    Gantry leveling offset
    731
    • maroondsundefined
      maroonds
      Hi! I was wondering, if it is possible to have an idividual z offset for both z motors. After I level my gantry with g32 the right side is always higher than the left side and I get a bad first layer.
      Board: Duet Maestro running RepRapFirmware for Duet 2 Maestro 2.05.1 (2020-02-09b1)
      • fcwiltundefined
        fcwilt @maroonds
        @maroonds
        G32 is supposed to result in a level bed.
        Something is clearly not working as it should.
        Post your config.g and bed.g files using the </> tag.
        • maroondsundefined
          maroonds
          Sure!
          ; Configuration file for Duet Maestro (firmware version 2.03)
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 22 2020 01:05:56 GMT+0200 (Mitteleuropäische Sommerzeit)
          G90                                                  ; send absolute coordinates...
          M83                                                  ; ...but relative extruder moves
          M550 P"My Printer"                                   ; set printer name
          M552 P192.168.1.69 S1                                ; enable network and set IP address
          M553 P255.255.255.0                                  ; set netmask
          M554 P192.168.1.254                                  ; set gateway
          M586 P0 S1                                           ; enable HTTP
          M586 P1 S1                                           ; enable FTP
          M586 P2 S0                                           ; disable Telnet
          M552 S1 P192.168.178.99
          M569 P0 S1 D3 v0                                     ; physical drive 0 goes backwards X
          M569 P1 S0 D3 v0                                     ; physical drive 1 goes backwards Y
          M569 P2 S0 D3 v0                                     ; physical drive 2 goes forwards Z
          M569 P3 S1 D3 v0                                     ; physical drive 2 goes forwards Z
          M569 P4 S1 D2                                        ; physical drive 3 goes forwards E
          M584 X0 Y1 Z2:3 E4                                     ; set drive mapping
          M350 X32 Y32 Z64 E32 I1                              ; configure microstepping with interpolation
          M92 X160.00 Y160.00 Z1600.00 E695                    ; set steps per mm
          M566 X420.00 Y420.00 Z24.00 E250.00                  ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z720.00 E7200.00              ; set maximum speeds (mm/min)
          M201 X2000.00 Y2000.00 Z1000.00 E1250.00             ; set accelerations (mm/s^2)
          M906 X700 Y700 Z600 E850 I30                         ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                              ; Set idle timeout
          M204 P1000 T2000                                     ; Set printing and travel accelerations
          M572 D0 S0.03                                        ; Pa
          M564 H0                                              ; movement without homing
          M669 K0
          M208 X-5 Y-5 Z-5 S1                                  ; set axis minima
          M208 X234 Y226 Z260 S0                               ; set axis maxima
          M574 X1 Y1 S1                                        ; set active high endstops
          M574 Z1 S2                                           ; set endstops controlled by probe
          M558 P9 H3 F120 T3000 A3 B1                            ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X49 Y23 Z1.87                               ; set Z probe trigger value, offset and trigger height
          M557 X49:233 Y23:220 S15                           ; define mesh grid
          M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
          M305 P0 T98801 B4185 R2200                           ; set thermistor + ADC parameters for heater 0
          M143 H0 S120                                         ; set temperature limit for heater 0 to 120C
          M305 P1 T100000 B4725 C7.060000e-8 R2200             ; set thermistor + ADC parameters for heater 1
          M143 H1 S300                                         ; set temperature limit for heater 1 to 280C
          M307 H2 A-1 C-1 D-1                                  ; Disables H2
          M106 P0 A22 H-1 S0 F150 X185                         ; Part cooling fan
          M106 P2 A2 H1 T45                                ; Hotend fan
          M563 P0 D0 H1 F0                                     ; define tool 0
          G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
          G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
          M208 X-23 Y-14 S1
          M501                                                 ; load saved parameters from non-volatile memory
          M911 S23 R23.7 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          G29 S1
          M671 X-15.0:230.0 Y110.0:110.0
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool v2 on Tue Jan 29 2019 19:02:30 GMT+0100 (Mitteleuropäische Normalzeit)
          G28
          G30 P0 X60 Y100 Z-99999 ; probe near an adjusting screw
          G30 P1 x180 Y100 Z-99999 S2; probe near an adjusting screw
          • fcwiltundefined
            fcwilt
            Don't see anything wrong in those two files.
            Please post your homeALL.g file.
