WiFi reported error: network scan failed
I've got a Duet Wifi (1.02+) running RRF 3.3.2. This printer has been running the same config.g and connecting to the same network for weeks. The router has not been repositioned (it's about 8 feet away) and there's nothing else (new) around it that ought to be interfering with the WiFi.
The Duet is on a UPS and active cooled. The room is 65 degrees or so. It had been printing off and on for maybe a week before this started. The printer is semi-enclosed with PVA foam board.
Some time last night I lost connectivity with the Duet. I have a Panel Due, so I was able to observe the status. I rebooted and got something like this:
WiFi module is idle WiFi reported error: no known networks found WiFi module is idle WiFi reported error: Timed out while trying to connect to <correctnetworkname> WiFi module is idle WiFi reported error: Timed out while trying to connect to <correctnetworkname> WiFi module is idle Error retrieving WiFi status message: bad reply format version
So that last bit seemed weird, and searching indicated maybe I needed to reflash the firmware. So, I re-grabbed the 3.2.2 zip file, unpacked, grabbed DuetWiFiServer.bin, copied on the SD card, and reflashed. Panel indicated success.
Now I'm getting streams of
The router is working; there's a Pi in roughly the same location serving video that I can still connect to.
Help? Thanks!
Rob
What does M122 show for the wifi section?
Can you try cycling through the wifi states?
M552 S-1
M552 S0
M552 S1
M552 S2Snnn 0 = disable networking, 1 = enable networking as a client, 2 = enable networking as an access point , -1 = disable WiFi module
What does the status LED on the module itself show?
Try reflashing again?
If that still doesn't work, try testing it in access point mode and see if that works.
https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M589_Configure_access_point_parameters
Thanks for responding! Access point mode seems to have issues. I've tried a second reflash without luck. Details below. Thoughts?
Lights
You asked about lights. I believe I was getting a blinking blue light on the WiFi before the March 14th reflash, now no blinking (either before or after 2nd reflash).
Status after boot (prior to 2nd reflash)
Still in this state, repeating every couple of seconds:
WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle
Diagnostics (complete, prior to 2nd reflash)
>> M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later Board ID: 08DAM-9K9K2-NGNS0-7JKDJ-3SJ6K-T70BL Used output buffers: 5 of 24 (13 max) === RTOS === Static ram: 23460 Dynamic ram: 73440 of which 24 recycled Never used RAM 15156, free system stack 187 words Tasks: NETWORK(ready,322) HEAT(blocked,294) MAIN(running,451) IDLE(ready,20) Owned mutexes: USB(MAIN) === Platform === Last reset 00:01:23 ago, cause: power up Last software reset details not available Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 20.1, current 25.9, max 26.1 Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 0, standstill, SG min/max not available Driver 1: position 0, standstill, SG min/max not available Driver 2: position 0, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 1970-01-01 00:00:00 Cache data hit count 100163503 Slowest loop: 6.92ms; fastest: 0.22ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.7ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1.48ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 0 of 8 - WiFi - Network state is changingMode WiFi module is idle Failed messages: pending 0, notready 0, noresp 0 Failed to get WiFi status Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok ok
Cycling through WiFi states
>> M552 S-1 Error retrieving WiFi status message: SPI timeout WiFi module is idle Failed to change WiFi mode: SPI timeout ok >> M552 S-1 ok >> M552 S0 ok WiFi module started >> M552 S1 ok WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle >> M552 S0 ok WiFi reported error: no known networks found WiFi module is idle ok WiFi module is providing access point 314cf6c12bfd05e849455c6w4q2s, IP address 65.84.84.51 Error retrieving WiFi status message: SPI timeout Error retrieving WiFi status message: SPI timeout Error retrieving WiFi status message: SPI timeout ... >> M552 S0 WiFi module stopped ok
Firmware refresh
Following https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
Copied all these over (overkill...):
- Duet2_SDiap32_Maestro.bin
- Duet2_SDiap32_WiFiEth.bin
- Duet2CombinedFirmware.bin
- Duet2CombinedIAP.bin
- Duet2Firmware_SBC.bin
- DuetWiFiServer.bin
Q: Docs indicate four files. Did I miss one?
