    Broken microUSB socket
    PanelDue
    • felekundefined
      felek
      Hi!
      Accidentally I've broken microUSB socket (X3 label on PCB) on PanelDue.
      @T3P3Tony I can't find a BOM.
      Can you send me link to supplier?
      Thanks
        droftarts administrators @felek
        @felek If you have a v2 or v3 PanelDue, it's the same as the one used on all Duet 2 and 3 boards, Amphenol FCI 10103594-0001LF. Should be available through most places like Mouser, Digikey, Farnell and RS (at least in the UK).
        I've also (finally) added it to the list here: https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Common_and_other_parts
        Edit: added part number for PanelDue 5i and 7i microUSB socket, Würth Elektronik 614105150721
          ...except for the PanelDue 5i and 7i, which use a different USB connector.
          • felekundefined
            felek
            @droftarts @dc42
            I can't find PanelDue PCB revision, but I hope I have the newest.
            I've found this micro usb but looks different
            https://www.digikey.com/en/products/detail/amphenol-icc-fci/10103594-0001LF/2350351
            https://pl.mouser.com/ProductDetail/Amphenol-FCI/10103594-0001LF?qs=EnLMdcWnKABYZwdMsmC%2Fag%3D%3D
            MicroUSB from PanelDue has 5 pins in 2 row (3 and 2), Duet2 WiFi has 5 pins in a row.
            Am I right?
              dc42 administrators @felek
              @felek said in Broken microUSB socket:
              Am I right?
              The 5i and 7i use a straight through-hole USB connector. We think that Wurth 614105150721 is a compatible connector.
              felekundefined 1 Reply Last reply Reply Quote 1
              • felekundefined
                felek @dc42
                @dc42 This one looks fine! Thanks
                  Connector type USB3130-30-A may also be compatible with the 5i and 7i.
