    e3D V6 settings
    • reshundefined
      resh
      Utilizing this link with my config below. It looks like I remove "bedtemp" and change to 'P1'? Also, the only 'C' I can find for is for M950 which there is no reference. Or maybe that takes place of the Y? Thank you
      https://e3d-online.dozuki.com/Guide/V6+RepRap+Firmware+Configuration/26
      Configuration file for Duet WiFi (firmware version 3)
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin bedtemp
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @resh
        @resh First thing to double check is your firmware version. By the syntax (and reading your other posts) I think you're on RRF3 (likely 3.2.2?).
        In the snippet of your config you have posted, you have all the commands you need for both your bed heater, and your extruder/tool heater
        The first part if for your bed heater (clue is that it says bed!)
        The second half is for the extruder heater:
        You want to update the M308 command for your E0temp to use the correct coefficients for your thermistor. This line should become:
        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8   ; define E0 temp sensor
        This is what the E3D guide is trying to tell you (though they haven't got the Pin name (P parameter) right, so it is a bit confusing.
        I would recommend you also double check the B parameter your bed thermistor. Looks like you've changed it from default to the value for the E3D Semitec. If it is one of these, add in the C parameter too. If not, probably best to find out what the actual coefficients are for your thermistor in your bed heater.
        i3 clone with a bunch of mods
        reshundefined 1 Reply Last reply Reply Quote 1
        • reshundefined
          resh @engikeneer
          @engikeneer thank you for the detailed response. I was mixing up the bed and extruder but you explained it. The bed I have is similar, or maybe exact, to the link below with a Creality glass plate. I'm not finding anything for the thermistor specs for the bed. Is there a way to measure or maybe I'm not looking in the right place?
          https://www.amazon.com/Creality-3D-Platform-Tempered-235x235x3mm/dp/B07FSM8DK9
            engikeneer @resh
            @resh that link is just for the glass plate, not the heater underneath. Ideally you'd need to find the actual datasheet for the sensor fitted. If this is a Marlin printer you're modifying to Duet, you could start by looking up the value in the Marlin firmware by looking at the code
            If it is a cheap, 'no-name' glass bead thermistor, chances are it will be B3950, but best to check.
            You can try measuring it by heating/cooking the bed/thermistor to known temperatures, measuring the resistance and then using an online calculator to determine suitable coefficients. There was a recent thread on how best to do this: https://forum.duet3d.com/topic/21783/analyze-thermistor
            • Vetiundefined
              Veti
              @resh said in e3D V6 settings:
              this is missing the c parameter for the semitec 104gt2
              this is the default and the incorrect value.
              for reference use the config tool. click on the beta value and a selection menu comes up.
