    Duet2 wifi + Duex5 for large printer with 4 Z motors
    752
    • bernardomattiucciundefined
      bernardomattiucci
      first question:
      Duet 2 wifi + Duex5 + PanelDue 7i have been assembled and wired.
      I tried to power everything with the 12volt 30A power supply and the result was the following.
      Sensors: VIN = 8.7 V Temperature = -67 C
      Current Extrusor temperature= 17.2 C
      I then replaced the power supply with the 24 volt 15A one and this is the result.
      Sensors: VIN = 16.8 V Temperature = -67 C
      I don't wish there was any problem with the power supplies (both used).
      Or some configuration problem!
      Tips?
      M122:
      3/3/2021, 18:11:41	M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 0JD0M-9P6M2-NW4SJ-6J1F4-3S46K-KVURM
      Used output buffers: 3 of 24 (12 max)
      Static ram: 23460
      Dynamic ram: 73792 of which 40 recycled
      Never used RAM 14788, free system stack 189 words
      Tasks: NETWORK(ready,179) HEAT(blocked,308) DUEX(blocked,31) MAIN(running,463) IDLE(ready,20)
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:14:47 ago, cause: software
      Last software reset at 2021-03-03 17:56, reason: User, GCodes spinning, available RAM 14788, slot 2
      Error status: 0x00
      Aux0 errors 1,1,1
      MCU temperature: min -69.6, current -66.6, max -65.9
      Supply voltage: min 16.5, current 16.6, max 17.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 5: position 0, standstill, SG min/max not available
      Driver 6: position 0, standstill, SG min/max not available
      Driver 7: position 0, standstill, SG min/max not available
      Driver 8: position 0, standstill, SG min/max not available
      Driver 9: position 0, standstill, SG min/max not available
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-03-03 18:11:40
      Cache data hit count 1075011622
      Slowest loop: 8.60ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.9ms, write time 0.0ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is assembling a command in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 16.61ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.25
      WiFi MAC address e0:98:06:a4:6a:92
      WiFi Vcc 4.36, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 27584
      WiFi IP address 192.168.1.111
      WiFi signal strength -82dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      === DueX ===
      Read count 1, 0.07 reads/min
      Config.g
      ; Communication and general
      M111 S0                         ; Debug off
      M550 P"Quadra 600"							  ; Machine name and Netbios name (can be anything you like)
      ;M552 P192.168.1.111				; IP address
      ;M554 P192.168.1.1				; Gateway
      ;M553 P255.255.255.0				; Netmask
      ;*** End of factory test lines to be removed
      ;*** Networking
      M552 S1					; Turn network on
      M586 P0 S1                                    ; enable HTTP
      M586 P1 S0                                    ; disable FTP
      M586 P2 S0                                    ; disable Telnet
      M555 P2					; Set output to look like Marlin
      G21						; Work in millimetres
      G90						; Send absolute coordinates...
      M83						; ...but relative extruder moves
      M569 P0 S1																				; X Axis - physical drive 0 goes forwards
      M569 P1 S1																				; Y Axis - physical drive 1 goes forwards
      M569 P3 S1																				; Extrusor - physical drive 3 goes forwards
      M569 P5 S1																				; Z1 Axis - physical drive 5 goes forwards
      M569 P6 S1																				; Z2 Axis - physical drive 6 goes forwards
      M569 P7 S1																				; Z3 Axis - physical drive 7 goes forwards
      M569 P8 S1																				; Z4 Axis - physical drive 8 goes forwards
      M584 X0 Y1 Z5:6:7:8 E3																	; set drive mapping
      M350 X16 Y16 Z16 E16 I1                       											; configure microstepping with interpolation
      M92 X33.33 Y128.00 Z800.00 E420.00            											; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00           											; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00       											; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00           											; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                  											; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                       											; Set idle timeout
      M208 X0 Y0 Z0 S1                              											; set axis minima
      M208 X602 Y602 Z602 S0                        											; set axis maxima
      M574 X1 S1 P"xstop"                           											; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                           											; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S1 P"exp.e5stop + exp.e6stop + exp.e7stop + exp.e8stop"                      	; configure active-high endstop for low end on Z via pin exp.e5stop
      ; Thermistors
      M140 H-1                                      ; disable heated bed (overrides default heater mapping)
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ;A"MK8"  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
      M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                          ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H T45                              ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0 S"Estrusore MK8"             ; define tool 0
      G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
      G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
      M575 P1 S1 B57600                             ; enable support for PanelDue
      M208 S1 Z-0.2
      T0
      • Vetiundefined
        Veti
        @bernardomattiucci said in Duet2 wifi + Duex5 for large printer with 4 Z motors:
        i hope you replaced the heater cartridge and the heater on the bed as well
        are you sure thats 75% of the rated current?
        those no the endstops on the duex. they start with duex and go through i2c.
        disconnect the paneldue and see if that helps
        also post a picture of your duet + duex wiring
          bernardomattiucci
          By replacing the 12v power supply with the 24v, I hadn't connected anything.
