 D0 P3 C"e0stop" S0 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      M591 D1 P3 C"e1stop" S0 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      M591 D0 ; display filament sensor parameters for extruder drive 0
      M591 D1 ; display filament sensor parameters for extruder drive 0
      M671 X-20.6:200:420.6 Y14.3:333.3:14.3 S5       ; Locations left, center, right
      M950 S0 C"duex.e6heat"                          ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T5000   ; set Z probe type to bltouch and the dive height + speeds (WAS 9000)
      G31 P25 X-29 Y0 Z1.55                             ; set Z probe trigger value, offset and trigger height(lower number farther away)1.54build 1.37glass
      M557 X10:360 Y10:290 S20                        ; probe from X=10 to 390, Y=10 to 290mm with a mesh spacing of 20mm
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4534 C9.565227e-8      ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                            ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S120                                                     ; set temperature limit for heater 0 to 120C
      M307 H0 B0 S1.00                                                 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                          ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.196220e-7 R4700 ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                             ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S280                                                     ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.00                                                 ; disable bang-bang mode for heater  and set PWM limit
      M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.196220e-7 R4700 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2                                             ; create nozzle heater output on e1heat and map it to sensor 2
      M143 H2 S280                                                     ; set temperature limit for heater 2 to 280C
      M307 H2 B0 S1.01                                                 ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"duex.fan4" Q500                             ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S0 H-1                                   ; set fan 2 value. Thermostatic control is turned off
      M950 F3 C"duex.fan8" Q500                        ; create fan 3 on pin duex.fan8 and set its frequency
      M106 P3 S1 H2 T45                                ; set fan 3 value. Thermostatic control is turned on
      ; LEDs
      M950 F4 C"duex.fan6" ;Q500                       ; create LED 4 on pin duex.fan6 and set its frequency
      M106 P4 S255 H-1                                 ; set LED 4 value. Thermostatic control is turned OFF
      M950 F5 C"duex.fan7" ;Q500                       ; create LED 5 on pin duex.fan7 and set its frequency
      M106 P5 S255 H-1                                 ; set LED 5 value. Thermostatic control is turned OFF
      M563 P0 D0 H1 F0 S"Left"                      ; define tool 0 Left
      G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets y was .45
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 X3 F2 S"Right"                        ; define tool 1 Right
      G10 P1 X0 Y-1.45 Z0                                  ; set tool 1 axis offsets (.5BMG) (-1.45)
      G10 P1 R0 S0                                     ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D0:1 H1:2 X0:3 F0:2 S"Copy"              ; define tool 2 Copy
      G10 P2 X95 Y0 U-95 S0 R0                         ; set tool 2 axis offsets (WAS 105)
      M567 P2 E1:1
      M568 P2 S1 ; turn on mixing for tool 2           ; set mix ratio 100% on both extruders
      M501                                             ; Record
      M575 P1 S1 B57600                                ;Panel due
      Homeall
      ; homeall.g
      ; X,U,Y Homing
      T0 P0
      G91                         ; relative positioning
      G1 H2 Z5 F2000              ; lift Z relative to current position
      G1 H1 X-475 U475 F7500      ;Rough home X and U axis
      G1 H1 X-475                  ; home X axis
      G1 H1 U475                 ; home U axis
      G1 H2 X5 U-10 F7500           ; go back a few mm
      G1 H1 Y500 F6000            ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y-5  F6000               ; go back a few mm
      M584 Y1                     ; Y-axis right side
      M574 Y2 S1 P"ystop"         ; Y-axis right side endstop Active
      G1 H1 Y15 F360              ; move slowly to Y axis endstop once more (second pass)
      M584 Y2                     ; Y-axis Left side
      M574 Y2 S1 P"zstop"        ; Y-axis left side endstop Active
      M584 Y1:2                   ; Combine Y-Axis
      G1 H1 X-25 F360              ; move slowly to X axis(second pass)
      G1 H1 U25                  ; move slowly to U axis(second pass)
      G1 H2 X2 U-2 F7500              ; go back a few mm
      ; Z Homing
      T0 P0
      G90 G1 X219 Y150 F6000      ; Move to the center of the bed
      M558 F500                    ; Fast probing speed
      G30                          ; First probe
      M558 F50                     ; Slow probing speed
      G30                          ; Second probe
      G32                          ; Level the bed
      G90 G1 X219 Y150 F7500      ; Move to the center of the bed
      G30                          ; Bed Deviation probe
      G90 G1 X-16                  ; Park x-axis
      • fcwilt
        fcwilt last edited by
        What version of firmware are you running?
