    Attempt to move motors when VIN is not in range
    1.8k
    • Milkeundefined
      Milke
      I am using a DUET 2 WIFI 1.03 with sucsses for more than 2 years. Today when I start a new job, I received a nmessage thath the board can not start because the , Vin is 34 volts, but the real voltage is 24 volts. The power supply is OK.
      The issue:
      When I try to move the motors it says "Attempt to move motors when VIN is not in range"
      DWC shows 34.2 V in VIN
      I have tested all fuses they show zero ohm
      I have measured power in and it shows 24 V
      I have measured from power to heatbed and it shows 24V
      I have measured from power to hotend and it shows 24V
      Wifi Blue light check
      3.3V green light check
      5V red light check
      VIN blue light check
      Z,Y, X stop red lights check
      I have checked that VIN is tight (it is tight..)
      All jumpers are in "stock" positions
        The Duet uses the 3.3V rail as the voltage reference. So if it is saying that VIN is too high, most likely either there is a problem with the ADC in the microcontroller, or the 3.3V rail is low. I suggest you measure the voltage on the 3.3V rail, also check whether ICs on the Duet or the WiFi module or SD card socket are getting hot.
        Milkeundefined 2 Replies Last reply Reply Quote 0
        • Milkeundefined
          Milke @dc42
          @dc42. Thanks. I will check
          • Milkeundefined
            Milke @dc42
            Today I checked the 3,3 Volts line on Board, it is ok, 3,29 Volts on my multimeter, I also Checked the 5 volts line and the results are 4,9 volts, then I disable the internal 5 volts regulator and add a external 5 Volts power, the results are 4,9 volts whit panel due plugged and the same without the panel due connected.
            I tested the reference voltage on inductor L5 and Capacitor C64, the voltage is 3,29 Volts .
            I checked the temperarture in Wifi Board and SD Card whith my PIR thermomether 33,3 °C and 33,2° C.
            I put the voltagem for my power supply on 21,3 Volts; the result on Uet WEb Control is around 23,8 to 24,2 Volts. M122 Command report:
            m122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
            Board ID: 08DJM-9178L-L4MSJ-6J1F6-3SN6N-9T1LR
            Used output buffers: 3 of 24 (20 max)
            Static ram: 27980
            Dynamic ram: 93868 of which 52 recycled
            Exception stack ram used: 552
            Never used ram: 8620
            Tasks: NETWORK(ready,404) HEAT(blocked,1224) MAIN(running,1552) IDLE(ready,80)
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:29:20 ago, cause: power up
            Last software reset at 2020-08-30 15:50, reason: User, spinning module GCodes, available RAM 8908 bytes (slot 3)
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
            Error status: 0
            MCU temperature: min 36.8, current 37.2, max 37.7
            Supply voltage: min 21.3, current 22.2, max 24.9, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 2: standstill, SG min/max 0/492
            Date/time: 2021-03-15 12:20:05
            Cache data hit count 2931106711
            Slowest loop: 8.16ms; fastest: 0.13ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 1.8ms, write time 0.0ms, max retries 0
            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 1324495ms
            === MainDDARing ===
            Scheduled moves: 10, completed moves: 10, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            === AuxDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 201.64ms; fastest: 0.09ms
            Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is active
              Failed messages: pending 0, notready 0, noresp 1
              WiFi firmware version 1.23
              WiFi MAC address cc:50:e3:e3:bc:ea
              WiFi Vcc 3.38, reset reason Unknown
              WiFi flash size 4194304, free heap 23632
              WiFi IP address 192.168.1.113
              WiFi signal strength -65dBm, reconnections 0, sleep mode modem
              @Milke said in Attempt to move motors when VIN is not in range:
              At what point does it start to show the wrong voltage? As soon as you try to move a motor?
              Milkeundefined 1 Reply Last reply Reply Quote 0
              • Milkeundefined
                Milke @Phaedrux
                @Phaedrux said in Attempt to move motors when VIN is not in range:
                Now the voltage of My Power Supplay is 24 volts checked with multimeter and a voltage display. The DUet Web Contro, show me 13,2 Volts and M122: Error status: 0
                MCU temperature: min 37.2, current 39.3, max 39.6
                Supply voltage: min 12.2, current 14.1, max 14.6, under voltage events: 0, over voltage events: 0, power good: yes
                With low voltage I can move the motors , the voltage do not change in the power supply, I use a 30A/24Volts Power Supply for Duet2Wifi (motors and hot end), for thehot bed I use a separate Power Supply 12Volts/50A, I use separate Mosfets for hot bed and hot end.