          Now I have reassembled the 12v and removed the display.
          This is the wiring
          No, I'm not sure of anything. first of all I wanted to understand how it works and fix things as you go. I'll need lots of suggestions ...
          • Vetiundefined
            Veti
            there is the problem that if you connect the paneldue to the wrong header, the voltage will drop.
            this seems to have happened for you.
            you also did not follow the duex wiring guide. see
            https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
              bernardomattiucci
              Ok. the problem with the display was that I had connected both cables supplied ... one, to the PanelDue connector (4 wire cable), the other to the LCD connector (not sure why).
              The supply voltage is now correct, even with the display on.
              I connected the power supply as shown in the photo to the link you suggested (even if the power supply was 30 cm from the boards).
              The next step is to understand how to properly set up the motors.
              For now I want to try with the 12 volt power supply, waiting to receive the various components (hot-end and fans) at 24 volts. The Hot Bed is, for me, a problem ... in the end I think I will have to use a 220v relay (with 12 or 24volt coil) to power the hot-bed, as, with the current structure of the floor, I have a way to mount heaters. It doesn't matter ... at the moment!
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti @bernardomattiucci
                there is a big warning on the page
                Do not run separate ground wires from each terminal block back to the power supply unless the power supply is very close (less than 100mm) to the Duet 2 and Duex.
                so 30 cm is more than 10cm
                bernardomattiucciundefined 1 Reply Last reply Reply Quote 1
                  bernardomattiucci @Veti
                  @Veti
                  Yes, you're right, but I just can't understand why. It does not matter. Now it is OK.
                  The problem now is understanding why the PanelDue works but doesn't seem to interact with the rest of the electronics. Maybe I need to update it?
                    bernardomattiucci
                    The PanelDue has also been updated.
                    Now I have to check the engine settings.
                    Tips?
                    • Vetiundefined
                      Veti
                      what engine settings?
                        bernardomattiucci
                        I have to verify the correctness of the settings, both for the stepper motors and for the remapping of the motors.
                        I have 4 independent motors for the Z axis, each with its own optical sensor (which I am mounting now), placed more or less at the 4 vertices of the XY plane (the printing plane is fixed). I have to make the Z axis move in a coherent way .. reset it using the 4 sensors and manage it properly.
                          That's quite easy with RRF3. All you need to do is connect your 4 z endstops, and then define the used pins in the M574 endstop configuration. And home Z as a single axis as normal.
                          https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
                            bernardomattiucci
                            Everything starts moving ... and if it weren't for the power supply fan, you wouldn't hear anything (or almost)!
                            very beautifull!
                              bernardomattiucci
                              Good morning,
                              I got to the point where I have to set the zeroing of the Z axis considering the fact that I have 4 motors with 1 endstop each.
                              in my config.g I have inserted the following instructions:
                              M584 X0 Y1 Z5: 6: 7: 8 E3
                              M574 Z1 S1 P "duex.e2stop + duex.e3stop + duex.e4stop + duex.e5stop"
                              and this is my homez.g:
                              G91
                              G1 H2 Z5 F6000
                              G1 H1 Z-607 F360
                              G92 Z0
                              How should I proceed?
                              I'm following these directions:
                              https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches+in+RRF2/18
                              But it is not very clear to me what I actually have to do and I would not want to be wrong.
                              In order, the Z axes (Z1, Z2, Z3 and Z4) are positioned as follows:
                              Z1 = X0 Y0
                              Z2 = X0 Y600
                              Z3 = X600 Y600
                              Z4 = X600 Y0
                              Can you give me some advice?
                              Thank you
                              EDIT:
                              Maybe I need to enter the command
                              M671 in my config.g?
                              In my case it would be something like:
                              M671 X-115: -115: 715: 715 y130: 470: 470: 130; Z leadscrews are at
                              Z2 (-115.130) Z2 (-115.470), Z3 (715.470), Z4 (715.130)
                              • Vetiundefined
                                Veti
                                delete the spaces
                                there is no leadscrew location required for this as the endstops determine the position.
                                just the normal z homing will do it
                                  Phaedrux Moderator @bernardomattiucci
                                  These are for RRF2.
                                  I already linked the instructions for RRF3 above.
                                    bernardomattiucci
                                    Good morning
                                    It all seems to work quite well.
                                    Now I just have to figure out how to solve a problem on the Y axis, mostly due to the type of "transmission" used and complete the settings ... before moving on to the print tests!
                                    This is the X axis test: https://youtu.be/UG27txKxALk
