    Incomprehensible problem
    1076
    • synergy41
      synergy41 last edited by
      Hello everyone,
      Well I still have a problem with my DUET WIFI, I think earlier that it is a problem of setting, but I can not understand what I do wrong …
      So I could not calibrate my nozzle properly,
      That is my way of doing things.
      1: I lower the nozzle until touching a sheet of paper on the tray.
      2: I look at the value of Z for example "1,50",
      3: I put the g code G92 Z0, the value of the Z axis changes to 0,
      4: I go into the config file and here:
      Z probe and compensation definition
      ; *** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
      M558 P1 X0 Y0 Z0; Z probe is an IR probe and is not used for homing any axes
      G31 X0 Y0 Z1.50 P500; Set the zprobe height and threshold (put your own values here),
      I get my value find here 1.50.
      Once that is done if I try to do a G1 Z0 F3000, my nozzle will sink into the tray,
      Do you have an idea,
      Thank you
      I LOVE MY DUET WIFI
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.4.1
      Cura 4.10
      • Jackal
        Jackal last edited by
        What is the Z value when the nozzle touch the surface when you have Z1.50?
        Maybe try setting Z-1.5 in your G31 instead.
        I always have trouble dealing with the +/-, all I have done was trial and error 😛
        Someone else could probably give you a more scientific approach
        • synergy41
          thank you for your reply,
          Not the value is +1.50.
          I am forced to go up the buzzard so it's much more I think.
          I LOVE MY DUET WIFI
          Cura 4.10
          • Dougal1957
            Dougal1957 last edited by
            do you have a Z Probe?
            If so what type is it?
            • synergy41
              Yes I have a BL TOUCH
              I LOVE MY DUET WIFI
              Cura 4.10
              • Jackal
                I believe the offset is only applied during the probing calculation, so you need to do another calibration before the offset is actually applied to the max print height.
                • Dougal1957
                  The value for Z in the G31 line needs to equal the hight of the nozzle above the bed when the BLtouch triggers.
                  • synergy41
                    If my BL Touch is too high this can be a problem?
                    I LOVE MY DUET WIFI
                    Cura 4.10
                    • synergy41
                      Well I'm really fooling with this machine,
                      It's been 3 whole days now that I try to do something with it but without success,
                      I think I will leave it aside and continue with my BLACK WIDOW that works really well,
                      One last question before I go through the window: what distance do you put between the BL TOUCH when the probe is in and the nozzle?
                      Is there a risk in making an update of the DUET WIFI,
                      Thank you for your patient
                      I LOVE MY DUET WIFI
                      Cura 4.10
                        @synergy41:
                        Yes, it could be so high that it doesn't trigger before the nozzle hits the bed.
                        With any Z probe, you should always test it, measure it's trigger height and put that value in the G31 command in config.g before you try to use it for homing of bed probing.
                        • synergy41
                          I'm still looking for my calibration problem.
                          I do not know what is wrong,
                          So here is the method that I practice,
                          1 - I lower my head until I catch a sheet on the board,
                          2- I then make a G92 Z0
                          3- I raise the head to about 50mm
                          4- I release the BL TOUCH
                          5- I lower the head until the BL TOUCH goes up and lights up
                          6- I open my config file and change the value here;
                          G31 X0 Y0 Z1.65 P500; Set the zprobe height and threshold (put your own values here),
                          And when the machine restarts I make G1 Z0 F1500 and the head come to sink a big blow in the plate,
                          What am I doing wrong?
                          Thank you
                          I LOVE MY DUET WIFI
                          Cura 4.10
                          • Dougal1957
                            for a start you have your config set for a IR Probe and not a BLtouch there is a thread on here about how to use a BL Touch.
                            • Forgvn77
                              Forgvn77 last edited by
                              I created a mount for my BLTouch that's connected to my Duet WiFi and included a number of Duet WiFi configuration/script files. It works good and you should be able to use them for a reference and the macro files to run your BLTouch.
                              https://www.thingiverse.com/thing:2389034
                              John
                              Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                              Make A Difference!
                              • synergy41
                                Thank you for your answers, I'll look at it later; I have to look at another problem "I really have no luck with this machine"
                                I miss the update of the DUET WIFI
                                I LOVE MY DUET WIFI
                                Cura 4.10