                I don't know what's going on. Sometimes the voltage is high and the motors do not start, sometimes the voltage is low and I can print to a certain point until the machine suddenly stops.
                I checked the temperarture in Wifi Board and SD Card whith my PIR thermomether 33,1 °C and 33,1° C.
                Is it possible that the processor is defective Or could the inductor and capacitor be in trouble?
                Could it be problems in the inductor?
                If I change the inductor L5 and Capacitor C64, will it solve?
                  I am confused. First you reported that the voltage reported by the Duet was 34.2V. Now you are saying it is 14V. Whar did you do to provoke the change?
                  • hackinistratorundefined
                    hackinistrator
                    if i'm not wrong , Vref is also powering thermistors .
                    try to disconnect all your thermistors and see if the voltage reading is right .
                    • Milkeundefined
                      Milke @Milke
                      @dc42 I am also confused, because sometimes when I turn on the machine, the voltage shown on the DWC and detected by the board is around 30 volts and sometimes around 14 volts, but the power supply is stable at 24 volts all the time.
                      I also checked the 3,3 Volts line on Board, it is ok, I also Checked the 5 volts line and the results are ok.
                      ADVREF or VDDOUT problems? Or VDDIN or VDDCORE?
                      • Milkeundefined
                        Milke @hackinistrator
                        @hackinistrator Are you referring to thermistors 0 to thermistor 7?termistores.jpg
                        hackinistratorundefined 1 Reply Last reply Reply Quote 0
                          hackinistrator @Milke
                          @Milke i see only 0 to 2 connected to Vref . maybe if one of them is shorted to +24V it effects the reference .
                          • Milkeundefined
                            @hackinistrator said in Attempt to move motors when VIN is not in range:
                            Could you help me identify it on the board? Their number and position?
                            • Milkeundefined
                              @hackinistrator Do you refered to bed thermistor and hot end thermistor? I disconnected both, the same problem, powe suplly 24 volts, DWC show me 17 volts
                                @Milke it might be bad adc i guess .
                                if Vref is bad , then i guess you should also see your hotend / bed temps fluctuate , this is not the case , right?
                                maybe also try connecting the board to your second 12v supply and see if the readings are also off .
                                • Milkeundefined
                                  Milke
                                  The hotend / bed temps are correct, there is no variation, they remain constant as a function of time.
                                  I changed my 24 volts power supply, and the 12 volts power supply too, the problem persists. Nothing changed.
                                  WhatsApp Image 2021-03-17 at 20.23.48.jpeg WhatsApp Image 2021-03-17 at 20.23.49.jpeg WhatsApp Image 2021-03-17 at 20.23.49 (1).jpeg WhatsApp Image 2021-03-17 at 20.24.07.jpeg 24,3 Volts on the new 24 volts power supply and around 17 volts on DWC.
                                  • Milkeundefined
                                    Milke
                                    HI people. The same problem, today I can not start the machine because the Vin is 9,1 volts, yesterday I printed whith 18 volts...
                                    Anyone can help me?
                                      Checking to see if there is any means of repair short of replacing the MCU.
                                      When and where was the Duet purchased?
                                      • Milkeundefined
                                        Milke @Phaedrux
                                        Sorry, I don't understand, do you say to replace the MCU or try to repair it without replacing the MCU?
                                        I bought it from a friend in Brazil who referred me to the duet.
                                        Last week I bought a Duet2Wifi clone from Makerbase in China, as I live in Brazil, the pound is very expensive for us, the cost of importing a Duet2 from England is around 364.30 pounds.
                                        Today when I turn on the machine, the voltage shown on the DWC and detected by the board is around 2,60 volts. Yestarday was around 14 volts, but the power supply is stable at 24 volts all the time.
                                        It is possible to repair Verfe components or it is necessary change thecustoimportacao.jpg MCu....
                                        I attached the simulation to buy a new Duet2wifi to Brazil.
                                          Unfortunately the quality of the clones is hard to predict.
                                          What kind of access to hot air rework and oscilloscope do you have? Whether the effort is worth it, or just replacing the board entirely may be more effective.
                                          • alankilianundefined
                                            alankilian
                                            @Phaedrux Is Vin monitored through one of the POWER_FAIL_DETx inputs?
                                            If so, he could measure the voltage at those components and see if it's strange. It's possible one of the two resistors in the divider are poorly soldered or cracked.
                                            Milkeundefined 1 Reply Last reply Reply Quote 1
