Ooznest Workbee Z Touch Plate Support with RRF3.2.2
@edwardp said in Ooznest Workbee Z Touch Plate Support with RRF3.2.2:
OK - machine up and running.
My probe z macros is now as follows:
M563 P0 S"ZProbe" ; Define a 'fake' tool (is this necessary?) T0 ; set the fake tool M400 ; make sure we've finished any other movements M558 K3 P5 C"!e0stop" ; configure probe 3 as switch connected to e0stop M585 Z10 F600 P3 S1 ; probe 'forward' in Z 10mm or until Probe 3 triggers ; Set the current workplane offset relative to this current position, backed-off 10mm ; in Z to allow for touch plate thickness G10 L20 Z10 I do not appear to have 'deployprobe.g' or 'retractprobe.g' in the system files (or macros) but I did have a 'probe.g', which definitely looks out of date so I have renamed that in case it was problematic.
Macro, as posted, produces no errors, response or movement. For the avoidance of doubt, the machine homes, jogs in all axis, moves under G0/G1 etc. with no apparent issues.
I have the same problems with my workbee
@dc42 perhaps you could post a 'canonical' macro sample showing the commands as you intend them to be used and that you have verified at your end? If there is a typo/mistake in my macro this would help us to flush it out.
The set-up I (and I think many Workbee customers) have is simple and because of Ooznest's documentation: https://learn.ooznest.co.uk/Guide/Assembling+Your+Original+WorkBee+XYZ+Touch+Probe/61they should be configured pretty consistently. At this point I just need to reproduce the simplest Z probe (Step 8 ) under firmware 3.2.2 - which is needed before any CNC toolpath can be run.
The macro needs to drive the tool down in Z until contact with plate is made (wiring as per the link - plate is essentially an NO switch) and set Z0 in the current work-space to be this position, plus the thickness of the plate.
I cannot emphasise enough how core this functionality is. The Duet under RFW3.xx is not, in practical terms, usable as a CNC controller without it. It has been over a month since I raised this problem...
(@scrhall thanks for checking this too, by the way, much appreciated)
@edwardp I had to revert back to firmware 2.0.5 due to this very reason. Though I enjoyed using some of the added functionality in RRF3.2.2 with the DWC-CNC from @Sindarius , the lack of a probing wizard like Ooznest's made me go back to Workbee Control.
@chimaeragh I'm going to stick with RRF 3.??, but I really hope that @Sindarius manages to find the time to develop a plug-in that works in the same way. There must be quite a few of us that are craving this option
@hagrid it is on my list, just been side tracked with some other efforts at the moment.
Hey I use this code and it works as desired
M400 ; make sure we've finished any other movements M558 K0 P5 F100 C"!e1stop" M563 P0 S"ZProbe" T0 ; set the fake tool M585 Z10 F600 P0 S1 ; probe 'forward' in Z 10mm or until Probe 3 triggers G10 L20 Z19.5 ;Set Tool Offset to 19.5mm thickness of the touch plate ;raise the dirll for 5mm for the second run G91 ; relative positioning G1 Z+5 F1000 ; go back a few mm G90 ;absolute positioning M585 Z10 F100 P0 S1 ; probe 'forward' in Z 10mm or until Probe 3 triggers G10 L20 Z19.5 ;Set Tool Offset to 19.5mm thickness of the touch plate ;raise the dirll for 20mm G91 ; relative positioning G1 Z+20.5 F1000 ; go back for 20mm G90 ;absolute positioning But maybe I discovered a bug. If you leave out the first G10 command, the code behaves confusing. After the first pass, the z-axis run down in the ground for maybe 20mm and then perform the second probing. The raise for 5mm don`t seems to be performed. Maybe someone else can reproduce that.
@sindarius No worries. Good things are worth waiting for
I use this macro, i found it on the forum. its working for now
; Z Probing macro M400 ; wait for current movement to finish M291 P"Make sure the probe is connected and the Endmill is on top of the probe" R"Warning" S3 ; warning message G91 ; set relative position G30 S-1 M400 G10 L20 Z19.1 ; set Z offset to 19.1 G1 Z10 M291 P"Probing complete on the CURRENT WCS. Please remove probe." R"Success" S1 ; screen message``` -
@kane - that seems to work for me! Many thanks. I simply changed the e1stop for the e0stop on my machine, but apart from that it seems to now run as I originally expected. There are a number of differences between our versions (we have commands in a different order and I use a different probe and dummy tool number, for example). I'll go through them line now and see if I can identify the precise problem with my original macro. I'll also see if I can confirm the other issue you mention.
Thanks again!
E
