    Duet 3, SBC can I also run Octopi on the SBC for older printers
    Using Duet Controllers
    • warpster
      warpster last edited by
      As the tittle says, I currently run a Railcore with a Duet 3 and toolboard. I'm thinking of adding the SBC to the Duet 3 and I was thinking it would be nice to also run Octopi on the SBC to manage a non Duet printer I have. Is this possible or is the SBC locked into the Duet role only?
      • jay_s_uk
        jay_s_uk last edited by
        that should be possible
        • warpster
          Thanks for the reply. That's encouraging but me being an idiot as far as Linux goes does anyone have a link or some info to help accomplish this?
          • gaweyo
            gaweyo last edited by
            if you plan on running DSF and Octoprint on the same SBC you'll likely need some custom configs as both cannot use port 80 for their own webserver - but can be done.
            • oliof
              oliof last edited by
              Octoprint is already using a reverse proxy for the web serving, so binding DWC to a local IP and reverse proxying that should be possible.
              <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
