    Duet Mini 5+ non responsive and files missing
    • oc_geekundefined
      oc_geek
      The card by time to time does not connect or looses connestion and the directories (all) appear empty
      This appears to be related with the issue on the SD card chip soldering ....
      Does not look good...
      Board: Duet 3 Mini 5+ (Mini5plus)
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.3beta1 (2021-02-14)
      Duet WiFi Server Version: 1.25
      And this is a dump of the diagnostics
      OC_GEEK_Voron
      Send code...
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      206.5
      Y
      304.0
      Z
      26.78
      Extruder Drives
      Drive 0
      0.0
      Speeds
      Requested Speed
      0 mm/s
      Top Speed
      0 mm/s
      Sensors
      Vin
      24.1 V
      Z-Probes
      0 0
      Tools
      Extra
      Control All
      Tool Heater Current Active Standby
      Tool 0
      T0 - Load Filament Hotend
      active 24.4 C
      0
      0
      Bed Bed Plate
      off 25.8 C
      0
      0
      Temperature Chart
      Send code...
      3/13/2021, 1:06:33 PM M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.3beta1 running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: F8W09-K196U-D65J0-40KM0-LH03Z-Z1XLX
      Used output buffers: 3 of 40 (31 max)
      Static ram: 98792
      Dynamic ram: 114764 of which 84 recycled
      Never used RAM 28072, free system stack 130 words
      Tasks: NETWORK(ready,228) SENSORS(delaying,25) HEAT(delaying,317) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,341) TMC(notifyWait,108) MAIN(running,426) IDLE(ready,20) AIN(delaying,260)
      Owned mutexes:
      Last reset 00:29:11 ago, cause: power up
      Last software reset at 2021-03-09 21:00, reason: User, GCodes spinning, available RAM 27656, slot 2
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      Supply voltage: min 0.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 81680, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 22435, writes 9, timeouts 0, DMA errors 0
      Driver 1: position -15600, standstill, SG min/max 0/466, read errors 0, write errors 0, ifcnt 16, reads 22428, writes 16, timeouts 0, DMA errors 0
      Driver 2: position 21424, standstill, SG min/max 0/472, read errors 0, write errors 0, ifcnt 16, reads 22428, writes 16, timeouts 0, DMA errors 0
      Driver 3: position 0, standstill, SG min/max 0/30, read errors 0, write errors 0, ifcnt 15, reads 22427, writes 15, timeouts 1, DMA errors 0, failedOp 0x01
      Driver 4: position 0, standstill, SG min/max 0/28, read errors 0, write errors 0, ifcnt 15, reads 22429, writes 15, timeouts 0, DMA errors 0
      Driver 5: position 0, standstill, SG min/max 0/458, read errors 0, write errors 0, ifcnt 16, reads 22427, writes 16, timeouts 1, DMA errors 0, failedOp 0x06
      Driver 6: position 0, standstill, SG min/max 0/466, read errors 0, write errors 0, ifcnt 16, reads 22428, writes 16, timeouts 0, DMA errors 0
      Date/time: 2021-03-13 13:06:31
      Cache data hit count 3024462402
      Slowest loop: 10.77ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 4.0ms, write time 58.4ms, max retries 0
      DMs created 83, maxWait 277852ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 16, completed moves 16, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
      === AuxDDARing ===
      Bed heaters = 0 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Filament sensors ===
      Extruder 0 sensor: ok
      === CAN ===
      Messages queued 15768, send timeouts 15765, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
      === Network ===
      Slowest loop: 169.11ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.25
        WiFi MAC address f4:cf:a2:6f:e9:87
        WiFi Vcc 3.45, reset reason Power up
        WiFi flash size 2097152, free heap 25448
        WiFi IP address 10.0.0.7
        WiFi signal strength -53dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
        3/13/2021, 1:06:20 PM Upload of Spalla L R-4h30m.g successful after 7s
        3/13/2021, 1:06:07 PM Successfully deleted Spalla L R-4h30m.g
        3/13/2021, 1:06:04 PM Successfully deleted Spalla L-2h44m.g
      • pkosundefined
        pkos
        In my case, what we believe is the soldering issue - the board does not get up anymore after a failed read, since it can't read any of the files on the card - the firmware, the webui, nothing.
        From your screenshots it would seem as if you can connect to the board, but it's just the files that are missing?
        Voron 2.4 (Duet 3 6HC + 3HC standalone), Voron SW (Duet 3 mini 5+ standalone), Voron Trident (Duet 3 mini 5+ standalone), Voron 0.1
        • oc_geekundefined
          oc_geek
          it's a go / no-go thing
          i can't connect, WIFI gets very very slow and all files are missing
          i power down/up cople of times it comes back...
          ...that said it's not very reassuring status
          IMHO the card is doing something (trying to read SD without luck) and does not answer -> reason for low WiFi rate / no response
            @oc_geek sorry to hear that. Please contact your vendor and initiate a warranty exchange. Please include a link to this thread as authorization.
            oc_geekundefined 1 Reply Last reply Reply Quote 0
            • oc_geekundefined
              oc_geek @Phaedrux
              @Phaedrux as i was fearing this to happen (i saw signs weeks back) i actually bought (when those were still available) a spare Mini 5+ from Dold (Germany) at the same time i bought the 2+ expansion; i didn't like the idea to stay without my only controller for e.g. some weeks if something bad would have happened
              That said it would be redundant to me to have two cards and if that would be an option i would rather prefer to go with a refund rather then a replacement; this also considered that i bought one of the first cards which were ava and those were from UK E3D...
              Is that possible ?
              thanks in advance
