Core XYU Z Movement Issue
HI, I have just built a Core XYU and basic movement is all working well and as expected. X Homes to left of the gantry and U homes to the right of the gantry.
I have just started to work towards dual printing, but the issue I have just discovered is that when X is active then Z movement is as you would expect, however when U is active and you try and change Z then the Z Carriage moves as expected but at the same time the U carriage is moved towards its home location.
Any ideas please?
TFree,TPost and TPre for both tools are empty.
config.g -
firmware version? Duet board type?
;M669 K5 ; switch to CoreXY mode M669 K1 X1:1:0:0 Y1:-1:0:1 Z0:0:1:0 U0:0:0:1 M669 K5 should work for corexyu. Why did you switch to a custom matrix?
Duet 2
Firmware 2.05.1 -
Because there is a fault with K5 that is not corrected until V3. I do not really want to go to V3 yet.
@pcsentinel said in Core XYU Z Movement Issue:
Are you sure you mjean Z and not Y? What is the "Z carriage"?
Hi DC42, following further tests, it seems to happen with both Y and Z instructions. So with the attached video, The active tool is Tool 1 (U) and I have sent a G1 Z25. The U Carriage moves back to Home and the Z Carriage moves down . If you then send a U-1 from the console. the U moves back to its original location and 1 left.IMG_3633.mp4
When Tool 0 is active (X) then all works properly.
What that homing move shown in the video?
Can you pot your homing files and any tool change files?
The homing move was not called, that just occurs when you do a Z or Y move, that's the whole issue. The tool files are empty.
If I make Tool 0 o r Tool 2 active (which does not exist I know), then Z and Y moves act as expected. This only occurs when Tool 1 is active
why do you have v axis defined ?
@hackinistrator Because I am using the same logic as worked out in https://forum.duet3d.com/topic/16375/core-xyu-or-xyuv/25?_=1615925048500
Which means (as far as I understand) you have 4 motors for a core XYU all of which need to move independently to achieve XY or UY movement.
As I've said above, All X Y U Z movement works absolutely fine when T0 is the active tool, than anomaly only happens when T1 is active.
@pcsentinel i think you are making a mess .
for dual carriage (coreXY) printer , if you have 2 motors for each carriage , then its XYUV .
if the second carriage connected to a single motor then its XYU .
your matrix defined as XYU , but drive mapping its XYUV .
how is the second carriage actually connected ? -
@hackinistrator Sorry, but I think you are wrong, please see: the link from above. Also the firmware code from the Duet is as follows:
case KinematicsType::coreXYU: // Core XYU is like CoreXY with an additional U axis controlled by the U and V motors inverseMatrix(0, 1) = 1.0; inverseMatrix(1, 0) = 1.0; inverseMatrix(1, 1) = -1.0; inverseMatrix(1, 3) = 1.0; inverseMatrix(1, 4) = -1.0; inverseMatrix(3, 4) = 1.0; inverseMatrix(4, 4) = 0.0; // V can't be commanded directly break; case KinematicsType::coreXYUV: // CoreXYUV is a dual CoreXY setup inverseMatrix(0, 1) = 1.0; inverseMatrix(1, 0) = 1.0; inverseMatrix(1, 1) = -1.0; inverseMatrix(3, 4) = 1.0; inverseMatrix(4, 3) = 1.0; inverseMatrix(4, 4) = -1.0; break; i.e. a core XYUV effectively has two XY carriages whereas a Core XYU has 2 heads mounted on a single Y carriage.
I am guessing I have 1 setting wrong somewhere that is causing this issue. Do you have a Core XYU machine, if so maybe you could post the config.g so that I can do a comparison.
Can you post some pictures of your machine?
@pcsentinel please tell hoy many motors connected to your second carriage .
its possible to make coreXYUV with single gantry , if 2 motors control second carriage . -
@hackinistrator There are4 motors controlling the XYU carriage. please see my post above which shows you that the firmware defines that as being core XYU
then its core XYUV , your m669 is wrong .
@hackinistrator 4 motors:
break; -
@Rushmere3D Hi, please see the video linked above and below.
you defined custom matrix , not just K5 or K8 . your m669 is wrong .
if you have 4 motors for XYUV
matrix should be something like that :M669 X1:1:0:0:0 Y1:-1:0:1:-1 Z0:0:1:0:0 U0:0:0:1:1 V1:-1:0:1:-1
