    Duet 3 to Ender 5 bed heater wiring
    • olorin42undefined
      olorin42
      Hi all, working on revamping my Ender 5 Pro with a Duet 3. Initially I'm just connecting to what is there to get things functional before changing things around. I've got everything functional at this point except for the bed heater.
      Based on the documentation this is how I wired it up:
      The documentation describes a secondary power source hooked up to OUT 0 POWER IN which I'm assuming is switched at the OUT 0 port. I doubled the connections from the PSU to OUT 0 POWER IN, but something is clearly not right. I tried to bring the bed temperature up to 40C and I heard some buzzing and then I got a fault warning on the bed.
      What am I doing wrong here?
      Thanks,
      David
      • fcwiltundefined
        fcwilt
        @olorin42
        That is how I would have hooked it up.
        How is the heater configured in config.g?
        • olorin42undefined
          olorin42
          This is my heater section:
          M308 S0 P"temp0" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin temp0
          M143 H0 S150 ; set temperature limit for heater 0 to 150C
          M308 S1 P"temp1" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
          M143 H1 S275 ; set temperature limit for heater 1 to 275C
          As far as I can tell the thermistors are reading correctly and the nozzle does heat up. It's just the bed heater that is buzzing when engaged before it faults.
          Thanks,
          David
          • Vetiundefined
            Veti
            @olorin42 said in Duet 3 to Ender 5 bed heater wiring:
            you have most likely not run a pid tune. this will cause a heater error of temperature not rising fast enough in rrf3.
            • olorin42undefined
              olorin42
              @Veti I definitely haven't done a PID tune and the error reported is temperature not rising fast enough. I'll go look up PID tuning now. Thanks!
              Thanks,
              David
                Is this the stock ender 5 bed heater?
                https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                • olorin42undefined
                  olorin42
                  @Phaedrux it is the stock bed heater. @Veti's suggestion of doing the PID tuning worked. I'm not sure what the buzzing noise was, but it didn't repeat and the PID tuning went smoothly for but the bed and hot end.
                  I've now got everything up and running. I just finished setting up a custom printer in Cura and am running a test print now. I'm not expecting miracles on this first pass but I'm keeping my fingers crossed for it to complete so I can figure out where I need to start with tuning parameters.
                  Thanks,
                  David