        • 3DPrintingWorld
          Oh sorry I missed that somehow. I was running 3.2 but I had a lot of issues happen at around the time of install that I thought were related so I rolled back to 3.1.1 and recently completely erased and reinstalled 3.1.1.
          fcwilt 1 Reply Last reply Reply Quote 0
          • fcwilt
            fcwilt @3DPrintingWorld last edited by
            @3DPrintingWorld said in Duex5 Endstop Issue:
            Firmware 3.2.0 has some issues with endstop handling causing it to miss one on occasion.
            Firmware 3.2.2 fixed that problem.
            3DPrintingWorld 1 Reply Last reply Reply Quote 0
            • 3DPrintingWorld
              3DPrintingWorld @fcwilt last edited by 3DPrintingWorld
              @fcwilt Ok, I've had a few other issues as well when installing 3.2 but when I reverted the other issues are still there as well.
              2/27/2021, 11:44:02 AM M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DGM-9T6BU-FG3SJ-6J1FA-3SN6J-1VYRG
              Used output buffers: 3 of 24 (20 max)
              Static ram: 27980
              Dynamic ram: 95828 of which 44 recycled
              Exception stack ram used: 640
              Never used ram: 6580
              Tasks: NETWORK(ready,368) HEAT(blocked,1224) DUEX(suspended,160) MAIN(running,1640) IDLE(ready,80)
              Owned mutexes: WiFi(NETWORK)
              Last reset 00:46:17 ago, cause: software
              Last software reset at 2021-02-27 10:57, reason: User, spinning module GCodes, available RAM 6660 bytes (slot 2)
              Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
              Error status: 0
              MCU temperature: min 38.5, current 39.8, max 40.3
              Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 0/500
              Driver 1: standstill, SG min/max 0/490
              Driver 2: standstill, SG min/max 0/472
              Driver 3: standstill, SG min/max 0/473
              Driver 5: standstill, SG min/max 0/429
              Driver 6: standstill, SG min/max 0/428
              Driver 7: standstill, SG min/max 0/397
              Driver 8: standstill, SG min/max not available
              Driver 9: standstill, SG min/max not available
              Date/time: 2021-02-27 11:44:01
              Slowest loop: 9.88ms; fastest: 0.13ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 4.5ms, write time 0.0ms, max retries 0
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 163, MaxWait: 999248ms
              === MainDDARing ===
              Scheduled moves: 75, completed moves: 75, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              === AuxDDARing ===
              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              Heater 1 is on, I-accum = 0.0
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 140.13ms; fastest: 0.00ms
              Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is active
                WiFi firmware version 1.23
                WiFi MAC address 60:01:94:2e:09:23
                WiFi Vcc 3.39, reset reason Unknown
                WiFi flash size 4194304, free heap 20576
                WiFi IP address 192.168.0.65
                WiFi signal strength -62dBm, reconnections 0, sleep mode modem
                Socket states: 0 4 0 0 0 0 0 0
                === DueX ===
                Read count 1, 0.02 reads/min
              • fcwilt
                Well the problem you describe was characteristic of firmware 3.2.0 - I never experienced it with 3.1.1 nor with 3.2.0.
                I would suggest you upgrade to 3.2.2 and see if it makes a difference.
                What is axis U used for?
