Duet 3 Mini 5+ VIN under-voltage issues in SBC mode
@dc42 With a SBC. Pi4.
Regards, Paul. -
@paulhew the cause of this issue is still a bit of a mystery; I’ve been running air prints all weekend with different firmware from dc42 to try and narrow it down. It shouldn’t be a problem if you run in standalone mode.
@droftarts I have been trying to get back to a working printer after the couple of hiccups I have encountered after moving over to a Duet Mini 5+ and 1LC, the BLT being the main one, Appreciated your guidance on that Ian.
If I can help test, please let me know. I would be more than happy to run some air prints, however that is done.
Just had another under voltage.
For info....
@paulhew Thanks. Please post response to M115, which shows firmware version and date. We're currently testing newer firmware versions internally, but this problem is proving quite elusive.
@droftarts as requested
m115 FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-02-11
@paulhew Thanks. Is that in SBC or Standalone? I think we haven't seen any 0V events confirmed in Standalone mode.
@droftarts Ian, SBC mode.
I'm seeing this too. DuetMini5+ Ethernet in SBC mode (RPi 3B+), M115 for mainboard and toolboard below:
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3beta1 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-02-14 16:24:45 M115 B121 Duet TOOL1LC firmware version 3.3beta1 (2021-02-14 16:34:04)
I left my printer sit powered on this week, and see 3 VIN undervolt events while idle. It also died again 3 hours into a 5 hour print last night. I'm happy to do whatever troubleshooting would help folks gather more info to get the root cause nailed down.
@fletcher said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
That's the first time we have seen this issue when the printer is idle. Perhaps it just wasn't noticed before. What was the voltage reported with the undervoltage events: 0.0, or a higher value?
Also 0.0v. It's possible I mis-read my logs, but I am pretty sure of what I saw. Also of note: for at least some of that time, my heater was on because I am an idiot (but thankfully I didn't burn my house down). Of course I closed the RRF tab in Firefox this morning because my laptop was dragging -- is there any way to retrieve historical console data from SBC, so I could potentially see exactly when those messages happened and if the heater was on at the time?
[edit]On further thought, I'd say it's more likely that I misread my log, than that this is a new problem you haven't seen before. I'm going to leave my machine on and idle again with a console window up and see if I can capture this again.[/edit]
[edit]I can, in fact, Google, so I've enabled logging with
M929 S1 P"vin-debug.log"
and we'll see what we get. Is there any harm in adding this to my config.g considering I'm running on a 32gb SD card and there's no way I'm anywhere close to filling that? Would be nice if we could do auto log rollover (ie: save to a new filename after the file reaches a certain size) but c'est la vie! [/edit] -
@fletcher You can probably get logs from the SBC:
sudo journalctl --unit duetcontrolserver
Ok, I caught a VIN error while idle! See below: The error at 1:42 AM was the print failing. The error at 4:43 PM was the machine sitting idle.
Happened again Mid-Print.
Had to issue a m564 h0 so I could lower the bed and clear the bed.
Again, SBC mode, rrf3.2.2
P.
@fletcher @paulhew We’ve been testing various new firmwares from @dc42 over the last week, but there’s still an issue. The trouble with this bug is that it can take 24hrs+ to happen! As far as we are aware, it does not happen in Standalone mode, so rather than waste filament on failed prints and raise the level of frustration, disconnect the SBC.
@droftarts Overnight, I had two more events:
I've tried two different PSUs and replaced 100% of the 24v wiring (before finding this thread), so I'm fairly certain it's not a power supply or wiring issue. Only remaining thing I could swap out is the 120V from the power entry module to the PSU, but this really feels like the same issue.
Good news is, I've got a build that seems to reliably generate failures every 12 hours, if you need more beta testers for firmware!
Due to the way my space is laid out, I'd need a wifi bridge (or to re-configure my SBC as a wifi bridge, I suppose) to use the Mini5 Ethernet without the SBC, so I'm down to test firmware for RRF.
I too ( as previously mentioned ) was having this issue , and to test the undervolt side I've swapped back to standalone mode, but kept everything else the same, so the pi4 is still running,its still running Duet interface ( although it cant connect! ), its still running the 7" touch hdmi screen and C270 webcam etc etc etc. The only difference is the onboard SD card, and disconnected the GPIO cable.
2 weeks have now passed and not a single undervolt issue. -
@ukwebb said in Duet 3 Mini 5+ VIN under-voltage issues in SBC mode:
2 weeks have now passed and not a single undervolt issue.Thanks, this confirms what we suspected, that it only happens in SBC mode.
I have identified and (I believe) fixed an issue that was contributing to this problem. For anyone who would like to try it, there is a new firmware build at https://www.dropbox.com/sh/b65da04w1gl94nf/AACLpPslfDiWDlJN5KDdPydAa?dl=0.
@dc42 Thanks as always for your hard work.
Have loaded and will let you know..