... WiFi module is idle >> M997 S0 T:17.6 /0.0 T0:17.6 /0.0 B:18.4 /0.0 Shutting down USB interface to update main firmware. Try reconnecting after 30 seconds. WiFi module is idle WiFi reported error: no known networks found WiFi module is idle ... >> M997 S1 T:17.5 /0.0 T0:17.5 /0.0 B:18.4 /0.0 WiFi reported error: no known networks found WiFi module is idle Trying to connect at 230400 baud: success Erasing 4096 bytes... Erasing 196608 bytes... Uploading file... 5% complete ... 95% complete Upload successful ok WiFi module started WiFi reported error: no known networks found WiFi module is idle ... WiFi reported error: no known networks found WiFi module is idle WiFi reported error: no known networks found WiFi module is idle
Diagnostics (after 2nd reflash)
>> M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later Board ID: 08DAM-9K9K2-NGNS0-7JKDJ-3SJ6K-T70BL Used output buffers: 1 of 24 (10 max) ... === Network === Slowest loop: 2238.53ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 0 of 8 - WiFi - Network state is changingMode WiFi module is idle Failed messages: pending 0, notready 0, noresp 0 Failed to get WiFi status Socket states: 0 0 0 0 0 0 0 0 ... ok Error retrieving WiFi status message: SPI timeout WiFi module is idle Failed to change WiFi mode: SPI timeout
That last bit seems interesting. Otherwise status seems same as prior to first reflash (although I only flashed WiFi that time, M997 S1).
Also, just to be clear, the printer will print fine when supplied a gcode file on the SD card.
Before enabling access point mode did you configure the SSID and password, etc with M589?
When and where did you purchase the Duet?
@Phaedrux I did not configure the AP; I'll do that and report back.
This Duet was purchased from Filastruder around April 29, 2017. Been working well this whole time, thousands of hours of prints.
Are those SPI errors normal?
Let's see how AP mode goes. The SPI errors are normal in that they are a thing that can happen. But they are not ideal. It's possible that the wifi module is failing.
But try AP mode and try adding your SSID again.
TL;DR: AP mode works ok. Console output below (inputs hand-inserted as best I can).
I guess this implies that something about my router or the overall environment changed. I'm going to rebuild the router (little GL-MT300a box) and also see if I can get it positioned even closer to the Duet. I'll follow up if it turns out that I cannot get it to connect after the rebuild.
Any other thoughts?
Thanks for the help in debugging!
Rob
>> M589 S"DuetWifi" P"duetwifi" I192.168.11.1 Error: M589: Failed to configure access point parameters: WiFi module is disabled >> M552 S0 ok >> 589 S"DuetWifi" P"duetwifi" I192.168.11.1 ok >> M552 S2 WiFi module started ok ok WiFi module is providing access point DuetWifi, IP address 192.168.11.1 >> M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later Board ID: 08DAM-9K9K2-NGNS0-7JKDJ-3SJ6K-T70BL Used output buffers: 1 of 24 (24 max) === RTOS === Static ram: 23460 Dynamic ram: 73440 of which 60 recycled Never used RAM 15120, free system stack 108 words Tasks: NETWORK(ready,186) HEAT(blocked,294) MAIN(running,417) IDLE(ready,20) Owned mutexes: USB(MAIN) === Platform === Last reset 30:51:04 ago, cause: power up Last software reset details not available Error status: 0x0c Aux0 errors 0,0,0 MCU temperature: min 26.9, current 28.6, max 29.3 Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 27000, standstill, SG min/max not available Driver 1: position -23000, standstill, SG min/max not available Driver 2: position 172437, standstill, SG min/max not available Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-03-17 19:05:22 Cache data hit count 4294967295 Slowest loop: 99.86ms; fastest: 0.22ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.8ms, write time 0.0ms, max retries 0 === Move === DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 829277, completed moves 829277, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is ready with "M122" in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 16.12ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is providing access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.25 WiFi MAC address 5e:cf:7f:37:8f:14 WiFi Vcc 3.40, reset reason Turned on by main processor WiFi flash size 4194304, free heap 25672 WiFi IP address 192.168.11.1 Connected clients 1 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 === Filament sensors === Extruder 0 sensor: ok ok
Well at least we know the wifi module is working.
@paralepsis I am having the same problem, except using the access point mode is not helping. Did you find a fix?
@tylersuard please start your own thread with your board info and M122 output
@tylersuard in my case I thought that the AP was fine, but in fact it had died.
@paralepsis The AP died, how did you handle it? Did you get a replacement from Duet, or ...?