                • 3DPrintingWorld
                  @fcwilt Its a IDEX so T1 is U axis and T0 is the X axis.
                  It homes X and U first then moves them away from the endstops. Next it homes Y to two different endstop switches to square up the gantry. There is a Y axis motor at each end of the gantry. If the U axis is not moved away from the endstop, while homing the Y it will pull the U axis towards the endstop because of the way the Dual markforged kinematics work.
                  It was hard to debug because it looked like a issue with the Y axis homing but it was actually the U axis, it just does not cause a Issue until it gets to the Y axis homing.
                  • fcwilt
                    Well I don't know what sort of arrangement you have but having U axis motion as a "side effect" of homing Y does not sound right.
                    Can you post a diagram of the motion system as used on your printer?
                    Thanks.
                    • 3DPrintingWorld
                      @fcwilt The Kinematics are correct, not really in question.
                      M669 K0 Y1:1:0:1.
                      Its a 0:1 or 1:0 arrangement depending on direction of travel of the Y axis.
                      The issue is the U axis is not stopping at the endstop correctly when connected to the duex5. I dont think the type of kinematics plays a role. Perhaps I gave TMI.
                        Phaedrux Moderator @3DPrintingWorld last edited by Phaedrux
                        M350 X16 U16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X100.00 U100.00 Y100.00:100.00 Z1096 E415.00:655.00 ; set steps per mm (1760nimble) M566 X1000.00 U1000.00 Y1000.00:1000.00 Z100.00 E100.00:300.00 ; set maximum instantaneous speed changes (mm/min)(Nimble 40) M203 X12000.00 U12000.00 Y12000.00:12000.00 Z2000.00 E4200.00:4200.00 ; set maximum speeds (mm/min) M201 X800.00 U800.00 Y800.00:800.00 Z100.00 E600.00:600.00 ; set accelerations (mm/s^2)(500)(Nimble 120) M906 X700 U700 Y700:700 Z200:200:200 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent(Nimble 500) M84 S30
                        You only need singular values for linear axis in M350, M566, M201, M203, M906, etc. It's only extruders that require those values to be defined per drive. Once the driver has been assigned to an axis, you only need to define the settings per axis.
                        3.2.2 did fix some issues with endstops triggering very close together. So updating to 3.2.2 would be a good thing to test.
                        Also something to keep in mind with the duex is that it's usually a good idea to try and keep the Z axis motors and endstops together on the same board, probably the main board. So in your case you could have Y and Z on the mainboard and X U E on the duex. That may help avoid any timing issues.
                        This may also help with your other thread on independent Z leveling.
                        • 3DPrintingWorld
                          3DPrintingWorld @Phaedrux last edited by
                          @Phaedrux said in Duex5 Endstop Issue:
                          This was pointed out in in the last thread. I made some large changes in experimentation and I must have reverted back to multiple values. I'll change it back but I have already confirmed that it will not have an effect. I'm assuming it defaults to the first value given.
                          It does seem like a good idea to put the endstops on the same board as the driver, but I was just trying to keep the X, Y, and U drivers on the same board. If that does not matter, I will move the U axis stepper and endstop back to the WIFI and then move both Y axis motors and endstops to the deux5.
                          Can you confirm that its ok to split drivers that work in conjunction to together on different boards? I would like to move the filament runout sensors to the deux5 but the documentation says it will not work. If its not suggested, then dual filament sensors would not be supported with my setup as I don't see a way around it.
                          I guess I will try 3.2.2 to see what happens.
                            Better to split X Y U than to split the drivers between a single axis, no?
                            Personally I would use the probe for leveling and abandon multiple endstops entirely.
                            • 3DPrintingWorld
                              @Phaedrux I am only using the probe to level Z. The other stepper motors each have a endstop; X, U, Y(left), Y(right). Four in total. I do use two endstops for the Y, that is required to square the gantry to the frame.
                              I have considered sensorless homing for the Y, which would free up to two spots on the WIFI. Another user in our group has had good luck with it.
