    Restart DuetControlServer (SBC)
    2.2k
    • BeosDocundefined
      BeosDoc @gloomyandy
      @gloomyandy
      I don't have that file in /etc/systemd/system/multi-user.target.wants
      I did find it in /etc/systemd/system/sysinit.target.wants/
      Mine at that location is currently:
      [Unit]
      Description=Duet Control Server
      [Service]
      ExecStart=/opt/dsf/bin/DuetControlServer
      TimeoutStopSec=15
      Restart=always
      Type=notify
      User=dsf
      Group=dsf
      UMask=0002
      CapabilityBoundingSet=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME
      AmbientCapabilities=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME
      [Install]
      WantedBy=sysinit.target
      • BeosDocundefined
        BeosDoc @Phaedrux
        @Phaedrux said in Restart DuetControlServer (SBC):
        @BeosDoc said in Restart DuetControlServer (SBC):
        Reseated the ribbon cable...no difference.
        Do you have another ribbon cable to test with or possibly make some jumper cables?
        No other ribbon cable, just the one supplied with your board and I have reseated it. I have short jumper wires I can use. I want to verify the required pins: 19,21,22,23,34 and 20 for ground. Is pin 17 (3.3V) and/or Pin 2/4 (5v) required? SBC has it's own power supply and the duet no jumpers on 5V -> SBC and also SBC ->5V
        • gloomyandyundefined
          gloomyandy
          @Phaedrux My understanding is that problem occurs when the rPi is started but the Duet board does not have any power. In that situation it is possible that the duetcontrolserver service has been suspended (due to the too many restarts), before the Duet board is even started. If that happens there is no way that the Duet is ever going to connect, because it has nothing to connect to. Certainly if that "duetcontrolserver.service: Start request repeated too quickly" message is in the syslog it would indicate that the service is being suspended. Either way the change is easy to make and then test to see if it helps with the problem.
          @BeosDoc That's odd, perhaps it has been moved at some point, my rPi image was created probably a year or so ago (but has been updated continuously since then).
            To be honest I'm not sure about the 3.3 and 5v pins. Try without if you're short on jumper wires.
            • BeosDocundefined
              BeosDoc
              I'll try the jumpers first. Then I'll try the changes to that file.
              • BeosDocundefined
                BeosDoc
                First part. I replaced the ribbon cable with very short, 9cm (ribbon is 20cm), and brand new jumpers. Initial boot worked. After that it still had the status of Off.
                FYI: You do need pin 17 (3.3V) hooked up. Without it, it didn't see it at all.
                For future reference Duet 3 > rPi you need pins 17, 19, 21, 22, 23, 24, 26 (not sure about 26) and one of the grounds (like 20 and/or 25
                Now for the second part with the file
                dc42undefined 1 Reply Last reply Reply Quote 1
                • BeosDocundefined
                  BeosDoc @gloomyandy
                  @gloomyandy said in Restart DuetControlServer (SBC):
                  Given that the main purpose of the SBC is to talk to the Duet I'm not sure it really makes sense to disable the service in this way. If you are happy making changes to the rPi config files (worse case you just reinstall everything), you can tell systemd not to disable a service in this situation by adding the following line:
                  StartLimitIntervalSec=0
                  to the [unit] part of the service control file. In this case that file is:
                  /etc/systemd/system/multi-user.target.wants/duetcontrolserver.service
                  I modified the file /etc/systemd/system/sysinit.target.wants/duetcontrolserver.service
                  I tried it several times and it didn't see it 😞
                  • BeosDocundefined
                    BeosDoc @Phaedrux
                    I've asked christian to take a look at this. Regardless, the Duet and Pi should be making a connection so the retry shouldn't come into play. Seems like either a bad cable or damaged pins.
                    If it was a bad cable or damaged pins, then it probably wouldn't work at all or there would be lots of comm errors. If I reboot the pi or restart DuetControlServer it works find, I've done several prints.
                      gloomyandy
                      @BeosDoc Are you getting any
                      systemd[1]: duetcontrolserver.service: Start request repeated too quickly.
                      messages now in your syslog file? Are you rebooting the rPi to test this?
                      BeosDocundefined 1 Reply Last reply Reply Quote 0
                      • chrishammundefined
                        chrishamm administrators
                        @gloomyandy Thanks for pointing out this limitation, I'll check if I can integrate your change in the next software version. The automatic fail detection wasn't an issue in earlier DSF versions because that always had a restart delay of 5 seconds.
                        @BeosDoc What I find odd about your report is that you do get occasional transfers (albeit with bad checksums) so I'm wondering if there is something wrong with the SPI peripheral either on the Pi or the Duet. Can you run the spidev_test procedure as described here? I'll update the docs with better troubleshooting instructions soon.
                        Duet software engineer
                          dc42 administrators @BeosDoc
                          To clarify: using Duet 3 MB6HC version 1.01 and later, or a Duet 3 Mini, you do need the 3.3v pin because it feeds the voltage translation buffer. You do not need the 5V pin.
                          It's better to connect more than one ground, especially the ground pins close to the SPI pins.
                          • BeosDocundefined
                            BeosDoc @gloomyandy
                            Actually I don't see any of those messages since I made the change to that file. The last time it appeared was 18:22 on Mar 1 which is before I made the change. I did a reboot of pi after I changed /etc/systemd/system/sysinit.target.wants/duetcontrolserver.service but not since then and I even did a print last night. The pi has it's own separate power supply and stays on (several reasons: powering off pi without proper shutdown could cause some corruption, don't want to wait for it to boot 🙂 )
                            gloomyandyundefined 1 Reply Last reply Reply Quote 1
                              gloomyandy @BeosDoc
                              @BeosDoc Well that's a good sign then and possibly removes one potential source of the problem you are seeing.
                              • BeosDocundefined
                                BeosDoc @chrishamm
                                @chrishamm said in Restart DuetControlServer (SBC):
                                Here's the results:
                                pi@duet3:~ $ RDY=22 CS=24 ; {
                                > gpio -1 mode $CS out
                                > gpio -1 mode $RDY in
                                > gpio -1 write $CS 1 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                                > gpio -1 write $CS 0 && echo "(Pin RDY/$RDY) `gpio -1 read $RDY` should equal `gpio -1 read $CS` (Pin CS/$CS)"
                                > { ~/spidev-test/spidev_test -v -s 8000000 -D /dev/spidev0.0 && echo RX should equal TX. ;} | tail -n3 | cut -b-100 ;}
                                (Pin RDY/22) 0 should equal 0 (Pin CS/24)
                                TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D
                                RX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D
                                RX should equal TX.
                                pi@duet3:~ $
                                SPI should be working, I've done several prints. Also, this isn't a good test, it shows that it's working but 32 bytes isn't long enough to see if there is any errors during a long transmission .
                                Is there a SPI test for the Duet 3?
