    random number
    Gcode meta commands
    • appjawsundefined
      appjaws
      Is rnd implemented?
      If so what would be the correct syntax to generate a random X move between X30 to X100?
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
        Yes it is, but I don't think it's been updated in the meta command documentation
        https://forum.duet3d.com/topic/17954/random-number-generation-with-meta-commands?_=1614626263724
        It's now been added to the functions list.
        https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands#Section_Functions
        sinned6915undefined 1 Reply Last reply Reply Quote 0
        • appjawsundefined
          appjaws
          Thanks, I'm trying to move X to a random place between X30 and X130.
          I'm really not sure of the correct syntax, have tried
          G1 X30+random(100) Y228 F3000
          but all that happened was a move to X30
          Any ideas on how to achieve this?
          Simplify3D 5.1.2
          • tekkydaveundefined
            tekkydave
            Try:
            G1 X{random(101) + 30} F3600
            or for your exact example above use:
            G1 X{30+random(100)} Y228 F3000
            that will actually move to X between 30 & 129 actually - if you need 30 to 130 put 101 as the parameter to random().
            ~ tekkydave ~
            D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
            FreeCAD, PrusaSlicer
            • appjawsundefined
              appjaws
              thank you so much
              Simplify3D 5.1.2
              • sinned6915undefined
                sinned6915 @Phaedrux
                @phaedrux What version RRF does this apply to?
                I am on 3.1.1 and I get 'unknown function' errors when I try to use it or any of the above suggestions.
                I have tried checking the Changelog file and the only thing I see referenced are the new gcode meta functions for version 3.1.0 and the redirect to the 'GCode_Meta_Commands' page where all this is listed.
                  jay_s_uk @sinned6915
                  @sinned6915 3.2 I believe