            Thanks.
            maroondsundefined 1 Reply Last reply Reply Quote 0
            • Rushmere3Dundefined
              Rushmere3D
              This post is deleted!
              • maroondsundefined
                maroonds @fcwilt
                @fcwilt I usually have the g32 command in my start gcode. Here's the homeall.g file:
                ; homeall.g
                ; called to home all axes
                G1 H2 Z5 F6000          ; lift Z relative to current position
                G1 H1 X-245 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000       ; go back a few mm
                G1 H1 X-245 Y-240 F360  ; move slowly to X and Y axis endstops once more (second pass)
                G1 X0 Y0 F6000         ; go to first bed probe point and home Z
                G30                     ; home Z by probing the bed
                ;G91                    ; relative positioning
                ;G1 Z5 F100             ; lift Z relative to current position
                ;G90                    ; absolute positioning
                • Vetiundefined
                  Veti
                  post the output of 3 consecutive G32
                  also after a G32, you need to home z again.
                  • fcwiltundefined
                    fcwilt @maroonds
                    @maroonds
                    The only thing I would change is the XY position when using G30.
                    I always use the same exact XY position whenever I do a G30 and I always use the center of the bed.
                    And as mentioned you need to do a G30 after doing one or more G32s.
                    Since it may take more than one G32 to get things level I do it this way:
                    ; *** bed.g ***
                    ; --- set positions of ball studs for auto-leveling (S is max allowed adjustment)
                    M671 X-180:0:180 Y-65:130:-65 S3
                    ; --- run first pass ---
                    M98 P"bed_3.g"
                    ; --- if deviation is too large run additional passes ---
                    while move.calibration.initial.deviation >= 0.02
                      ; check if pass limit reached
                      if iterations = 5
                        abort "Bed Leveling Aborted - Pass Limit Reached"
                      ; run next pass
                      M98 P"bed_3.g"
                    ; *** bed_3.g - called by bed.g ***
                    ; --- probe near ball studs ---
                    G30 P0 X-145 Y-65 Z-99999    ; probe near ball stud #1
                    G30 P1 X0    Y100 Z-99999    ; probe near ball stud #2
                    G30 P2 X145  Y-65 Z-99999 S3 ; probe near ball stud #3
                    ; --- set Z=0 datum ---
                    M98 P"center_probe.g"        ; position to center of bed for probing
                    G30                          ; do single probe which sets Z to trigger height of Z probe
                    • maroondsundefined
                      maroonds @Veti
                      @Veti
                      7.3.2021, 13:20:13 g32
                      Leadscrew adjustments made: -0.035 0.005, points used 2, deviation before 0.016 after 0.000
                      7.3.2021, 13:19:38 g32
                      Leadscrew adjustments made: -0.028 0.006, points used 2, deviation before 0.012 after 0.000
                      7.3.2021, 13:19:05 g32
                      Leadscrew adjustments made: -0.041 0.043, points used 2, deviation before 0.021 after 0.000
                      • fcwiltundefined
                        fcwilt @maroonds
                        @maroonds said in Gantry leveling offset:
                        @Veti
                        For reasons lost in the mists of time as you can see if my bed_3.g file I include a single G30 after the leveling pass.
                        I know you need to do a G30 but I don't know if you need to do it after each pass or after all passes.
                        maroondsundefined 1 Reply Last reply Reply Quote 1
                        • maroondsundefined
                          maroonds @fcwilt
                          @fcwilt Could my issues come from my rather old firmware version?
                          If so, is there a config converter from RRF2 to RRF3?
                          • fcwiltundefined
                            fcwilt @maroonds
                            It's possible but it has been quite a while since I used v2 so I don't have any specific recollection.
                            I don't know of a convertor. I converted by editing my existing files. It wasn't as much work as I thought it would be.
                            I've never used the RRF configuration tool so I don't know if you can load a v2 .json file into the v3 tool.
                            Stephen6309undefined 1 Reply Last reply Reply Quote 0
                            • Stephen6309undefined
                              Stephen6309 @fcwilt
                              @fcwilt I'veloaded a v2 json for a v3 config. It won't populate any of the pin stuff.
                              fcwiltundefined 1 Reply Last reply Reply Quote 1
                              • fcwiltundefined
                                fcwilt @Stephen6309
                                @Stephen6309 said in Gantry leveling offset:
                                Not too surprising since v2 didn't use pin assignments.
                                Thanks for the feedback.
