    help with config.g
    1.6k
    • patterson6undefined
      patterson6 @Phaedrux
      @Phaedrux so i found a 100ohm in my bin and wired it up. On channel P"spi.cs0". I am now getting 4.3c on the hotend. So i am going to put in the new smart effector when i can and order a new pt100 to be safe. thanks
        The daughter board comes with a 100Ω resistor that you can wire in place of a two wire sensor to check the board is working correctly. With the resistor in place, the reading should be 0°C.
        If the reading at room temperature is higher than it should be, then you probably have a bad connection between the RTD interface board and the sensor, or the wires to the sensor are too long or too thin. Each additional ohm of wiring resistance will increase the temperature reading by 2.5C. Using a 4 wire solution PT100 sensor will improve this. If you only have a 2 wire P100 sensor you can still improve the accuracy by using 4 wires for the majority of the distance
        patterson6undefined 1 Reply Last reply Reply Quote 0
          @Phaedrux You mind checking my starting and ending scripts? The starting script seems to work like it should. let me know if you see anything out of place or odd. The ending script does not work like it really should. One of the main problems was the color Teal would not even show in the cool down period. It would just go to green as showing finished.
          starting script
          ;*********************************** RED HEATING UP ********************************************
          M106 P4 S0.0 ; Turn off white led
          M106 P5 S1.0 ; Turn on red led
          M106 P6 S0.0 ; Turn off green led
          M106 P7 S0.0 ; Turn off blue led
          G21 ; Set Units to Millimeters
          G90 ; Set to Absolute Positioning
          M82 ; Set extruder to absolute mode
          G28 ; Home
          M400 ; Finish all moves above first
          M104 S140 ; Set extruder temperature
          M141 H2 S70 ; Set chamber radiator temperature
          ;M141 H2 S35 ; Set chamber recirc temperature *not in use at this time
          M191 P70 ; Wait for chamber temperature to reach target temp
          M109 S140 ; Wait for extruder temperature to reatch target temp
          M400 ; Finish all moves above firrst
          ;********************************** PURPLE * PRE HEATED and START CALI * **************************
          M106 P7 S1.0 ; Turn on blue to make purple
          G32 ; Auto Calibration
          ;********************************** ORANGE Achieve final temps * ***********************************
          M106 P6 S0.06 ; Turn on green led 6% to make orange
          M104 S[extruder0_temperature] T0 ; Set extruder temperature
          M109 S[extruder0_temperature] T0 ; Set extruder temperature to first layer temp
          ;*********************************** WHITE * START PRINT* *****************************************
          M106 P4 S1.0 ; Turn on white led
          M106 P5 S0.0 ; Turn off red led
          ending script
          G28 ; Move home
          M104 S0 ; Cool the extruder
          M106 P3 S0.0 ; Turn off berd-air
          ;*********************************** TEAL COOLING OFF *********************************************
          M106 P6 S1.0 ; Turn on green led
          M106 P7 S1.0 ; Turn on blue led
          M191 S35 ; Wait for chamber temperature to reach target temp
          M190 S35 ; Wait for bed temperature to reach target temp
          M140 S0 ; Turn off bed
          M141 H2 S0 ; Turn off chamber radiator
          ;M141 H2 S0 ; Turn off chamber recirc heater *not in use at this time
          ;*********************************** GREEN FINISHED **********************************************
          M84 ; Disable motors
          ;end
            Phaedrux Moderator @patterson6
            @patterson6 said in help with config.g:
            It's probably ignoring these commands because the target temp is too low.
            Note: M190 will not wait for temperatures below 40c because in many cases they may never be reached due to ambient temps. So if you want to wait for a bed to cool, use 41c or higher.
            This goes for all the other heater commands as well.
              @phaedrux
              ok so i really haven't been able to print anything yet. The problem i am having is the nozzle is pushing down on the bed at the start of the print. Added 2mm to Z-axis in S3D and im still getting the same effect. I tried just using auto cali, mesh and then both and same results in starting script. When i G32 i M500 and saved the info to config override. The height map is mostly green with a touch of blue after G29. Im not great at this part. What would you need to see to help me?
              Back on the duet 2 i had this bad boy printing anywhere with no prob using mesh. I dont have a mesh.g. Do i need one? Thanks
                Let's see your bed.g, homedelta.g for starters.
                patterson6undefined 2 Replies Last reply Reply Quote 0
                  This post is deleted!
                    @phaedrux
                    ; bed.g
                    ; called to perform automatic delta calibration via G32
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Feb 28 2021 07:03:53 GMT-0600 (Central Standard Time)
                    ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                    ; 16 points, 6 factors, probing radius: 215, probe offset (0, 0)
                    G28
                    G30 P0 X0.00 Y215.00 Z-99999 H0
                    G30 P1 X138.20 Y164.70 Z-99999 H0
                    G30 P2 X211.73 Y37.33 Z-99999 H0
                    G30 P3 X186.20 Y-107.50 Z-99999 H0
                    G30 P4 X73.53 Y-202.03 Z-99999 H0
                    G30 P5 X-73.53 Y-202.03 Z-99999 H0
                    G30 P6 X-186.20 Y-107.50 Z-99999 H0
                    G30 P7 X-211.73 Y37.33 Z-99999 H0
                    G30 P8 X-138.20 Y164.70 Z-99999 H0
                    G30 P9 X0.00 Y107.50 Z-99999 H0
                    G30 P10 X93.10 Y53.75 Z-99999 H0
                    G30 P11 X93.10 Y-53.75 Z-99999 H0
                    G30 P12 X0.00 Y-107.50 Z-99999 H0
                    G30 P13 X-93.10 Y-53.75 Z-99999 H0
                    G30 P14 X-93.10 Y53.75 Z-99999 H0
                    G30 P15 X0 Y0 Z-99999 S6
                    ; homedelta.g
                    ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Feb 28 2021 07:03:54 GMT-0600 (Central Standard Time)
                    G91 ; relative positioning
                    G1 H1 X1200 Y1200 Z1200 F2200 ; move all towers to the high end stopping at the endstops (first pass)
                    G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
                    G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
                    G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
                    G90 ; absolute positioning
                    G1 X0 Y0 F6000 ; move X+Y to the centre
                      M558 P5 R0.4 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
                      G31 P100 X0 Y0 Z4 ; set Z probe trigger value, offset and trigger height
                      What type of z probe do you have and have you measured the trigger height?
                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                      Can you post an image of your heightmap display?