                                Ah yes, sorry, for some reason I took your other thread about independent z leveling as the reason you were wanting to use multiple endstops.
                                Sensorless homing may be a good option. It might take some tuning though.
                                • martin7404
                                  martin7404 last edited by martin7404
                                  Something that just came to me.
                                  I think a year ago during setting duex5 with my dual lifting extruder experiment in the documentation was stated to take power for the duex from the duetwifi terminal , not directly from PSU. I forgot about that when wiring Muldex and the power for duex comes from PSU, i think others did the same as far the wiring on the github scheme is like that. I wonder if that could be the reason. I do not belive so.link text
                                  The only reason for some troubles could be having bad GND conection between 2 boards
                                  • fcwilt
                                    fcwilt @martin7404 last edited by
                                    @martin7404
                                    This is how I connect power to Duet 2/Duex combos.
                                    The two wires connecting the boards are solid, the two wires from the power supply are stranded.
                                    The goal was to keep the length of wire from each board to the power supply the same so both boards see the same voltage.
                                    • NexxCat
                                      NexxCat last edited by
                                      I had a very similar issue when building my IDEX printer. I seem to remember finding information from @dc42 that the end-stops on the Duex2/5 were polled differently from those on the main Duet2 board. I just moved mine back to the main board and the issue went away.
                                      The issue I had was caused by the end-stop status not changing correctly or becoming stuck as triggered when it wasn't. This caused failed homing on the U axis, or failure to do a second more precise homing move after the coarse one. I verified that it was the Duex by manually triggering the end-stop and monitoring its status in DWC, where you could see it sticking. As soon as I moved it to the Duet2, it worked flawlessly.
                                      • martin7404
                                        So with Muldex that can sol e the U problem, but with 3 Z motors on duex and Bltouch on duetwifi?
                                        3DPrintingWorld 2 Replies Last reply Reply Quote 0
                                        • 3DPrintingWorld
                                          3DPrintingWorld @martin7404 last edited by
                                          @martin7404 Good catch! I remember seeing that too, but I must have spaced it when I did the wiring. The wires are about 100mm long so it might be ok but I'll change it anyways.
                                          • 3DPrintingWorld
                                            3DPrintingWorld @NexxCat last edited by
                                            @NexxCat This sounds like the issue. I updated to 3.2.2 and homed it maybe 10 times and no problem so far but it can be intermittent. I test it some more today.
                                            I would move it back to the WIFI but I was hoping to use two filament runout sensors so I don't have the room on the board for both if I do.
                                            • 3DPrintingWorld
                                              @martin7404 said in Duex5 Endstop Issue:
                                              I did try moving all three z axis motors to the wifi but my leveling was the same.
                                              • fcwilt
                                                Then what ever issue you are having is very likely related to the endstop sensors and/or the wiring.
                                                I have my 3 Z steppers and Z endstop sensors connected to my Duex5 and they all work without problem now that I am running firmware 3.2.2.
                                                • 3DPrintingWorld
                                                  I have not seen this issue repeat since installing 3.2.2. Despite it being bad practice to have the endstop on a different board then the stepper. I will keep a eye on this should nozzle alignments not stay consistent as I often do multi material printing. The end goal is to move the y-axis to senseless homing which will make also room on the mainboard for the remaining endstop.
                                                    dc42 administrators @3DPrintingWorld last edited by
                                                    Despite it being bad practice to have the endstop on a different board then the stepper...
                                                    It's not bad practice, except that on Duet 3 there is one combination that is currently unsupported (endstop connected to main board and motor connected to expansion board).
                                                    3DPrintingWorld 1 Reply Last reply Reply Quote 1
                                                    • 3DPrintingWorld
                                                      3DPrintingWorld @dc42 last edited by
                                                      @dc42 said in Duex5 Endstop Issue:
                                                      Ok, good to know! I would consider this problem solved since I am not seeing any issues since updating to 3.2.2
